Old Oct 28, 2009, 11:02 AM
JoeSantora is offline
Find More Posts by JoeSantora
USA, CO, Lakewood
Joined Sep 2002
Fus/wing ratio
Are there any rules of thumb for the ratio of fus length(tail) to wingspan?
Joe
JoeSantora is offline Find More Posts by JoeSantora
Old Oct 28, 2009, 01:49 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
No.
structural issues put an upper limit on it, and zero is the lower limit.
Old Oct 28, 2009, 03:47 PM
nmasters is offline
Find More Posts by nmasters
internet gadfly
nmasters's Avatar
Colorado
Joined Aug 2006
Originally Posted by vintage1 View Post
No.
LOLI like zero myself, Joe, but if you really want other numbers search for "tail volume".
--Norm
nmasters is offline Find More Posts by nmasters
Old Oct 28, 2009, 06:00 PM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
As the others have indicated there is a huge range and thare is no 'right length'. Generally structural issues and weight asside its more efficient to have a long tail boom, but weight and structural issues do have to be considered in the real world.
At the risk of being shot down in flames, i'll stick my neck out and say; 'Normal average looking' planes usually have the distance between the wing and the tail about equal to half of wing span.. But this is a horrible sweeping generalisation and there are many planes that are way outside this 'rule'.
Steve
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Nov 01, 2009, 05:57 AM
HugePanic is offline
Find More Posts by HugePanic
German Engineering.......
HugePanic's Avatar
Auxsburg
Joined Dec 2007
a nother rule of thumb i catched up here:
measure the angle between wingtip, tail and wingtip.
if itś somewhere 90 it should be ok...
HugePanic is offline Find More Posts by HugePanic
Old Nov 01, 2009, 10:00 AM
Aberdeen
Joined Mar 2006
Which is just another way of saying that the wing to tail length should be about half of wing span......
Old Nov 01, 2009, 06:13 PM
Wendi Smol is offline
Find More Posts by Wendi Smol
Fanwriter - VAK Educator
Wendi Smol's Avatar
Europe
Joined Dec 2008
Originally Posted by JoeSantora View Post
Are there any rules of thumb for the ratio of fus length(tail) to wingspan? Joe
Don't let them fool you with their arrogant pseudo little science games (which are also factually wrong in many cases).
In praxis the ratio between fuselage length l and wing span b for single- engined tractor planes [ l/b ] is between 0.8 and 0.5. Usually the chord (or mean chord) of the wing [ c ] is the guiding parameter. One c in front of the wing and two c for the tail behind normally produce a balanced fuselage.
For modern gliders the ratio can be between 0.4 and 0.3. Because of the narrow chord one often ends up with two "c" in front of the wing and four for the tail.
W.
Wendi Smol is offline Find More Posts by Wendi Smol
Old Nov 02, 2009, 01:35 AM
Aberdeen
Joined Mar 2006
Wendi,
There is only one person arrogantly pedalling 'rough rules of thumb' as firm scientific theory in this thread....
Steve
Old Nov 02, 2009, 09:12 PM
BMatthews is offline
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
I put my drawings on the wall and then stand back and squint. If it looks about right then that's close enough....
Seriously though there's no optimum length at all. However there's some pluses and minuses to either long or short depending on what you want to do with the model. It's also entirely possible and practical to make the tail extremely long or extremely short. We don't see many super long tails but there's lots of examples of super short tails that are still not actual flying wings. The Great Planes Slo Poke is one and the Clancy Lazy Bee is another. Scale models of racing planes from the 30's often have very long fuselages compared to the wingspan and do just fine as well.
It really comes down to aesthetics. To produce a design that is aesthetically pleasing that is based even loosely on full sized or other models study the plans or 3 views of such designs and blatantly copy them in terms of the tail length and overall fuselage length to span so you get the same overall planform appearance.
But just be aware that you still want to ensure you have either a decent horizontal tail volume coefficient or that you make some other choices in a suitable airfoil for those cases where you want to make the tail super short and still keep the stabilizer normal sized. In other words the more closely the model resembles a plank style flying wing the more important it is to have an airfoil that has a very low negative pitching moment, a neutral pitching moment or a positive pitching moment. The neutral or positive pitching moment choice being suitable for either an extremely short coupled model with a very small tail or a full on plank style flying wing.
BMatthews is offline Find More Posts by BMatthews
Old Nov 03, 2009, 04:16 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
contol line combat models ended up as wings with no fuselage partly because tails were vulnerable, but also because a wing without a fuselage tail is the fastest turner of all.
The longer the fuselage, the better relationship there is between wing and tail and the better overall L/D the model will have, so gliders tend to have long tails for efficiency.
In between is really arriving at a different sort of compromise. Pattern ships tend to have long tails because a long tail at a fixed sort of airspeed tends to be smoother in manoeuvring, and operating close to zero net up-force or down-force, will fly inverted as well as right way up with minimal trim changes.
More sporty models will tend to have shorter tails for greater nimbleness, and operate with net downforce on the tail. This makes them both a bit less neutral to fly, and a bit more responsive to large control input.
There is no one answer. Despite all these rules of thumb.
Discussion What is the normal thrust to weight ratio of a flying wing? Will I have enough power? stuntflier91 Flying Wings 18 Nov 02, 2015 09:27 PM
Discussion Any ideas on strengthening the Wasabi fus.?- Sorted!! cliffhanger Slope 6 Sep 18, 2009 06:29 AM
Wanted Trinity F3F 3M FUS/WING PARTS blurr Aircraft - Sailplanes (FS/W) 2 Dec 15, 2007 03:52 PM
Discussion Wing to Fus combo Wing-span Sailplane Talk 9 Apr 06, 2007 01:15 PM
FOR TRADE vt e-graphite fus for a ct fus talonxracer Aircraft - Electric - Airplanes (FS/W) 0 Jun 10, 2004 12:58 AM
