Old Oct 27, 2009, 03:28 PM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Build Log
Radian FPV Build. Pic Heavy and FPV Videos
This is my first real post and my first real veture into the world of FPV flight. While looking in to fpv flight I was set in using the EasyStar because of it success. Being a nitro guy I went to the LHS in search of a EasyStar to start my venture into eletric flight. Well they didn't have the EasyStar in the shop but the owner would not stop going on about his Radian. After walking out the door I thought to myself, ehh what the hell. I bought the PnP version of the Radian. I'm glad I did. This thing is stable and flies for ever. Third flight... 30 sec motor 50 mins of flight. So I was sitting around the other day reading the forums and decieded to start my FPV flying with the Radian. There is not much FPV flying with the Radian so I thought I'd start a thread on my build. I still don't have most of the parts so it will be updated as the parts come.
I will be flying with this.
TX : Futaba 9z
RX : Hitec Mini 6s 72mhz (for now)
Pan servo : HS-85BB
Tilt servo : Tiny servo off a Walkera heli (Don't know the name but I think it
handle the job)
R/E servo : Parkzone PKZ1060
ESC : E-Flight 30 amp
Battery : Parkzone 3s 2200mah
I will use the ESC to power the RX and servos. Hope fully it doesn't shut down. I dout it will because 2 more servos should not affect that much hopefully. Tests will prove otherwise.
This is what I want along with the price and order I will get get them:
Other - kx131 ($83.00)
dpcav - 900MHz Pro-series TX 500mW ($129.95)
RV - 900MHz video RX x2 ($50.00 each) ($100.00)
dpcav - Oracle Video Diversity Controller ($159.95)
RMR* - TrackR2 Headteacker ($159.95)
Other - Antenna/Batteries/Etc/shippping +/-($300.00)
RV - Video google ($275.00)
RV - RVOSD ($335.00)
RMR* - RC UHF LRS ($349.95)
Total $1892
That can't be right!!!
Ofcoarse this is a build up. So it will be spread out thank god.
So here are some pictures of the start.
man2000me is offline Find More Posts by man2000me
Old Oct 27, 2009, 05:56 PM
Capy-Norway is offline
Find More Posts by Capy-Norway
Capy-Norway's Avatar
Norge
Joined Feb 2009
You need to change the esc. I have one fpv crash with the radian and that was because the esc shut down. Now I'm using the 40amp pro. Works great!
Capy-Norway is offline Find More Posts by Capy-Norway
Old Oct 27, 2009, 06:16 PM
IL76MD is offline
Find More Posts by IL76MD
fly it high as possible
Falls Church, VA
Joined Jun 2009
I'm one more for it - to replace to 40A and, probably, use separated BEC. Your bird is going to be more heavy and motor would overheat ESC and as a bad result overheat initial BEC and as result to failure RX.
Cheers.
IL76MD is offline Find More Posts by IL76MD
Old Oct 27, 2009, 07:08 PM
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Is there light weight 40 amp ESC you can recommend that will power the RX with the servos. I plan to run everything including the vTX, rc rx and camera off one battery. I know it is not recomended but I'm stubborn. Haha
Old Oct 28, 2009, 08:03 PM
IL76MD is offline
Falls Church, VA
Joined Jun 2009
Some time ago (last year) I bought 40A ESC from this site
http://www.headsuprc.com/servlet/the...ushless/Detail
very fast delivery and you can buy anything else for same price $2 delivery.
As you see my pic that ESC (40A) fits very well.
And one more pic with Co-Pilot and camera
Today was very windy and gusting, Radian just danced on sky.
Cheers.
Old Oct 28, 2009, 09:33 PM
rc_ron is offline
Find More Posts by rc_ron
shawnee, ks
Joined Apr 2004
hey man,
i'm using a radian for fpv. i love the plane -- flies great, easily to repair, enough room for equipment, and overall not too expensive.
glad to know about the esc. i'm still using the stock one without trouble so far but may upgrade given the responses.
couple recommendations for the radian:
1. i'd place some clear packing tape along the leading edge of the wings. i love the z-foam but it does have a tendency to flake off in chunks with wear and tear
2. i mounted my video transmitter on the bottom of the tail boom. for people interested in doing this, the tape along the bottom covers a thin piece of fiberglass that is about 1/4" deep and runs the length of the tail boom. be careful not to cut this since it will greatly weaken an already flimsy tail.
