Old Oct 27, 2009, 12:22 PM
trappy is offline
Find More Posts by trappy
trappy's Avatar
Austria
Joined Feb 2007
fmkit: when you have a whole system on sale (nunchuck + UHF tx / rx with min 5CH) plz let me know. This is a really cool project, I need one for x-mas
trappy is offline Find More Posts by trappy
Old Oct 27, 2009, 12:24 PM
fmkit is online now
Find More Posts by fmkit
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Originally Posted by trappy
the reason I want to get the nunchuck is because of the hands-free operation not the UHF tx. But ... I need the UHF tx in order to get it hands-free, otherwise the nunchuck is tied to the TX.
I really like the idea of the wrist-band mounted UHF tx and the nunchuck in your hand. It's a very simple, self-contained unit.
And one last question on the nunchuck-control. Obviously when you throw the plane you want the sticks to remain in neutral position despite of how your hand moves ... have you factored in that?
No wristbands! if your video not 2.4ghz use original wireless nunchucks
http://imgs.inkfrog.com/pix/leechomlch/WII-CON010_a.jpg
fmkit is online now Find More Posts by fmkit
Old Oct 27, 2009, 12:40 PM
fmkit is online now
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
you have no idea how cool it can be,
how often do you see flying wing gyro on each axis ?
the receiver end has specialized chip to do elevon mixing and gyro reading, cause one chip is responsible for gyros and mixing there is absolutely no delay.
Meanwile I use gyro sensors extracted from esky 0704b HH gyros. I'm working on IMU based on Wii MotionPlus 3axis gyro+accelerometers extracted from nunchuck.
here is flying wing receiver with two gyros built-in
http://forum.rcdesign.ru/attachment....3&d=1256309116
Old Oct 27, 2009, 03:46 PM
rilandtg is offline
Find More Posts by rilandtg
Joined Sep 2007
How about a video of how this all works?
rilandtg is offline Find More Posts by rilandtg
Old Oct 27, 2009, 04:20 PM
fmkit is online now
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Nunchuck kits available
I just uploaded page were you can order Nunchuk conversion kit for $20 shipped. Takes me 10min to convert nunchuck into 9ch system (solder pre-programmed chip, buzzer connector) and there was 3 months of development and in field testing.
http://fmtv.us/wii_nunchuck_rc.html
Along with excellent ergonomics of Nunchuck you get 2D throtle control, expo on elevator and aileron, user presets, speed and intuitive control that needs no trained fingers
This is standard 20ms frame chip,
the UHF system I'm using is 4 times faster and requires special receiver capable of variable rate PPM.
if you use small craft or do crazy thing on simulator the difference is dramatical.
Old Oct 27, 2009, 06:53 PM
Tuven is offline
Find More Posts by Tuven
Alexander/Sweden
Tuven's Avatar
Hemavan/Sweden
Joined Nov 2006
Can just say, amazing work, very cool,
I like the nunchuk controller so dam nice to hold and use.
Cant wait to get hold on this,
Just ordered one from you
Tuven is offline Find More Posts by Tuven
Old Oct 27, 2009, 06:56 PM
Tuven is offline
Alexander/Sweden
Tuven's Avatar
Hemavan/Sweden
Joined Nov 2006
Two questions.
Could this work in parallel whit the head tracker 2?
Could i use the joystick on the nunchuk to control rudder and elevator? it would be a nice option.
Just a thought.
BTW have a futaba 7c.
Old Oct 27, 2009, 07:10 PM
fmkit is online now
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Originally Posted by Tuven
But one question.
Just a thought.
the nunchuck works with my own headtracker (which is another desected nunchuck ) , I never owned other headtrackers. If you tell me how your tracker works I may come up with solution, Say you have PPM train of 10ch and want to replace channels 3 and 8 with PPM train from another source - that's easy. What's output of your headtracker ?
ps: will ship tomorrow!
Old Oct 27, 2009, 07:52 PM
Tuven is offline
Alexander/Sweden
Tuven's Avatar
Hemavan/Sweden
Joined Nov 2006
Sounds great. no hurry hehe
The head tracker i use is the TrackR2,
Here is the manual if you have time,
http://hobbywireless.com/docs/TrackR2_manual.pdf
BTW could the nunchuk joystick be used to control rudder and elevator in some way. if not i would be a great option.
Regards Alex
Old Oct 27, 2009, 08:38 PM
logicwins is offline
Find More Posts by logicwins
FPV FTW
Austin, TX
Joined Dec 2004
Just ordered the one with the chip already implanted. Looking forward to messing with it. I am Justin in case a bunch of people are ordering. I have a futaba 7c radio, but I want to get a set of those 2way radios you were describing and fit them in a wing.
logicwins is offline Find More Posts by logicwins
Old Oct 27, 2009, 08:40 PM
FPV FTW
Austin, TX
Joined Dec 2004
Could the 2way radio design be used as an RX and video TX as an all in one unit? Would sure simplify the setup
Old Oct 27, 2009, 08:43 PM
fmkit is online now
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
Channels map:
x/y accelerometers - elev/ail, Z-button for 2s to hold position
x/y joystick: pull=throttle up, push=throttle down
left/right >> multifunction: rudder,throttle,channels 5,6,7,8
C short -reset to preset throttle,rudder on, also reset ch9 to zero
rapid C clicks:
x2 throttle offset set
x3 ch5 , x4ch6, x5 ch7
while rudder stick is switched push Z button to store channels/throttle into EEPROM , or push C button to exit setup.
Z-button held for 1s activates low rates (ail/elev only)
Z-button short - throttle cut-off
You can fly while in setup, ail/elev/throttle don't change function, to have rudder back momentarily push C-button
C-button for held for 1second ch9 50%, 2s ch9 100%
any button held while powering up sets reference for accelerometers,
If you don't have time to trim your model mechanically you can temporarily trim the controller: hold any button while powering up and tilt or move rudder stick a bit in same direction, for example if model yaw CW push rudder a bit CW while powering up so centerd position will have offset till next calibrate
Old Oct 27, 2009, 09:04 PM
fmkit is online now
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
I've tried to transmit AM and FM video using modified 5W Midland 2way radios but had no luck finding 10-20MHz wide channel in 420-470MHz range, dispite excellent hardware I had the system was unusable - to much RFI.
FRS voice channels are just 6khz wide and with such bandwith -120dbm sensivity is normal.
UHF just meant for compact long range comms.
Old Oct 27, 2009, 09:42 PM
fmkit is online now
fast
fmkit's Avatar
ISRAEL
Joined Aug 2007
my very 1st Nunchuck
While learning to fly small quad I realized that I have to use throttle a lot !
the quad was loosing altitude with every turn and was very twitchy. I just had to make my own remote to fly comfortable. Here is the picture of my 1st setup - the Nunchuck connected to original remote.
This nunchuck used original remote power and IR LEDs, nothing else - it outputs proper 38kHz modulated PPM.
The Nunchuck turned out to be the best remote so today I use nothing else.
Old Oct 27, 2009, 09:57 PM
The_Mongrel is offline
Find More Posts by The_Mongrel
CASA Certified RPAS Instructor
The_Mongrel's Avatar
Australia, NSW, Yass
Joined Dec 2007
So here is a question...
Can it have full proportional throttle control? Do you have the ability to fully control the throttle while you fly?
The_Mongrel is offline Find More Posts by The_Mongrel
