Go Back   RC Groups > Aircraft - General > Aerial Photography
Old Oct 30, 2009, 03:25 PM   #31
Cool. I like it. I've got a couple other planes and whatever, and that thing really is a solid design. Easy to fly too.
Aut0tek is offline Find More Posts by Aut0tek   Reply With Quote
Old Oct 31, 2009, 07:57 PM   #32
rjarois's Avatar
gear nstalled..
installed the gear today....all i have left is the camera mount, and the rubber band keepers for the wing. as of now the model sits at 25oz. the gear added lots of weight. with 2250 3cell the weight is at 31.3oz. i might have to look into a smaller camera, i donno. randy.
rjarois is offline Find More Posts by rjarois   Reply With Quote
Old Oct 31, 2009, 08:25 PM   #33
That weighs well under what mine does with all it's junk. it's 50 oz with my bigger battery and cam... I like heavy planes (with adequate propulsion to MOVE said weight) they are less susceptible to wind and such... Or at least that's how it feels when I fly.
Old Oct 31, 2009, 11:00 PM   #34
Vapor Junkie
Breezemont's Avatar
Try it with dummy weight first - I'll bet that wing will easily lift it.
Breezemont is offline Find More Posts by Breezemont   Reply With Quote
Old Nov 01, 2009, 09:00 AM   #35
rjarois's Avatar
camera plane is ready for its first flight....
got the high-lift camera model ready to fly....its auw without a payload is 30.5oz. with a 3 cell 1300mah pack, and 33.3oz. with a 3 cell 2250mah. i weighed my camera and its 12.8oz. ready to fly with servo trigger. my camera mount is at 1.1oz. i have not installed yet. ......that's real fat, and i have a 14.1oz. payload i can test fly....if it can haul that up, it will be fine with the 12.8oz. camera......if not, i will have to get a lighter camera. the first flight should be soon. i will be back to report. randy.
Old Nov 01, 2009, 09:27 AM   #36
signguy's Avatar
14 oz payload should be easy with that plane
signguy is offline Find More Posts by signguy   Reply With Quote
Old Nov 01, 2009, 11:20 AM   #37
Real Time Recon
Good luck on maidenWatch ground prop clearance(going by the pix.)...RTR
realtimerecon is online now Find More Posts by realtimerecon   Reply With Quote
Old Nov 01, 2009, 01:01 PM   #38
rjarois's Avatar
thanks, real....the prop has tons of clearance...the photos dont show this. going to maiden to get cg, then use a 14oz. weight and to try to fly.... randy.
Old Nov 01, 2009, 01:27 PM   #39
Ya, THAT Ira
Real Ira's Avatar
Hi Randy,
Cool looking bird.
It may be a little wobbly in the pitch axis but I have found that standard thinking sometimes does not seem to apply to aircraft this size. It could well fly smooth as silk.
Can't wait to hear how she does.
Real Ira is online now Find More Posts by Real Ira   Reply With Quote
Old Nov 01, 2009, 03:11 PM   #40
rjarois's Avatar
thanks ira....i made it from a great planes tudor model...actually i made a stock sized one that flies great...all i did was scale it up, and instead of a clark-y i used this foil...hopefully it does fly good, and i will give a detailed flight report. randy.
Old Nov 01, 2009, 04:20 PM   #41
Hehe they almost killed me for such statement in the begginning of this topic .
I wish it flys like a bird.
Good luck
Michal
tty044 is offline Find More Posts by tty044   Reply With Quote
Old Nov 01, 2009, 04:41 PM   #42
vpatron's Avatar
Send a message via Yahoo to vpatron
Hi Randy,
Your build looks awesome! But your wing as tons of undercamber. You're gonna need a lot of up elevator to counter the negative pitch moment it will produce.
Looks similar to a plane I'm building now...
-Vince
vpatron is offline Find More Posts by vpatron   Reply With Quote
Old Nov 01, 2009, 05:48 PM   #43
rjarois's Avatar
Originally Posted by vpatron View Post
Hi Randy,
-Vince
Vince, it seems to me you have more advanced knowledge of aerodynamics's than i do...would you have any cg recommendation for this high-lift wing?? is it the same as a Clark-y? i have no clue as were to have on the first flight. i was going to have it on the first 30% . would you do any thing different?. thanks for any input from anyone regarding the cg. thanks. randy.
Old Nov 01, 2009, 06:51 PM   #44
It would be good to have CG closer to the front than to the back. Normally (and more safe for maiden) I would keep it 20-25% from front wing edge. After initial testing you could move CG a little closer to trailing edge (25-30%) and observe plane behaviour. I suppose you will need stable photo platform - thats why I am proposing to keep CG 20-25% from the front of the wing.
Here is CG calculator. You can play with it and find what you need.
Regards
Michal
Old Nov 01, 2009, 07:18 PM   #45
rjarois's Avatar
cool mike, thanks....i will look it over. just for the record, i can build ok, but as far as what im buildin...well I'm a idiot...but that never stopped me, lols. thx again. randy.
High Res Camera's MatRat Aerial Photography 6 Jul 12, 2005 03:54 PM
High lift Homecut wing garydog1 Foamies (Kits) 0 Feb 23, 2005 09:14 PM
High Lift Airfoil garydog1 Slope 12 Feb 04, 2005 12:05 PM
My obscenely low tech, yet somehow high tech, camera mount eBird Aerial Photography 29 Dec 31, 2004 07:49 PM
high lift airfoils ikkus Dynamic Soaring 2 Dec 02, 2003 03:57 PM
Bored? Want to fight?
Join the RCGroups clan!
