Go Back   RC Groups > Boats > Submarines
Old Oct 26, 2009, 09:41 PM   #1
jaguar75's Avatar
Radios
What are the pros/cons of the Robbe/Futaba Navy-14 radio ?
jaguar75 is offline Find More Posts by jaguar75   Reply With Quote
Old Oct 27, 2009, 08:12 AM   #2
"What are the pros/cons of the Robbe/Futaba Navy-14 radio ?"
What does the answer below have to do with the question above?
"SL PRODUCT REVIEW
http://www.rcgroups.com/forums/show...t=912056&page=4"
Skip Asay
Skip Asay is offline Find More Posts by Skip Asay   Reply With Quote
Old Oct 27, 2009, 10:42 AM   #3
A BIG con would be the cost of the system, very expensive compared to the 2.4 Ghz systems now for the same money, however a Pro would have to be how expandable the system can be, i recently purchased one and also a 8 prop expander and it has way more than i need..
Also i have the twin stick set-up for use with a 4 screw 6' battleship
I also like the fact that it's not too complicated and no computer readout
RussCA is offline Find More Posts by RussCA   Reply With Quote
Old Oct 27, 2009, 11:26 AM   #4
jaguar75's Avatar
Thread
"SL PRODUCT REVIEW
Skip Asay
Thread no longer exists.
Old Oct 27, 2009, 11:27 AM   #5
Since John asked the question in the r/c sub forum, we should assume that a comparison to 2.4GHz systems isn't valid since they cannot be used in this application.
-Jeff
JWLaRue is offline Find More Posts by JWLaRue   Reply With Quote
Old Oct 27, 2009, 11:42 AM   #6
Actually, it does. For some reason, my post was moved to this thread but it refers to a post in the "Sombra Labs SL-8 Radio Receiver" thread.
Skip Asay
Old Oct 27, 2009, 01:53 PM   #7
Shrug...
Bill Harris's Avatar
The Moderationator moved these first two posts from the earlier Sombra thread. Think of the old game of musical chairs...
My experience with aircraft is to get as much radio as you can afford. I started with a 4-channel non-computer radio andwent to a 6ch 'puter radio and then an 8 channel. A "computer radio" is great because it has multi-model memory, it can mix channels very exactly, and it will set the servo travel, the servo endpoints and the servo control "feel" for each channel.
I am having one of my JR 8103 aircraft radios converted over to 75 mHz (or rather, the exchangable RF module).
Quickie question about channel assignments an marine radios, surface and submarine boats. I am used to the left stick controlling throttle and "yaw" (aircraft rudder), and the right stick controlling pitch (elevator) and roll (ailerons, 'turns'). How are the channels assigned with boats?
--Bill
Bill Harris is offline Find More Posts by Bill Harris   Reply With Quote
Old Oct 27, 2009, 02:31 PM   #8
KC8WPF
Generally on subs, the left stick controls throttle and ballast tank, the right stick controls rudder and dive planes.
Depending on the surface runner, rudder is usually on the right stick and throttle on the left. However some guys run multi drive motors and will use the left stick for the port motor and the right stick for the starboard motor.
Here's the setup for my model of USCGC TAMAROA: left stick up/down = throttle; left stick left/right moves fire monitor left/right; right stick left/right = rudder; right stick up = fire pump on; right stick down = horn. I use a slightly different set up for a German S-boat (E-bopat or PT): left stick up/dopwn = center motor; right stick up/down = port & starboard motors; right stick left/right = rudder.
CG Bob is offline Find More Posts by CG Bob   Reply With Quote
Old Oct 27, 2009, 06:20 PM   #9
Shrug...
Good, then it won't be anything too different from what I'm used to.
--Bill
Old Oct 27, 2009, 09:44 PM   #10
jim
Send a message via AIM to spongjim Send a message via Yahoo to spongjim
Bill where are you in Al?
Jim
spongjim is offline Find More Posts by spongjim   Reply With Quote
Old Oct 28, 2009, 10:06 AM   #11
Shrug...
I'm near Jasper, Jim. Been following your "Central Alabama Ships and Subs" group, planning to contact you when I finish my boat. Y'all still float at Lake Purdy?
--Bill
Old Oct 28, 2009, 04:55 PM   #12
Pro's are the tray format which suits boats and subs as it makes playing the switches very easy. Expandable with more functions than you'll ever need.
Con are price, and its a non computer set. Get the FC16 instead.
HelloMoto is offline Find More Posts by HelloMoto   Reply With Quote
Bored? Want to fight?
Join the RCGroups clan!
