Old Apr 27, 2003, 10:48 PM
ColdBlood is offline
Find More Posts by ColdBlood
Hilo, Hawaii
Joined Jan 2003
Hawaiian TM! or Menehune Magic!
After crashing my beloved tm into the roof one day, this is the results of the rebuild. By the way, a menehune is the Hawaiian equivilant of a dwarf or pixie!
ColdBlood is offline Find More Posts by ColdBlood
Old Apr 27, 2003, 10:50 PM
Hilo, Hawaii
Joined Jan 2003
UC has a spring loaded main struts (spring taken from a disposable lighter).
Old Apr 27, 2003, 10:52 PM
Hilo, Hawaii
Joined Jan 2003
A scale look steerable tailwheel was definitely called for.
Old Apr 27, 2003, 10:54 PM
Hilo, Hawaii
Joined Jan 2003
To enhance the scale appearance a corrogated wing tank was built out of 3mm and 1mm Depron. Corrogations were made by thinning and rounding the edge of a popsicle stick and grooving the 1mm depron.
Old Apr 27, 2003, 10:57 PM
Hilo, Hawaii
Joined Jan 2003
Flying wires were made out of nylon carpet thread instead of dental floss. Rod is a scrap piece of CF rod.
harryo is offline
Find More Posts by harryo
Mmmm... crunchy balsa.
harryo's Avatar
United States, CA, Oakland
Joined Sep 2002
Okay ColdBlood...
Of all the TM threads I've seen in this forum, Your's is definitely one of the tops! The landing gear is outstanding! All of the other scale details... superb!
OKAY You just added riggin pictures when I was writing this!!! WOW!!!
- Harry
harryo is offline Find More Posts by harryo
Old Apr 27, 2003, 10:59 PM
Hilo, Hawaii
Joined Jan 2003
I decided to go to a scale pull pull system. Again, the cables are nylon thread.
Old Apr 27, 2003, 11:02 PM
Hilo, Hawaii
Joined Jan 2003
Split elevators on a pull pull system made it necessary to make a bellcrank to join the cables so a single pushrod could be used to actuate the bellcrank from the servo.
Old Apr 27, 2003, 11:04 PM
Hilo, Hawaii
Joined Jan 2003
The cockpit floor was cut out for access and for a scale look. Side doors were carved out of balsa.
Old Apr 27, 2003, 11:07 PM
Hilo, Hawaii
Joined Jan 2003
The dash was downloaded from this forum. Windscreen was leftover plastic from replacement cowl. Note elevator servo location! Yellow on cockpit floor is actually the heatshrink from E-Tec 1200 2S pack.
Old Apr 27, 2003, 11:10 PM
Hilo, Hawaii
Joined Jan 2003
After seeing all the cool TM's with floats, I had to have them too! These were made out of 1-lbs EPS foam skinned with 1/32" balsa and painted with Tamiya Acrylic Aluminum paint.
Old Apr 27, 2003, 11:13 PM
Hilo, Hawaii
Joined Jan 2003
This shot shows the strut arrangement which I tried to make as scale as possible. The UC and Float struts (1/32 wire centers) plug into 1/16" brass tubes mounted on the fuse and balsa ribs on bottom of wing.
Old Apr 27, 2003, 11:16 PM
Hilo, Hawaii
Joined Jan 2003
So what's under the cowl? A GWS IPS-A Twin RLC 4.8v on a custom motor mount! Mount is held in place with 0-72 screws and nuts. Mount can be rotated to mount the stock motor! OOPS! forgot to attach the image!
Old Apr 27, 2003, 11:20 PM
Hilo, Hawaii
Joined Jan 2003
Hey Mr. Lin! How's about manufacturing mounts like this one so everyone can have a mount that can accomodate either a single or twin IPS motor! But, thanks to everyone for giving me the ideas for this project! and to GWS for making such a sweet flying parkflyer!
Old Apr 27, 2003, 11:26 PM
Hilo, Hawaii
Joined Jan 2003
Sorry about leaving off the pic of the motor! Here it is!
TM or SSS for G2? Coyote Simulators 1 Aug 31, 2003 09:29 PM
TM or Piper j8m8l Parkflyers 3 Nov 26, 2002 08:58 AM
TM or Mini Max ?? Rogerdoger Parkflyers 14 May 21, 2002 05:34 PM
Wind limitiaitons for GWS TM or Cub? Hammer Head Parkflyers 12 Apr 13, 2002 03:46 PM
TM or a Sopwith? Erinair Parkflyers 12 Oct 14, 2001 12:21 AM
