Old Feb 16, 2011, 01:36 PM
Maxthrottle is offline
Find More Posts by Maxthrottle
You are a "go" for reentry
Maxthrottle's Avatar
High Orbit.....
Joined Jun 2009
The bay is 40mm wide X 62mm tall. So anything below that.... you could widen it even more if you wanted. Too much battery and one has already commented it becomes a little more nose heavy.
Maxthrottle is offline Find More Posts by Maxthrottle
Old Feb 21, 2011, 11:27 AM
BLOWZILLA is offline
Find More Posts by BLOWZILLA
get high
charlotte, nc
Joined Feb 2011
Mine is coming tuesday, along with my EF2000 from HL. HL got me w/ that 299 sale. Im not sure which to build first. This is my 2nd F-35 and i just love them. Weather is looking great next weekend too.
BLOWZILLA is offline Find More Posts by BLOWZILLA
Old Feb 22, 2011, 04:30 PM
get high
charlotte, nc
Joined Feb 2011
How is easy is it to slo speed high alpha this jet?? This is my first TV jet, so i will be experimenting alot. Any good TV videos out there?
Old Feb 22, 2011, 05:12 PM
pavcon is offline
Find More Posts by pavcon
Κύπρος, Λευκωσία, Πέρα Χωριό
Joined Jan 2010
how difficult is for s1 to post a vid?
pavcon is offline Find More Posts by pavcon
Old Feb 23, 2011, 05:43 PM
get high
charlotte, nc
Joined Feb 2011
Hey guys, got my F-35 and have some problems. 1. left main gear is jammed, no compression. 2. bomb bay doors seem warped, almost bent. will not lay flat. Anybody else? What is the trick to tacking apart the lg w/o breaking it? I need to do the spring mod. Both my intackes were crumpled also
Old Feb 23, 2011, 10:28 PM
High Orbit.....
Joined Jun 2009
Post 341 2 pages back shows the lg. If the intakes are crumpled send it back. Who did you order it from. Or is it minor.
Warped doors etc is an easy fix. Either low heat iron it from the back side or lay it flat and add a thin layer of epoxy on the inside. See what the vendor can do though.
Old Feb 24, 2011, 04:55 PM
get high
charlotte, nc
Joined Feb 2011
I got it from banana, and the intakes are just crumpled in alittle. Still it just looks bad, tried to pull them straight but its still creased. will check that post about the gear, thanks. Hey Maxx, ive never set up a TV jet b4 and im using a dx7. Can you point me in the right direction for programing and rx pin placement.
Old Feb 24, 2011, 05:01 PM
get high
charlotte, nc
Joined Feb 2011
Originally Posted by ShockWave View Post
Hey Guys,
I have solved the leap off the ground take offs that we are all experiencing; I did two flights today and I am very happy with the results.
Here are the steps that have worked out great for two of our F-35's; you should be able to finish this mod in under an hour.
  • Carefully remove one of the scissor pins on one of the main gear " these can break easily but you can use a small bolt and nut if this happens"; this will allow you to pull out the lower end of the strut and set aside.
  • Take a small screw driver or similar tool and gently work the spring out. You might want to have the model right side up so you have gravity helping you. If this does not work take a paper clip and bend a very small hook at one end; use this to grab the spring and pull out of the upper part of the strut.
  • Cut 1/2 inch off of the spring; on the larger of the two spring halves bend the cut end up slightly so that it does not gouge out the upper strut when compressed.
  • Reassemble the strut "if you have the standard Servo activated gear you might want to use the servo slow feature on your transmitter so you don't strip one of the servo gears" if you have the servoless retract gear don't need to worry about anything. Now retract the gear; notice that the scissor now hits the side of the fuse; mark this spot or press the strut down slightly just enough to leave an imprint in the foam. Use a dremel to grind out a channel so that the gear close fully without binding.
  • More than likely you will need readjust the spectra string so that the gear doors will close better. I used a bit of fishing line on my doors and it works reasonably well.
