Old Oct 28, 2009, 11:40 AM
EQMOD is offline
Find More Posts by EQMOD
EQMOD's Avatar
Joined Mar 2008
Lama V4: Increasing Flybar to Blade Grip Cyclic Pitch transmission
I previously did this mod on walkera 4#3B and was successful.
http://www.rcgroups.com/forums/showthread.php?t=1127892
The idea in simple mechanical sense is to extend the ball links on the flybar outwards.
This increases the pitch angle on the grips on a per flybar pitch angle. This as a result increases the amount of stabilization correction from the flybar to the blades allowing even small shaft tilts to be corrected.
As done on a LAMAV4;
* This was done by taking the ball linkages from an old flybar and transfer them to the Lama V4's flybar.
And a short test video;
Lama V4: Amplifying Flybar Stabilization without adding weights. (2 min 34 sec)
EQMOD is offline Find More Posts by EQMOD
Old Oct 28, 2009, 08:49 PM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
here is a short outdoor flight test;
Lama V4: Amplifying Flybar Stabilization without adding weights. - Outdoor (4 min 58 sec)
Old Oct 28, 2009, 10:28 PM
Chap1012 is offline
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
As always EQMOD, I love your vids, both the indoor and outdoor. Dang, I wish I had another V4. When I'm done testing some blades and blade grip stiffeners for a member, I am considering a double flybar link. That indoor flight was incredible..great left/right AIL. Heck, great flying...PERIOD
Thank you (Again) for sharing,
Mike.
Chap1012 is offline Find More Posts by Chap1012
Old Oct 31, 2009, 02:49 AM
erdnuckel2 is offline
Find More Posts by erdnuckel2
erdnuckel2's Avatar
Joined Mar 2009
Don't know if I mentioned this in this thread before (in this case again):
Awesome job EQMOD!!!
Would you tell me if you are using the stock transmitter for your double swash plate helis or did you do the mods and use a "more professional" (I didn't want to say "real") transmitter (spektrum, futaba, hitec ....)??
Sven
Old Oct 31, 2009, 09:06 AM
EQMOD is offline
EQMOD's Avatar
Joined Mar 2008
Sven
Hi Sven,
i am using a futaba transmitter although the stock transmitter will do just fine.
regards,
Mon
Discussion LAMA V4 Dual Swash Flybarless : Tabletop Cyclic Punch EQMOD Coaxial Helicopters 7 Oct 24, 2009 05:03 PM
Sold Brushless Blade CX2 CX3 Lama V3 V4 Complete Kit syncronized Aircraft - Electric - Power Systems (FS/W) 1 Oct 24, 2009 12:07 PM
Discussion Walkera 4#3B: Increasing Flybar Pitch transmission for more stability (plus an idea) EQMOD Micro Helis 21 Oct 19, 2009 05:23 PM
Sold Lama V4; Blade CX2 Bing44 Aircraft - Electric - Helis (FS/W) 2 Aug 27, 2009 10:02 AM
Discussion Flybar link source for lama V4 (blade CX?) caffinatedbear Coaxial Helicopters 3 Jan 29, 2009 11:47 PM
