View Poll Results: How far have you flown FPV from your base station?
0km to 2km 54 64.29%
2.1km to 5km 21 25.00%
5.1km to 10km 5 5.95%
10.1km to 20km 2 2.38%
Greater than 20km !!!! 2 2.38%
Voters: 84. You may not vote on this poll
Old Oct 26, 2009, 05:15 PM
Bindle83 is offline
Find More Posts by Bindle83
The FPV Ninja
Bindle83's Avatar
Brisbane, South East QLD
Joined Dec 2008
Poll
How far have you flown from Base Poll
I have been trolling through the vast amounts of info on this forum comparing UHF systems and various other systems and kept wondering what the maximum range people have gotten whilst flying airborne so i started this poll.
I am sure that if you are getting decent range people would like to know what equipment you are using so please let us know so we all can be jealous.
Cheers,
Bindle83
Bindle83 is offline Find More Posts by Bindle83
Old Oct 26, 2009, 05:31 PM
aaron_gx is offline
Find More Posts by aaron_gx
Flying FPV from the lab.
aaron_gx's Avatar
Canada, AB, Lethbridge
Joined Jun 2008
i feel a post from FedAviationAdmn coming on...
aaron_gx is offline Find More Posts by aaron_gx
Old Oct 26, 2009, 05:34 PM
Bindle83 is offline
The FPV Ninja
Bindle83's Avatar
Joined Dec 2008
Ha, what the FAA and CASA don't know won't hurt them
Old Oct 26, 2009, 05:51 PM
jetstreaming is offline
Find More Posts by jetstreaming
UK
Joined Mar 2009
Elaborating, that should be 1 direction, max distance obtained, before turning round and flying back to your ground station in the same flight/session (not the round trip distance)
A very modest 0 - 2km here! ...If I actually see 2km, I will be very proud!
jetstreaming is offline Find More Posts by jetstreaming
Old Oct 26, 2009, 06:49 PM
downeym is offline
Find More Posts by downeym
Electric Addict
downeym's Avatar
United States, GA, Atlanta
Joined Apr 2002
people should post their RC equipment setup also...
2.4Km (1.5Miles) on 72Mhz 9CAP/R149DP
downeym is offline Find More Posts by downeym
Old Oct 26, 2009, 07:01 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
2km run
Attached is a photo I took when 4200 feet away from my base station when the video feed started to get a bit weak. I continued on for another 2000 feet before the video feed was too broken up for me to fly well.
System:
Tx: 900 Mhz with 3dbi rubber duck from dpcav.com
Rx: 900 Mhz 4 channel with 8 dbi patch antenna from dpcav.com
Camera: DPC171 low light camera from dpcav.com
OSD: Remzibi poor man's OSD with GPS from Remzibi here on RCG
Airplane: Scratchbuild dual boom glider from my living room
IBCrazy is offline Find More Posts by IBCrazy
Old Oct 26, 2009, 07:26 PM
tychoc is offline
Find More Posts by tychoc
tychoc's Avatar
Austin, TX
Joined Feb 2006
2km with Thomas LRS, 900Mhz VTx and 8db patch. Turned around at the 2km mark as I was getting nervous... No glitches or video degradation at that range though.
-tychoc
tychoc is offline Find More Posts by tychoc
Old Oct 26, 2009, 09:04 PM
Elcheapo is offline
Find More Posts by Elcheapo
Elcheapo's Avatar
Joined Oct 2007
Distance 2.5Km, altitude 480mts. Hitec electron6 PPM Rx 72Mhz, no changes to Rx or Tx antenna. Video was ok, but was having RC glitches.
Video Tx 900Mhz 500mW, Patch on the Rx side.
Elcheapo is offline Find More Posts by Elcheapo
Old Oct 26, 2009, 09:11 PM
bracky72 is offline
Find More Posts by bracky72
Questionable judgement
bracky72's Avatar
Charles Town, WV
6 km here but I have recently made some improvements to my setup and anticipate much more daring flights soon. (I discovered using channel 8 on my lawmate works so much better then channel 1 )
1 watt 2.4 lawmate video on channel 1
14 dBi patch
Thomas LRS
6 km fpv flight (22 min 48 sec)
bracky72 is offline Find More Posts by bracky72
Old Oct 26, 2009, 09:32 PM
JettPilot is online now
Find More Posts by JettPilot
JettPilot's Avatar
Miami
Joined Apr 2005
Yes !
I have flown ## KM from base and back The key is to work up to it slowly, dont try a huge record flight much further than previous flights. Also make sure to do an occasional 360 to make sure you have both video and RC control, signals have a nasty habbit of being good going away and then going very bad once you turn 180 degrees to come back
JettPilot is online now Find More Posts by JettPilot
Site Sponsor
Old Oct 26, 2009, 10:03 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
never far enough
close to LVC has always turned me back
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Oct 27, 2009, 01:15 AM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Originally Posted by JettPilot
Yes !
Good advice. I noticed the same problem. I now mount my TX in the nose which helps eliminate that problem.
Also a warning on banking. When out at a long distance make your banks gentle. Go to a 45 to 60 degree bank and you might find your video goes out mid turn.
Old Oct 27, 2009, 01:21 AM
Bindle83 is offline
The FPV Ninja
Bindle83's Avatar
Joined Dec 2008
This is the sort of thread i was after, fantastic effort keep the replies going!!!
As for me a modest 1km with Spektrum DX7, 900mhz tx 8dbi patch. Upgrading to a UHF system for my Gasser Senior Telemaster soon!!! I want that range
Old Oct 27, 2009, 09:37 AM
FedAviationAdm is offline
Find More Posts by FedAviationAdm
Joined Sep 2009
we know Bindle, we know. You're next on our never-ending list of busted FPVers!
FedAviationAdm is offline Find More Posts by FedAviationAdm
Old Oct 27, 2009, 10:33 AM
Shift is offline
Find More Posts by Shift
Russia, Moscow
Joined Nov 2007
I think there should be more variants on the poll, i'd devide 0-2km into 0-1 and 1-2 km. I've reached 1.3 km with 900 mhz vtx and vrx with stock antenas and the video started to fade out, so i turned back (and my video signal got much worse as Jett said it would be).ut i felt pretty confident with my radio range, there was no glitches or anything, i believe my radio link could go 2-2.5 kilometers if the plane stays high like 200 meters or higher. My radio is futaba 7C 2.4 Ghz with 607 reciever
Shift is offline Find More Posts by Shift
Cool How high have you flown.... Grunta5 Electric Sailplanes 15 Aug 25, 2009 01:09 PM
Question Turnigty 12s 100a ESC, how far have you pushed it? Knife Liddle Power Systems 1 Apr 29, 2008 09:44 AM
Discussion How far from you have you flown your Honey bee FP? Fairmont Micro Helis 8 Apr 04, 2008 05:30 PM
Discussion How far have you gone to retrieve your plane? twoshadetod Electric Plane Talk 39 Jan 27, 2008 07:17 AM
Discussion How far have you driven (or flown) to join an event? KingOfTheHill Slope 29 May 10, 2006 07:05 PM
