Old Oct 26, 2009, 06:21 PM
Miami Mike is offline
Find More Posts by Miami Mike
Pompano Hill Flyers
Miami Mike's Avatar
Miami Lakes, Florida, USA
Joined Mar 2003
Mini-HowTo
Sailplane Stand made from a Home Depot Ridgid Flip Top Work Support
This $29.97 Ridgid Flip Top Portable Work Support from Home Depot makes a great sailplane stand for assembly at the field.
I got the idea yesterday while reading this thread, started by jonesjj, and it didn't take very long to put it together. I used two blocks of foam wrapped in duct tape and a couple of short bungee cords. There's a detailed summary of how I built it on my website.
Here are a few pictures:
Miami Mike is offline Find More Posts by Miami Mike
Old Oct 26, 2009, 06:46 PM
jaizon is offline
Find More Posts by jaizon
WINS - Winch In Nose Sailplane
jaizon's Avatar
USA, NH
Joined Mar 2008
Sorry, Mike. It just doesn't look very stable, especially on anything but dead level ground. Big plane, slight breeze and over it goes. Needs a much wider base for the legs, like a tripod.
jaizon is offline Find More Posts by jaizon
Old Oct 26, 2009, 08:16 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
It's extremely stable. Even off balance with only one wingtip installed, it's rock solid. The stand is made of strong steel and is fairly heavy.
And even if there's a stability problem from a very strong wind, the stand can be easily lowered to compensate. The center shaft could even be pushed into the ground.
Remember, the main purpose of the stand is to assemble the plane. If you're really worried about stability, which is unlikely once you've tested it, you can always set the plane on the ground before you walk away from it.
Old Oct 26, 2009, 08:57 PM
AndyTheLegend is offline
Find More Posts by AndyTheLegend
Thermals?!
AndyTheLegend's Avatar
Plantation, FL
Joined Apr 2008
Awesome Mike.
Andy
AndyTheLegend is offline Find More Posts by AndyTheLegend
Old Oct 26, 2009, 09:10 PM
Rairwalk is offline
Find More Posts by Rairwalk
Flyer
Rairwalk's Avatar
United States, FL, Lakeland
Joined Nov 2008
Handy tool Mike. Good job.
Rick
Rairwalk is offline Find More Posts by Rairwalk
Old Oct 26, 2009, 10:44 PM
yyz is offline
yyz
Find More Posts by yyz
yyz
yyz's Avatar
USA, CA, Paso Robles
Joined Dec 2004
Nice job. Not that different than this one:
http://www.letmodel.cz/nahled-models.php?name=flash.jpg
and your base looks wider. Guaranteed to be more than $29.95 US
yyz is offline Find More Posts by yyz
Old Oct 27, 2009, 07:22 AM
BrianSmith is offline
Find More Posts by BrianSmith
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
neat!!
Great idea Mike.. Thanks for sharing it... Brian
BrianSmith is offline Find More Posts by BrianSmith
Old Oct 27, 2009, 07:52 AM
dephela is online now
Find More Posts by dephela
What's wrong with heavy?
dephela's Avatar
USA, CT, Hamden
Joined Oct 2002
I tried stands. Laying parts out on the ground still works best for me.
dephela is online now Find More Posts by dephela
Old Oct 28, 2009, 07:39 AM
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
HUh??
Well Hooray for you... Brian
Old Dec 06, 2009, 10:47 PM
Kaw1000 is offline
Find More Posts by Kaw1000
They call me Crash!
Kaw1000's Avatar
Ohio
Joined Jun 2006
hey Mike!
Just wanted you to know that I bought one of these...works great...built it just the way you did. Thanks for tip!
Kaw1000 is offline Find More Posts by Kaw1000
Old Dec 07, 2009, 07:26 AM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
You're welcome!
A few folks commented about it at the Tangerine contest in Orlando the weekend before last.
Old Dec 07, 2009, 07:28 AM
<>< AKA W4BPS
USA, TN, Tullahoma
Joined Dec 2001
neat stand
Mike had this at the Tangerine. Really a neat set up.. The model sits at a little bit of a downward angle and it sits in the wind with no problems. Nice for sure!! Brian
Old Dec 08, 2009, 06:09 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Great idea. Thanks for posting it here.
aeajr is offline Find More Posts by aeajr
Old May 23, 2010, 11:26 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
The stand seems to be catching on. Jody Miller of the Orlando Buzzards came up with a couple of improvements.
One is to use wider foam blocks and a smaller gap between them to help keep your fuselage from twisting in the wind. You can see his stand in this picture, linked from this thread:
The other improvement of his, which you can barely see in the picture, is to drill through the two bottom horizontal portions of the legs near the center and add eye-bolts, through which he can drive stakes into the ground. Although the stand is extremely stable even without the stakes, this removes all worry that it's going to blow over.
I've also come up with a latch for my stand that attaches to the tow hook, removing the need to wrap a bungee cord around the fuselage.
Old Jun 14, 2010, 07:26 PM
Pompano Hill Flyers
Miami Mike's Avatar
Joined Mar 2003
A local fellow named Willy came up with a really fancy version of the Ridgid Work Support Sailplane Stand:
It swivels and locks into place facing different directions, can spread apart for different size fuselages, and even has a drawer to store a few tools. Here are some more pictures.
Discussion Question about Pink foam sheets from Home Depot SteveC68 The Builders Workshop 17 Nov 27, 2011 08:54 AM
Help! insulfoam from home depot ant141110 Foamies (Scratchbuilt) 1 Feb 22, 2009 08:28 PM
Discussion Lithium Battery Packs For Ryobi From Home Depot Rickochet Batteries and Chargers 3 Dec 06, 2008 05:15 AM
Discussion next noob ? - which foam to buy from lowes/home depot pairadocs Foamies (Scratchbuilt) 11 Sep 12, 2007 07:28 AM
