Old Oct 27, 2009, 09:33 PM
power is offline
Find More Posts by power
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Build Log
Yet another AP platform..."DOUBLE EXPOSURE"
Well, after a long thought process I decided to tackle the issue of prop clearance, it occured to me that if we split the wattage/weight of the larger motors and move two motors off the center of the plane. This would allow for all kinds of options for camera mounting This platform uses two AXI 2212-34 motors. I tried to equal the power of the Passive with the AXI 2814-20. I was a bit skeptical that two 10 amp motors could give me the thrust I needed but I was pleasantly surprised! Great power light weight and super cool sound.
The other interesting thing I discovered is that by mounting the motors in the wing, this seems to isolate the vibration from the fuse. I mounted up a Canon HF-100 with nasty sensitive OIS and I did not see any vibes until over 3/4 throttle. On my other birds I saw vibration immediately. This I will be testing further.
The Maiden flight had a 7 oz ballast using the forward dowel location and forward pack location. The second flight had the 17oz Samsung onboard and the pack at the rear location. This thing can probably be setup to fly a 4 oz camera with out adding non functional weight
I designed the front slope at 15 deg so the small Flip style camcorders can be rubberbanded to the fuse by using the wing dowels. This works very slick. I have been testing the new Kodak Zi8 lately and I must say I am impressed. I have been comparing 1080p clips with my big Samsung and honestly the little $150.00 Kodak is doing quite well. I have not had a chance to fly the Kodak yet. I have had the plane up and it is a joy to fly. I have a maiden video coming soon. I did fly the Big Samsung HMX-20 on the same day but the wind was pretty bouncy and the footage is not worthy of watching. Anyway... here are some specs and pics of my latest project.
WS: 80 in
Fuse: 2" beaded foam with 2" 1/64 ply spine down the entire bottom.
AUW without camera 37.9 oz
(2) AXI 2212-34's
(2) PH-25 ESC
Lipo: TP 3s 1350 v2
Note: twins are very reliable, they do need a few special needs. Quality ESC's as matched as possible. CC has a PDF that gives the settings. They are very straight forward and work extremely well. Quality motors are also reccommended as the higher end motors tend to have closely matched kv ratings.
Thoughts...
(Maiden Video) : http://whispershots.smugmug.com/Aeri...6_J5KQA/Medium
power is offline Find More Posts by power
Old Oct 27, 2009, 09:36 PM
power is offline
power's Avatar
Joined Apr 2003
Here is a teaser until I get the video up...
I really like this shot.
Old Oct 27, 2009, 09:56 PM
Vintauri is offline
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
Very cool Mike. Have you been up to the new school they are building on the south east side of town? It would be cool to see some shots of that as they work on it.
Steve
Vintauri is offline Find More Posts by Vintauri
Old Oct 27, 2009, 10:18 PM
frogman1206 is offline
Find More Posts by frogman1206
Frogman
Stoughton, WI
Joined Jun 2009
Dang the ideas running around in that head of yours are amazing. Another work of art. I bet the 2 motors sound cool. Good part is if one motor dies the other should give you enough to get home....right. Are you going to test by stopping a motor in mid flight. That way you know it is a fail safe. Of course you wait till you've flown it awhile right.
frogman1206 is offline Find More Posts by frogman1206
Old Oct 27, 2009, 10:26 PM
nocontrol1 is offline
Find More Posts by nocontrol1
Joined Mar 2007
Nice Mike! Its been really cool to see the design evolution since the "Beast". This looks like a winner.
Rob D.
nocontrol1 is offline Find More Posts by nocontrol1
Old Oct 27, 2009, 10:51 PM
cdi3d is offline
Find More Posts by cdi3d
Brushless
cdi3d's Avatar
Joined Mar 2009
This is so cool - Great job Mike! I really need Hobby Lobby to have a sale on AXI motors!!!!!!!!!
cdi3d is offline Find More Posts by cdi3d
Old Oct 28, 2009, 12:04 AM
Alpina540 is offline
Find More Posts by Alpina540
Fly Big, Low and Slow....
Alpina540's Avatar
USA, VA, Wicomico
Joined Aug 2008
Awesome work! I like the twin motors but I dislike the added cost.
How much shorter(vertically) is the fuse compared to say the Solution that has to be taller to clear the lens of the camera?
Do the motors make a loud resonating sound mounted in the wing?
Looks very sharp!
