Old Oct 25, 2009, 08:03 AM
Steve Mills is offline
Find More Posts by Steve Mills
Steve Mills's Avatar
England
Joined Dec 2005
Gorilla glue.
Just wondering if there are any generic alternatives to this glue.
thanks....
Steve Mills is offline Find More Posts by Steve Mills
Old Oct 25, 2009, 09:49 AM
Curtis Suter is online now
Find More Posts by Curtis Suter
Red Merle ALES
Curtis Suter's Avatar
United States, Mt, Helena
Joined Apr 2002
From the Gorilla Glue website:
http://www.gorillaglue.com/informati...re-to-buy.aspx
Where To Buy
In the U.S. and Canada, Gorilla products can be found at most hardware stores, mass merchants and home centers. Also, be on the lookout for new Gorilla Epoxy, coming soon to a store near you.
For United Kingdom, please call 44 (0) 844 7451880 or email: eusales@gorillaglue.com
Curtis
"A Beginner's Guide to Cutting and Bagging Foam Wings" DVD
Curtis Suter is online now Find More Posts by Curtis Suter
Old Oct 25, 2009, 10:43 AM
England
Joined Dec 2005
Where To Buy
Curtis
Thanks but I'm seeking an alternative.
Old Oct 25, 2009, 11:27 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
For sure there are alternatives. My carpenters (my? well the ones who built the house) had a foaming poly glue from probably screwfix.
heres some
http://www.screwfix.com/cats/A436128...thane-Adhesive
Not sure if these are foaming or not.
Oh a google suggest all polyurethanes are foamers, to a point
here's another one
http://www.toolstation.com/shop/Adhe.../sd3198/p52489
Basically head for the nearest Builders Merchants and ask for polyurethane wood glue, at trade prices of course!
While you are there ask if they have ultra lightweight Polyfilla as that is the best balsa filler yet for very low weight, and get a gun of decorators caulk. That's brilliant stuff for filleting. It is essentially somwhqat like PVA plus filler, and it can be applied and wiped off with a wet finger., sets hard but not brittle. Its THE best filleter for wood use, Paints up easily too, unlike silicone. I've used it in the house along with bits of carved blue foam to make a faired in pipe 'blister' that covered an ugly pipe and its perfect for blending in edges. I have also used it to replace fallen out mastic in my motorhome. White, and seals the cracks better than regular mastic cos it STICKS. It's another way to hold canopies in as well.
Its rather like a slow version of hot glue...
Old Oct 25, 2009, 11:32 AM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Lots of alternatives - PU = Polyurethane
Elmers PU
Ultimate PU
Excel PU
SUMO PU
Titebond PU
hoppy is offline Find More Posts by hoppy
Old Oct 25, 2009, 11:56 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Sadly none available this side of the pond Hoppy.
Same glue, different brand names.
One of the best is simply called 'sticks like sh*t' Yup. That really is what its called on the tube, jus' like I wrote it.
Its not a PU glue tho. Its like 'no more nails' - a sort of air set acrylic glue.
Old Oct 25, 2009, 12:11 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
LOL,
In that case, google 'polyurethane glue uk'
One hint, place a strip of tape over the joint face that faces out. It will prevent the excess foaming out that is a pain to clean up after it has hardened.
Old Oct 25, 2009, 02:08 PM
Broken Wings is offline
Find More Posts by Broken Wings
Broken Wings's Avatar
United States, FL, Cocoa
Joined Jan 2006
This was a post by one of our other members;
"I am a woodworker (yet another hobby ) and subscribe to Fine Woodworking magazine. They ran a very thourough test on wood glue strengths in their August 2007 issue.
There were some surprises in the results. Big surprises. They tested the following:
1. PVA................. (Elmer's Carpenter's Glue, Titebond I, etc)
2. PVA Type I....... (Titebond III, etc.)
3. Epoxy.............. (Slow set type, not the weak 5-minute stuff)
4. Polyurethane.... (Gorilla Glue, etc.)
5. Liquid Hide Glue. (Brown urea based liquid)
6. Hot hide glue.... (Flakes dissolved and heated in glue pot)
The surprises? Epoxy was not the strongest. Polyurethane was the worst of the lot, really poor. And regular old PVA won the day. Sure surprised me anyway (as well as the editors doing the testing).
The strongest was PVA Type I, but it was only marginally stronger than regular PVA.
So unless you need the esoteric stuff for something outside normal bonding, the cheap PVA's are by far the best performer.
Please note, the tests were conducted on WOOD joints only. If you are bonding other materials, then epoxy wins.
They did not test any CA as it is seldom used in general woodworking and never for any serious joint.
Tom"
Broken Wings is offline Find More Posts by Broken Wings
Old Oct 27, 2009, 05:37 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
well its a question of the joint..a GOOD woodworking joint is a mortice and tenon, where the glue does no more than resist shear forces. PVA is brilliant there.
Not so sure when you are trying to butt something up, and need to build a fillet.
Old Oct 28, 2009, 03:52 PM
DENHAMDULAKE is offline
Find More Posts by DENHAMDULAKE
DENHAMDULAKE's Avatar
Brighton, England
Joined Mar 2009
Gorilla Glue in UK
Are you asking if there is an alternative to Gorilla glue because you can't source it in uk?... Just by chance popped into screwfix the other day and noticed they are selling Gorilla glue :-) so should be everywhere round the uk.
Also there is something called rhino glue which some model shops have here in uk which i think is the same thing.
Denham
DENHAMDULAKE is offline Find More Posts by DENHAMDULAKE
Old Oct 28, 2009, 03:59 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Rhino is better(?) in that it foams less.
Old Nov 07, 2009, 11:37 AM
England
Joined Dec 2005
Denham
Thanks Denham and everyone but it's the often silly prices for small quantities that I struggle with and why I usually look for a non branded alternative.
Old Nov 08, 2009, 06:44 PM
Brighton, England
Joined Mar 2009
Just brought a 275ml bottle for 12 from screw fix. I thnk its about 27 for a one liter bottle which would last forever :-)
Old Nov 08, 2009, 10:37 PM
T_om is offline
Find More Posts by T_om
The Junk Man
Jacksonville, Florida
Joined Jul 2006
...which would last forever :-)
PU adhesives have a limited shelf life. It is false economy to over-buy in large quantities.
Tom
T_om is offline Find More Posts by T_om
Old Nov 15, 2009, 04:06 AM
Jim.Thompson is online now
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
Alternate brands
This is slightly off the point, but here in Australia we buy PU glue "Vise" brand is one. However, I have reason to suspect that it has differing qualities to Gorilla Glue. For most purposes this is not a problem. However, I did some test samples of vac bagging wings along Curtis's construction methods with poor results. I have formed the conclusion that the glue behaved differently than "Gorilla" glue. I posted my results in http://www.rcgroups.com/forums/showthread.php?t=1065446
Jim.
Jim.Thompson is online now Find More Posts by Jim.Thompson
Homage To Gorilla Glue steelhead Foamies (Kits) 20 Jan 30, 2009 04:27 AM
Gorilla Glue/Probond question arx_n_sparx Foamies (Kits) 6 Jan 02, 2004 12:14 PM
Gorilla Glue sreding Foamies (Kits) 4 Aug 23, 2002 12:12 PM
