Old Jun 23, 2011, 12:51 PM
cbrniner is offline
Find More Posts by cbrniner
Joined Jun 2011
Has anyone set this up with a DX8 ??? If so can you list your set up please ..... Trying to get this right so I can fly ..lol
Todd
cbrniner is offline Find More Posts by cbrniner
Old Jul 17, 2011, 12:30 AM
AJ5000 is offline
Find More Posts by AJ5000
Foamy Pilot
AJ5000's Avatar
United States, CA
Joined Jun 2011
Great info in this thread. Has anyone upgraded the the power system? I just purchased the kit version and was thinking about puting in this fan/motor: http://www.epf.com.tw/enshop/goods.php?id=125 Thoughts?
AJ5000 is offline Find More Posts by AJ5000
Old Jul 17, 2011, 12:50 AM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
No one has seen one in action so its hard to say. I'm not expecting that fan to achieve the posted numbers and there are a number of 70mm fans that push even more around the same amp consumption.
There would be no duct issues as there is no duct. the FSA of the intakes may match the 64mm but it may not perform well without a proper inlet duct.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Jul 29, 2011, 02:23 AM
AJ5000 is offline
Foamy Pilot
AJ5000's Avatar
United States, CA
Joined Jun 2011
To those who purchased the air frame kit: What brand/type servos did you use for your build? Links would be great. I was told these were good: http://www.hobbyking.com/hobbyking/s...aft_servo.html
Old Jul 29, 2011, 02:28 AM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
that EDF unit AJ is actually 64mm..
I knwo it produces thrust but you need to have an exit of 55mm to get good performance
pavcon is offline Find More Posts by pavcon
Old Aug 09, 2011, 10:48 AM
Roswalt is offline
Find More Posts by Roswalt
Capt, USAF
Roswalt's Avatar
United States, NV, Las Vegas
Joined Feb 2009
I got mine all put together last night and I've got it squared away with minimal issues. One question though - I want to relocate the battery to behind the canopy and I'm curious to know how the stock setup will work with a 2200mah 5S batt placed in the flat space between the battery/RX box and the cockpit. If it will work, does anything require modification? I've never liked the underside-located battery box thing, and it would be preferable to move this up front.
What's the general concensus on this jet as a whole? Is the new version with servoless retracts good, bad, or in between?
Roswalt is offline Find More Posts by Roswalt
Old Aug 16, 2011, 03:42 AM
AJ5000 is offline
Foamy Pilot
AJ5000's Avatar
United States, CA
Joined Jun 2011
Silly question; does the F-35 have navigation lights? I have an exrta set and would like to use them on one of my planes.
Old Aug 16, 2011, 03:48 AM
pavcon is offline
Joined Jan 2010
no .. it only has one LED on the nosegear
Old Aug 16, 2011, 12:32 PM
High Orbit.....
Joined Jun 2009
likely because the F-35 doesn't really have much in the way of running lights. Wing tips. The probably figured why fish two lights thru a thin wing for something that won't be very visible if done to scale.
Are you going to have the wires on the bottom skin of the wing to run them?
Old Aug 16, 2011, 11:01 PM
AJ5000 is offline
Foamy Pilot
AJ5000's Avatar
United States, CA
Joined Jun 2011
Yes. I think I will put them on anyways. I also plan to re-paint it as well. Maxthrottle, you still flying yours?
Old Aug 16, 2011, 11:31 PM
High Orbit.....
Joined Jun 2009
I haven't finished mine. Mine was a kit build. I've been working on the PakFa T-50 and Euro lately. But for this one I've been adding scale; minus the lights. There is the duct that I've been fabricating and I've been waiting for a good light rotating gear and PZ just came out with a set so it will have the dual doors for the retracts with a RCBee sequencer.
Wing tube, LE flaps still have to be actuated. The Ordnance bays holds the batteries but are being reshaped externally to take the JDAM and AMRAAMs.
Clean up and top hinge the tailerons
So no no flights yet.
Old Aug 16, 2011, 11:49 PM
AJ5000 is offline
Foamy Pilot
AJ5000's Avatar
United States, CA
Joined Jun 2011
Wow, sounds like a serious build! Cant wait for the pics.
Old Aug 16, 2011, 11:53 PM
High Orbit.....
Joined Jun 2009
have you got a colour match done yet? if so what the formula?
Old Aug 17, 2011, 12:11 AM
AJ5000 is offline
Foamy Pilot
AJ5000's Avatar
United States, CA
Joined Jun 2011
I have not got that far yet, but this is the color and decals I am going to go with...
Old Aug 17, 2011, 12:20 AM
High Orbit.....
Joined Jun 2009
If you want to add lighting you could do LO lighting for the Rudder and intake lips. They went with green instead of the usual yellow. I think they make the light strips for models.
Ya I was going with the same tone but I may add a picture overlay in the lighter gray .... will see.
Poll which is better nitro planes f-35 or banana hobbies f-35 j3tman Electric Ducted Fan Jet Talk 6 Mar 07, 2011 07:03 PM
Build Log Profile F-35 JSF Mid Motor Pusher with Thrust Vectoring bdelapen Foamies (Scratchbuilt) 54 Oct 19, 2010 09:00 PM
Question The new F-18 from banana hobby j3tman Foamy EDFs 3 Jan 21, 2010 07:31 PM
New Product Hobby lobby new f-35 j3tman Foamy EDFs 1 Oct 12, 2009 04:23 AM