-Anson
Alpina540 is offline Find More Posts by Alpina540
Old Oct 28, 2009, 12:42 AM
soft2 is offline
Find More Posts by soft2
Vermont
Joined Apr 2007
What is the purpose of all those holes in the fuse? Weight reduction? Handy places to put things like batteries, rx, etc. providing mulitple options for balancing? All of the above? I think the extra wind drag that those holes create will far outweigh any benefits from weight redux.
Remind me again why you don't like pusher setups? Everybody I know who is using dual motors also has ailerons which helps in case of one motor/esc failure.
Just my .02 - worth about what you paid for it!
Good luck with your newest design...
soft2 is offline Find More Posts by soft2
Old Oct 28, 2009, 05:33 AM
Lomcevac is offline
Find More Posts by Lomcevac
Worn-out the seat of my pants
Lomcevac's Avatar
Dorset UK
Joined Dec 2006
Ooh that should spark a debate! Yaw is your enemy in an asymmetric situation, not roll. Sure you also experience roll but only as the secondary effect of yaw.
Lovely work Mike
Lomcevac is offline Find More Posts by Lomcevac
Old Oct 28, 2009, 06:42 AM
Joined Mar 2007
Soft- Mike's designs are intended to fly slooow. Drag from the holes is either negligible or maybe even desired!
Rob D.
Old Oct 28, 2009, 07:25 AM
cvandenb is offline
Find More Posts by cvandenb
cvandenb's Avatar
Manchester
Joined Jul 2008
Awesome Mike !! What an amazing looking plane !! Just brilliant.
Gonna have to build one of these !
Great Work !
cvandenb is offline Find More Posts by cvandenb
Old Oct 28, 2009, 07:36 AM
BOILER1 is offline
Find More Posts by BOILER1
Indianapolis
Joined Aug 2005
Awesome design. I like the idea of the vibration absorbed my the wings.
I may have to buy another wing for my UL and mount twins on it.
BOILER1 is offline Find More Posts by BOILER1
Old Oct 28, 2009, 09:17 AM
power is offline
power's Avatar
Joined Apr 2003
Thanks for the comments guys
soft2,
The reason for the holes is in fact everything you stated. Mostly weight. You would be surprised as to how much weight is reduced with the holes. This becomes very effective at the tail when C.G. is the topic. I am a bit radical about keeping my planes light as well as strong. This one covers both. The 2" beaded foam is extremely stiff with the ply spine.
I do not like pushers for two reasons. One is that it requires longer motor leads adding unwanted weight and obtaining C.G. is always a pain. They also create a ton of noise as most applications the prop has to bite dead air from the fuse or other parts of the aircraft. This reduces efficiency.
nocontrol1, pretty much nailed it on the drag. With "typical" airframes we are concerned with reducing drag for flight. With AP platforms if you can get good flight characteristics while adding drag this is a win win. I like slow flight and this plane does this well....
Wait and watch the video and you will see what I mean, it is a pussycat with plenty of power. it also can cruise at less than 1/3 throttle with the wing loading this low.
Old Oct 28, 2009, 09:24 AM
quailbird is offline
Find More Posts by quailbird
quailbird's Avatar
Rich Hill Missouri 64779
Joined Nov 2003
Great job Mike! Looking forward to seeing the video! You always do such nice work!
quailbird is offline Find More Posts by quailbird
Old Oct 28, 2009, 09:25 AM
ekees is offline
Find More Posts by ekees
ekees's Avatar
Medford, Oregon
Joined Jan 2009
Sweet design Mike. I like the inclusion of the Flip style camcorder mount. I have a Kodak Zi6. It takes great video (60fps 720p) for an $80 referb camera. Can you turn off the IS on the Zi8?
Where does this design fit in your fleet? Could you please give as a brief description of your top 5 or 6 planes? e.g. Design goals, flight characteristics, overall pro and con of each design.
ekees is offline Find More Posts by ekees
Discussion Another AP platform? California Condor Aerial Photography 3 Apr 13, 2008 12:49 PM
Discussion Yet another AP jbeckett Foamies (Kits) 0 Jul 24, 2006 05:30 AM
Yet Another AP UAV... JeffreyB Aerial Photography 4 Mar 14, 2005 01:07 AM
Polly Pusher, another AP Platform Radiofly Aerial Photography 2 Sep 24, 2004 08:15 AM
Yet another AP from a Slow Stick cfischer505 Aerial Photography 1 Dec 26, 2003 02:44 PM
