Go Back   RC Groups > Aircraft - General > Aerial Photography
Old Oct 25, 2009, 06:30 PM   #1
rjarois's Avatar
high-lift camera foamie...
fellas, after giving my magpie-ap to a friend so he can learn to fly, i decided to build a new camera model. i did a google search for high-lift cargo airfoils...and this was listed as one of them. the fuse was cut out on the phlatprinter, and the wing test cut on my hotwire. it is a 10 1/2 constant root, and will cut it with a 55in wing span. the fuse is scaled to a magpie size wise. randy.
rjarois is offline Find More Posts by rjarois   Reply With Quote
Old Oct 25, 2009, 06:53 PM   #2
I believe this wing profile would not be stable. You have to pepare for nervous response for h-stab. It would be nice to test it though.
Good luck
Regards
Michal
tty044 is offline Find More Posts by tty044   Reply With Quote
Old Oct 25, 2009, 07:43 PM   #3
John O'Sullivan's Avatar
This is a perfectly normal airfoil for stable slow flight and should not present any problems. don't hesitate to use it.
It's amazing what totally hybridized concoctions of single surface airfoils are being used to good effect.
This section should not any present problems as long as you have a light wing loading and fly slowly.
John
John O'Sullivan is offline Find More Posts by John O'Sullivan   Reply With Quote
Old Oct 25, 2009, 08:48 PM   #4
rjarois's Avatar
airfoil..
yea john, its worth giving a try... i got the model in the Clark-y programmed on both machines, so if it don't work i can just cut the other..i made a 40in wing span with the Clark-y thats proven. here is a link if your interested. randy.
phlatforum
Old Oct 25, 2009, 09:06 PM   #5
fritzdecat's Avatar
Yes this looks good
look forward to seeing the rest of it come together
fritzdecat is online now Find More Posts by fritzdecat   Reply With Quote
Old Oct 25, 2009, 09:43 PM   #6
These guys are scary good
Montag DP's Avatar
There's no reason it would make the plane unstable, but it will probably make the plane tougher than most to trim.
Montag DP is offline Find More Posts by Montag DP   Reply With Quote
Old Oct 26, 2009, 08:30 PM   #7
Peepin' from above
Gwelan's Avatar
Interesting thread about the airfoil issue:
http://www.rcgroups.com/forums/showthread.php?t=696779
If trying an undercambered is important for you, please consider modern airfoils like the DAE31 and the DAE51. I used both of them on my last plane and was very pleased with their general behavior.
http://www.worldofkrauss.com/foils/1372
http://www.worldofkrauss.com/foils/1150
Gwelan is offline Find More Posts by Gwelan   Reply With Quote
Old Oct 29, 2009, 02:45 PM   #8
rjarois's Avatar
wing almost built..
just a little more work, and i will test the heavy cargo wing....its a 62in span. i am hoping it can lift the small camera i have. randy,
Old Oct 29, 2009, 02:48 PM   #9
Real Time Recon
Should be able 2 lift more than a small cam !...RTR
realtimerecon is offline Find More Posts by realtimerecon   Reply With Quote
Old Oct 29, 2009, 03:22 PM   #10
rjarois's Avatar
wing progress...
im just hoping it will lift it...
Old Oct 29, 2009, 05:34 PM   #11
Real Time Recon
A little H.Z.S.cub (ALL stock) will lift a 6 oz. camera.And that wing is only 7"X47".So you'll have no problems...RTR
Old Oct 30, 2009, 02:30 AM   #12
A "small cam?" That wing will probably lift 5 small cams. lol.
Good luck.
soft2 is offline Find More Posts by soft2   Reply With Quote
Old Oct 30, 2009, 07:14 AM   #13
rjarois's Avatar
yea, its a old canon G-7 that weighs 12oz. without battery.....thats my concern...maybe its not a small camera....randy.
http://www.dpreview.com/news/0609/06091405_canon_g7.asp
Old Oct 30, 2009, 07:47 AM   #14
Yea, 3/4 of a lb isn't real tiny haha. I always thought my Kodak 7630 was big. it's like 1/2 the weight of your cam. lol.
I think the wing will lift it... I would've thought a longer chord though... definitely keep us posted!
Aut0tek is offline Find More Posts by Aut0tek   Reply With Quote
Old Oct 30, 2009, 09:10 AM   #15
rjarois's Avatar
build update...
fitted the wing to fuse...as of now the model is almost 18oz. i suppose the gear is next....any and all input is very welcomed. randy.
High Res Camera's MatRat Aerial Photography 6 Jul 12, 2005 03:54 PM
High lift Homecut wing garydog1 Foamies (Kits) 0 Feb 23, 2005 09:14 PM
High Lift Airfoil garydog1 Slope 12 Feb 04, 2005 12:05 PM
My obscenely low tech, yet somehow high tech, camera mount eBird Aerial Photography 29 Dec 31, 2004 07:49 PM
high lift airfoils ikkus Dynamic Soaring 2 Dec 02, 2003 03:57 PM
Bored? Want to fight?
Join the RCGroups clan!