3. dont rely on the stock magnets alone to hold the canopy on with the camera mounted to it.
4. consider running some strips of packing tape along the inside of the wing insertion slots on the top. this part of the fuselage is very thin and with one of my crashes it cracked in half over the wings. the tape will help distribute the force.
5. others have suggested replacing the stock control horn linkages with dubro ez-connectors.
6. after a few crashes, the wings were getting a little loose. i dont think they would come off but just in case i put some velco on each side.
here are pics of my ship -- "nemo"
http://www.rcgroups.com/forums/showp...postcount=1159
rc_ron is offline Find More Posts by rc_ron
Old Oct 29, 2009, 10:20 AM
IL76MD is offline
Falls Church, VA
Joined Jun 2009
Originally Posted by rc_ron View Post
hey man,
Thanks for information and, even more, i replaced stock wings joiner by stronger joiner from EG. Somebody already had it broken on flight.
Cheers.
Old Oct 29, 2009, 07:18 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Nice build. Have you flown this model yet? How does it do? Are you using a separate battery for video feed?
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 29, 2009, 10:16 PM
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
I have flown it just as you see it to see how the extra wieght (so far) would affect it. I added no extra weight to fix the C.O.G. i just moved the battery further back. I don't even notice the extra wieght of the servo. just have to add on the tilt servo, cam, and transmitter. 92 grams +/- 10 grams. more of weight. (2 standard servos and one hs-85)
Old Oct 29, 2009, 10:53 PM
rc_ron is offline
shawnee, ks
Joined Apr 2004
i'm using an extra 800ma 2cell which is probably overkill and i do notice a difference with the added weight. stock the plane just floats and i can easily get 20 minutes or more a flight. with the fpv equipment i use the motor more and have to work a little harder to keep it up.
Old Oct 30, 2009, 01:25 AM
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
I'm adding one component at a time and still flying it. So far with one mini servo there is not much of a change in wieght. So I would not expect the flight to be much different. I am using the 3s 2200 battery instead of the smaller lighter one. I plan on using one battery. I 've been following the one battery thread and that has helped with all of planning. From what I understand the video gear does not take much to run. I expect running the gear off one battery and thermals will give me 1 hr of flight on a good day but maybe 30min on a bad day. That is enough time for me.
Old Nov 05, 2009, 06:00 AM
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Does anyone know the current draw in mah for:
Hitec Mini 6s
2 parkzone 1080 servos
1 HS-85bb
1 walkera 7.6-2
The E-Flight says it would run 5 analog servos no problemin the manual.
The servos listed are all analog and either mirco or sub micro.
With what you guys are telling me I'm doubting the E-Flight pro 30amp.
Also when they put the radian pack together I'm assuming they were expecting a 2.4 rx be used. The 2.4 supposedly draws more power then a 72mhz rx. If the esc bec were to fail would it power back up once cooled down?
Old Nov 05, 2009, 06:11 AM
yellowcolorado is offline
Find More Posts by yellowcolorado
United States, LA, Metairie
Joined Feb 2009
Don't chance the plane losing connection when an External BEC is like 10 bucks.
yellowcolorado is offline Find More Posts by yellowcolorado
Old Nov 05, 2009, 08:45 PM
Vantasstic is offline
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Okay, I must admit...I'm astounded that a switcher BEC is only rated at .7A. Then again...it is listed to handle 5 analog servos (which can be well over the .7A limit. I going to guess the switcher can handle the load of the added servos.?.? I've used Dimension Engineering and Castle Creation BECs. They're more than $10, but have never let me down.
Vantasstic is offline Find More Posts by Vantasstic
Old Nov 05, 2009, 11:07 PM
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
Since we are on the subject of ubec... will a ubec run a 5v cam filtered from a 11.4 lipo with no interference?
Build Log Multiplex Fox FPV Build chancesAU FPV Talk 385 Jun 26, 2010 06:51 AM
Discussion FPV Build Log tr6world FPV Talk 4 May 31, 2009 06:36 PM
Discussion Wing Dragon for FPV - FPV Build Log IanJ FPV Talk 10 Jan 03, 2009 08:40 PM
Discussion Ritewing TL 60 FPV Build pandauric FPV Talk 14 Dec 08, 2008 08:13 PM
Discussion FPV Build reccomondations... MonsterMaxx FPV Talk 10 Sep 12, 2008 10:48 AM
