Joined Sep 2007
Boeing 737 kit
Hey guys: Has anybody flown one of these?
http://www.hobbytron.com/Boeing737Du...CAirplane.html I love airliners but they are either too expensive or won't take off on my grass field. I'm thinking of getting it, junking the radio and putting ailerons on it. If you know of any other kits, let me know. |
I would say get a large piece of paper and start drawing your own, to a size that's respectable for you. I would use a Clark airfoil or something similar............should provide plenty of lift. I would build it out of depron foam if I were you and keep the weight down. I would do a built up fuse with all depron pieces and maybe a few ply blukheads around the wings for strength, but you could do all the formers and planking out of depron. no complex curves or shapes, so would be very easy to build. it's basically a tube with a tapered rear and a nose. LOL. if it were me, I would be designing it around a pair of twin 64's/65's. they are cheap to buy and readily available at many sources. and it's a one off and totally yours..............how cool is that? I would go online and get some good 3 views. just my two cents.
here's a link to a 3 view with a few dimensions, but there are many more out there. http://www.tc.faa.gov/its/worldpac/techrpt/ar98-28.pdf |
actually, I was just on EJF.com and windrider have a Boeing 787 EDF, and it's a pretty respecatable size. it's for twin 70mm and is basically 65"wingspan and 62" length. and better still, it's only 200 bucks. here's the link if you are interested.
http://www.ejf.com/index.php?main_pa...roducts_id=797 good luck Rich |
designing your own
hi, i used the boeing web site for the 3 view plans to design my 737-500, http://www.boeing.com/commercial/airports/3_view.html.
you will need a cad reader to see it. i used to use the free brava onehttp://www.infograph.com/products/dwgviewer/, click the last one, (it says View DWG, DWF & DXF) install it and when you click on the plans on the boeing web site they will open up. you could build my 737 from my plans on http://www.rcgroups.com/forums/showthread.php?t=1119909. you could scale up the plans larger to fit any size edfs you want, the construction would be the same, may be just use 6mm depron for the formers instaed of 3mm. |
| Thread Tools | |
| Build Log A little boeing 737-500 build thread | brett1984 | Foamy EDFs | 51 | Apr 15, 2012 04:39 PM |
| Zagi 400X vs Boeing 737-400 | Ex-Slimedriver | Foamies (Kits) | 4 | Nov 19, 2007 03:49 PM |
| Boeing 737 - the new project | Hawker | Foamies (Kits) | 34 | Sep 09, 2007 06:01 PM |
| Discussion Twin EDF75 Boeing 737 | pardus | Electric Ducted Fan Jet Talk | 27 | Sep 21, 2004 01:35 AM |
| Boeing 737 | jermaine | Foamies (Kits) | 6 | Apr 08, 2002 11:21 PM |
