Old Oct 28, 2009, 01:28 PM
SpookiePower is offline
Find More Posts by SpookiePower
Denmark, Capital Region of Denmark, Brøndbyvester
Joined Jun 2009
From how far can my controller reach my plane
I still got my stock EZ* and today I did a new altitude record 337meters/1236feets.
I was wondering how far I can go with my EZ*, when using the Hitec Zebra 4 FM pro controller and the Hitec Zebra ZR 105SF receiver ? I had no problems controlling my plane at that distance. But someday I'm afraid that I go to high, and loose the control.
SpookiePower is offline Find More Posts by SpookiePower
Old Oct 28, 2009, 06:05 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
If you go to high and lose control hen you are ok as when it starts to come down you will get it back. Going to far away and losing control is another thing as it will properly drop to the ground. the best way to know for sure how far you can go with you're setup is to test it and you can do this with the help of a friend. have someone hold the plane while you walk away while controlling it until you no longer have control, this will give you a better idead then a online member saying he can go 1500-2000-3000 ft.
freechip is offline Find More Posts by freechip
Old Oct 28, 2009, 06:22 PM
nicoyenny is offline
Find More Posts by nicoyenny
globemaster
nicoyenny's Avatar
USA, CA, Cypress
Joined Jun 2008
You will first lose sight of the plane
BUT if your radio batteries are low, well, I hope the plane lands close to here
nicoyenny is offline Find More Posts by nicoyenny
Old Oct 28, 2009, 08:08 PM
m61hp09 is offline
Find More Posts by m61hp09
North Jersey
Joined Jul 2008
There are too many variables to say an exact distance a particular plane can fly before losing control. Bottom line is, straight up is the only direction you would want to go out of range if you need to. Any other direction and you will probably lose it.
Generally, there is a failsafe that cuts the throttle when it is out of range, meaning it'll float back down within range. Just don't fly it 2000 feet horizontally over a neighborhood. BAD IDEA
~Mark
m61hp09 is offline Find More Posts by m61hp09
Old Oct 28, 2009, 08:17 PM
chimmike is offline
Find More Posts by chimmike
wind sucks
Sarasota, FL
Joined Sep 2009
if you need binoculars to fly the plane properly, it's too far anyways!
chimmike is offline Find More Posts by chimmike
Old Oct 28, 2009, 10:36 PM
outngo is offline
Find More Posts by outngo
E-Gliders
outngo's Avatar
South Carolina
Joined May 2009
Most are rated 1miles+
outngo is offline Find More Posts by outngo
Old Oct 28, 2009, 11:43 PM
Ickarusmelt is offline
Find More Posts by Ickarusmelt
old pilot
Ickarusmelt's Avatar
Rapid City SD
Joined Dec 2007
With most any popular radio systems you can get too far off to see orientation before you lose radio contact. At least if you can't see an EZ*, it is likely to come down okay by itself if you cut the power and let go the stick (unless it's over a freeway).
Ickarusmelt is offline Find More Posts by Ickarusmelt
Old Oct 28, 2009, 11:44 PM
Xpress.. is online now
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
That radio is only rated for short range, so about 1500ft. would be max. And the receiver is a refaced Micro05S
Xpress.. is online now Find More Posts by Xpress..
Old Oct 29, 2009, 08:37 AM
Joined Jun 2009
1500ft, that's about 450 meters. Maybe I should not go any higher, so far.
thanks
Old Oct 29, 2009, 03:12 PM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
A couple of things.
If trying to check the range in the air, always do it up wind, never down wind. If the model loses the signal, hopefully it will drift with the wind back towards you.
Tx aerials radiate a signal rather like the shape of a donut. So pointing your aerial at the plane is usually a lower signal strength than turning the side to the model.
eflightray is offline Find More Posts by eflightray
Poll How far have you flown from Base Poll Bindle83 FPV Talk 36 Nov 01, 2009 05:54 PM
Poll How far do you travel to reach your nearest flying field? arukum17 Sailplane Talk 73 Apr 13, 2008 04:45 PM
How far can I push my Multicont X-08 ESC tduro Beginner Training Area (Aircraft-Electric) 3 Apr 30, 2005 11:28 AM
How far can I push my Multicont X-08 ESC tduro Electric Ducted Fan Jet Talk 0 Apr 28, 2005 03:42 PM