The results is that you should now have the mains about 1/2 shorter that will give enough positive incidence to allow for smooth takeoffs. I am attaching pictures and video now.
Video Link: recorded with my iphone
http://www.youtube.com/watch?v=tIXS9msTSyI
I hope this mod works well for you guys as it did on our F-35's.
Take it easy.
David.
Hey Shockwave, Those pins on the gear are really tight and im scared to snap 1 off. Are you just prying the pin apart or what? Dont feel like breaking it.
Old Feb 24, 2011, 10:51 PM
takiss is offline
Find More Posts by takiss
Patras, Greece
Joined May 2007
Hi.
If you will take them off, you will brake most of them. But its an easy replacement with metal nuts ant bolts.
takiss is offline Find More Posts by takiss
Old Feb 28, 2011, 05:02 PM
get high
charlotte, nc
Joined Feb 2011
OK, I'll try to be carefull w/ it. Not sure why its jammed, but ill soon find out. Thanks guys.
Old May 21, 2011, 12:58 AM
capt soap is offline
Find More Posts by capt soap
capt soap's Avatar
dallas tx
Joined Jun 2003
Anybody own the bh, and hL f-35 both... give some comparisons please.
capt soap is offline Find More Posts by capt soap
Old May 23, 2011, 11:02 AM
High Orbit.....
Joined Jun 2009
The LX has a much better/accurate external scale appearance but lacks a proper duct. The gear is better with the exception of running off rough grass from smaller wheels.
The FW is a little smaller but gets better performance from its EDF because it has a smooth duct and a better TV or thrust vectoring unit. This allows it a smaller drive train setup to perform very well for its weight.
Both do not appear to fly much differently and I would guess only vary depending on what they are equipped with.
Old Jun 22, 2011, 10:33 PM
cbrniner is offline
Find More Posts by cbrniner
Joined Jun 2011
Just getting this one going ...could someone tell me , is this ment to run on elevons ???? I know its wired this way , but is it better ele / ail separate .... Please gimmie your input ...I am using DX8
Thanks Todd in Vegas
cbrniner is offline Find More Posts by cbrniner
Old Jun 23, 2011, 12:04 AM
High Orbit.....
Joined Jun 2009
you can do either but with a DX8 you have options.
Firstly they wire this that the tailerons are slaved to the ailerons (the F35 doesn't have elevons). But this config mean when you pitch up the ailerons become spoilerons reducing lift and pitch down and they become flaps. Not the best way.
The wiring can be changed to allow this to work per design having the tailerons work independently for pitch and roll and the ailerons as ailerons and flapperons for roll and lift.
There is a vid posted in this thread I believe.... or in the other thread that showed the improved landing characteristic of having flapperons and tailerons.
On the DX8 the taileron mix is elevon or on JR Delta. You'll need to sort out your channel choices to make certain flap mixes don't get applied to the tailerons.
We've posted a few comments on this so you can look back at additional details.
Old Jun 23, 2011, 01:12 AM
cbrniner is offline
Joined Jun 2011
So set the wing type to elevon on the DX8 ?? wouldnt that make the aileron also work with the elevator as well ??? Is there a step by step on this radio to set up for this plane ??? I do appreciate your help - just trying to figure out the right setup for this radio ....and yes I think i would want to set up flaps as well
Thanks in Advance
Poll which is better nitro planes f-35 or banana hobbies f-35 j3tman Electric Ducted Fan Jet Talk 6 Mar 07, 2011 07:03 PM
Build Log Profile F-35 JSF Mid Motor Pusher with Thrust Vectoring bdelapen Foamies (Scratchbuilt) 54 Oct 19, 2010 09:00 PM
Question The new F-18 from banana hobby j3tman Foamy EDFs 3 Jan 21, 2010 07:31 PM
New Product Hobby lobby new f-35 j3tman Foamy EDFs 1 Oct 12, 2009 04:23 AM
