Old Dec 29, 2011, 05:02 PM
the1upper is offline
Find More Posts by the1upper
United States, MD, Brandywine
Joined Dec 2011
Eflight 10-15 tri - set. Then make custim steering servo. The stock gears are junk.
The first attempt to fix i cut thin roofing sheet metal to use as the broken arm (expoxy'ed in)
the1upper is offline Find More Posts by the1upper
Old Dec 29, 2011, 07:14 PM
rochet is offline
Find More Posts by rochet
Joined Aug 2005
Thanks for the advice!
rochet is offline Find More Posts by rochet
Old Jan 03, 2012, 05:03 PM
stanordave is offline
Find More Posts by stanordave
stanordave's Avatar
Joined Jan 2006
Should the ailerons move up w/up elevator or down?
My F-22 has them going opposite ways but a video of the F-35 has them going the same way. Which is right?
I would think the up aileron w/up elevator would be counterproductive but...?
Merci,
stanordave is offline Find More Posts by stanordave
Old Jan 03, 2012, 06:05 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
Pitch up with tailerons, flapperons go down for more lift. Pitch down with stabilator, flapperons up.
The video shows it that way because of the setup. But if you separate the ailerons to flapperons from the stabilator or especially as a taileron they would work at opposite angles to produce greater lift in the desired direction.
Where they need to work together moving in the same angle, is in a stalled wing attitude. When the wings AoA is extreme near stall and more or less flying on the engine... especially with a single engine, you have less or no roll control because the ailerons any further forward would then be fully stalled and ineffective. To keep them working at that slow speed stalled, many fighter aircraft flip the aileron to a spoiler config to maintain control to capture the turbulent force washing over the wing tips.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Jan 03, 2012, 10:39 PM
stanordave's Avatar
Joined Jan 2006
Thanks Max! The video surprised me w/the setup but the flight was reported good so wasn't too sure.
gracias
Old Jan 25, 2012, 12:10 PM
tnt1106 is offline
Find More Posts by tnt1106
tnt1106's Avatar
Joined Dec 2011
Originally Posted by AJ5000 View Post
Has anyone run a 6s setup? I want to use (2) 3s lipos in series but worried about the CG.
Anyone?
Originally Posted by Donky73 View Post
Hi guys!
I just bought a second hand and still good looking F35 from someone, but forgot to ask what esc he placed in it. Its not the stock one...I find that out somehow.
More importantly; can the motor handle 6s? I have to 3s 4500mah with a total weight of 750 grams. Provided I place them right, can the plane handle the weight and can the motor take the heat?
Thanx in advance..
I am in the process of build this model and have a related above question.
Keeping the flying weight close or at stock weight, what are the advantages to running a 4s set up? Or a 6s set up?
I would like to fly this off either 1 x 4s OR a 2 x 3s packs (I will start with 2200s and go from there.)
Could any of you that are running either a 4s or 6s set up please comment with what fan motor and size ESC you use with success please? Perhaps comment with why you chose that set up?
My goals are ~5 min flight times, near stock weight with much more thrust that stock. ( I plan to make a intake duct and will document it when I get that far.
tim
tnt1106 is offline Find More Posts by tnt1106
Old Jan 25, 2012, 12:27 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
get a DPS ally 68mm edf unit from hobbyking run it at 4s with much more poiwer than stock.. 60 amp esc will be fine
witha 3300mah pack you will have your flying time easy.. not to mention the whooshy sound
pavcon is offline Find More Posts by pavcon
Old Jan 25, 2012, 12:40 PM
High Orbit.....
Joined Jun 2009
You may want to look into the new SU-35 purple 2200kv 6S motor Freewing just released for the SU-35 twin 70mm. That model is 2.7-3kg and with the same FW fan, and some are already saying they are getting 1:1 TWR; only its a twin counter rotating. They are doing well.... very well with a low amp draw. So they got the right motor for the fan. If you AUW is 1.5kg it may be worth looking over.
Old Jan 25, 2012, 09:08 PM
mray is offline
Find More Posts by mray
USA, AZ, Buckeye
Joined Feb 2010
Does anyone recall what the stock AUW was?
Not sure you will achieve your goal with a 6s as that will add more weight.
mray is offline Find More Posts by mray
Old Jan 25, 2012, 10:05 PM
tnt1106 is offline
tnt1106's Avatar
Joined Dec 2011
Stock 5s 2200 battery was reported to weigh in at 306g?
My 3s 2200 packs are 147g each. Should be rather close I am hoping!
Old Jan 25, 2012, 11:50 PM
High Orbit.....
Joined Jun 2009
1.3 kilos AUW. The wing load would increase but the design floats as it is. He'll gain weight reinforcing the wings but can drop weight with a more current 100g 6S outrunner. He's in the ball park as ling as he's not adding any extras.
Old Jan 26, 2012, 12:20 AM
mray is offline
USA, AZ, Buckeye
Joined Feb 2010
Well between my battery and just my motor I am just below 800 grams. I don't think the rest of the plane should come out to 500 grams. I got to get around to weighing it.
Old Jan 26, 2012, 08:55 AM
tnt1106 is offline
tnt1106's Avatar
Joined Dec 2011
Mine should be here tomorrow or Monday. I plan to weigh each component as well as total weight so I can tune and stay very near the 1.3kg with changes I have planned.
Old Jan 26, 2012, 08:57 AM
Ken1.8T is offline
Find More Posts by Ken1.8T
Have glue gun, will travel...
Ken1.8T's Avatar
USA, NY, LONG ISLAND
Joined Mar 2004
Does anyone have pics of the new BH F-35 in the 'Thunderbird' scheme?
Ken1.8T is offline Find More Posts by Ken1.8T
Old Jan 26, 2012, 09:29 AM
JGuilty13 is offline
Find More Posts by JGuilty13
JGuilty13's Avatar
United States, MI, Rochester Hills
Joined Nov 2005
Ken, here is mine. Haven't flown it yet. I plan on using 5s 4000 packs....its a tight fit. And just so you know, the tail cone and cockpit come all white, I just painted mine.
Jordan
JGuilty13 is offline Find More Posts by JGuilty13
Poll which is better nitro planes f-35 or banana hobbies f-35 j3tman Electric Ducted Fan Jet Talk 6 Mar 07, 2011 07:03 PM
Build Log Profile F-35 JSF Mid Motor Pusher with Thrust Vectoring bdelapen Foamies (Scratchbuilt) 54 Oct 19, 2010 09:00 PM
Question The new F-18 from banana hobby j3tman Foamy EDFs 3 Jan 21, 2010 07:31 PM
New Product Hobby lobby new f-35 j3tman Foamy EDFs 1 Oct 12, 2009 04:23 AM
