Old Apr 27, 2003, 02:58 PM
pocket rocket is offline
Find More Posts by pocket rocket
pocket rocket's Avatar
patagonia,az
Joined Oct 2002
Hacker Master ESC beep beep beep.....
replaced my Hacker Master 70 Opto with a new one due to crash damage.
the new one is a little different than the old one.
on power up with throttle on low I get
one beep - brake on
5 beeps - what do these mean ???????
than silence
it's not the 'timing mode' nor the 'frequency mode' as it's just 5 single beeps not those long sequences.
everything works ok but the old ESC didn't do this.
anybody know what the beeps mean ????????
thanks, Philip
pocket rocket is offline Find More Posts by pocket rocket
Old Apr 27, 2003, 07:46 PM
BEC is offline
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
I presume you've checked the instructions and not found anything about it?
The Jeti Advance controllers tell you which timing mode they're in if you let them sit there, armed, for a time, by using a beeping signal. Perhaps this feature has been added to the Masters.
BEC is offline Find More Posts by BEC
Old Apr 28, 2003, 04:07 AM
JWS is offline
JWS
Find More Posts by JWS
JWS
More power !!!!
JWS's Avatar
Zwolle, Netherlands
Joined Aug 2002
My new 30 A Master does the same.
The 77 A in my Ariane does not.
JWS is offline Find More Posts by JWS
Old Apr 29, 2003, 06:31 PM
patagonia,az
Joined Oct 2002
just found out from my 'inside source' that it's a software upgrade.
the '5 beeps' confirm Timing Mode 1
I'll try changing the Timing Mode and hear if the 'beeps' are different
Philip
Old Apr 30, 2003, 11:10 PM
patagonia,az
Joined Oct 2002
changed to Timing mode 2 and now I get 5 rounds of 2-beeps to confirm on power up
changed frequency mode but that doesn't change the beeps
Philip
Old May 01, 2003, 02:53 AM
Gary Retterbush is offline
Find More Posts by Gary Retterbush
I "plant" trees (balsa)
Gary Retterbush's Avatar
Eisenschmitt, Germany
Joined Jan 2002
The beeps after the initial single beep indicate the timing mode as pocket rocket noted. With a Hacker motor you want 5 beeps for the correct mode. The frequency mode has no effect on the startup beeps as you noted.
Gary Retterbush is offline Find More Posts by Gary Retterbush
Warranty info on Hacker Master ESC Ben74 Electric Heli Talk 8 Dec 18, 2002 02:14 PM
Hacker Master ESC, Help needed HarryNz Electric Heli Talk 4 Oct 01, 2002 11:43 PM
AF020 + Hacker Master ESC = Glitches = Crash? mario alvarez Electric Plane Talk 1 Jul 30, 2002 09:51 AM
Disabling BEC on Hacker Master ESC JeffD Electric Plane Talk 4 Jul 29, 2002 01:10 PM
UK/Europe Source for Hacker Master ESC and C40 12T? Ben C Electric Plane Talk 5 Feb 14, 2002 08:54 AM
