Norm Abram...step aside :)
A couple more pieces of wood CA'ed and Epoxyed, along with some landing gear struts fitted....
![]() ...leads to the installation of a 1/8" chunk of balsa, painted with thin CA, here: ![]() And it is airworthy! The cool thing about this is the interchangability between fuses. All I have to do is take the tail apart, cut the ziptie holding the airframe to the mounting base, and transfer it to the other fuselage. No adjustments needed. On the to-do list...glue on a 'locating' plate to the mounting base like on the Align fuse to keep it from sliding forward, and it looks like the tail will be reworked. I'm finding that it is a bit too short. (Wow, I seem to like to do things twice, eh? ) EDIT: I reviewed my photo collection of 500D's, the tail is staying the way it is. Looking at the rotor disk it seems low, but looking at the overall profile it is a better match to the real thing. Damn flybar...get rid of that and tuck the rotor closer in...A quick test flight to make sure it doesnt burst into flames...A little preview of the planned color on the tail:
Drumroll....The Airframe
A couple shots of the Trex250 airframe I'm using:
This is a basic "super combo" V1 heli. I sanded down the mixing arm bearing spacers for a better fit and less slop in the head resulting in more accurate control. Some other changes as follows: Relocated tail servo. Aluminum mounting bracket screwed to the motor mount. No worries about fitting a tail servo into the fuselage now! ![]() 1300mah 3S battery. Longer flight times, less heat, and no need for lead weights to balance either of the 2 fuselages. Gives a nice slight forward weight bias, uses the stock battery plate. ![]() "Left side" tail rotor with CF tail control rod (stock rod ends glued into some CF tube). Puts the tail rotor on the correct side. ![]() Scorpion 3900kv motor. The stocker motor got somewhat toasty running on higher pitch all the time. A motor with a bigger stator/stronger runs cooler. On 13T (Hobbycity 13T 2.3mm shaft pinion drilled to 2.5mm to fit). Normal flight at 3500rpm headspeed, 4000rpm mode available for higher wind stability (CC25 governed). Note: The stock motor might be happy with a 14T pinion to cool it down some, but I never tried it so... ![]() Elevator servo moved inboard. More clearance ![]() ![]() More later... |
Yeah, the nose profile is...I dunno, didnt actually figure that out yet. BTW, this fuse has 'doors' on it...The window opening for the door is definately too small. I'm thinking of how to cut it bigger and not have it look like a hack job. Although I could just stuff a tinted window from the crashed Align fuse into the hole and be done with it. Not sure what I'm going to do yet.
| Thread Tools | |
| Mini Me is born! err... My Mini IFO is born :D | Gene Bond | Parkflyers | 11 | Jan 21, 2003 09:17 AM |
| Mini-Max flight report with questions :) | E's-R-Gr8 | Parkflyers | 2 | Nov 30, 2002 04:49 PM |
| FS NIB EJF Mini A-10 - composite. With Fans..... | jfruge | Aircraft - Electric - Airplanes (FS/W) | 10 | Nov 18, 2002 11:02 PM |
| Anyone tried the Mini Max/Sporty 280 with gear box on TM? | Hammer Head | Parkflyers | 10 | Jun 05, 2002 07:56 PM |
| Is there a speed control that will give me 3 servos with a speed 400 & 10 cells | martin johnson | Electric Plane Talk | 4 | Jun 04, 2001 12:47 AM |
