Old Oct 24, 2009, 06:43 AM
Old age is not for sissies
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Pull Pull material
Lately I've converted most of my pull pull systems to pushrods, but on my SemiNoll with dual elevators it's more difficult. I've been using Spider Wire, but have been having a lot of trouble keeping it tight enough. Either it's stretching or the foam is contracting in our colder weather.
Suggestions/comments appreciated.
Azarr
Azarr is offline Find More Posts by Azarr
Old Oct 24, 2009, 10:10 AM
Horizon Hobby Employee
3D-Seth's Avatar
Champaign, IL
Joined Jan 2007
Azarr,
On the Spider Wire, with normal single elevator, you can run your two lines up through the bottom of the servo horn, then wrap around the servo arm screw clockwise. Then all you need to do, is tighten the screw when the cables loosen.
Seth
3D-Seth is offline Find More Posts by 3D-Seth
Old Oct 24, 2009, 10:21 AM
Oly crap.. Deese ease not gud!
hpapilot's Avatar
USA, NC, Kernersville
Joined Nov 2006
Gee Seth, that sure sounds familiar...
Azarr I think I showed you that pull-pull setup on one of my planes at KIEF. I have done the exact same thing on a Seminoll with split elevators and the tiny little D47 servo screw and it still worked fine.
Of course, ideally we'd find some line that doesn't need tightening and still doesn't stretch under load...
RJ
hpapilot is offline Find More Posts by hpapilot
Old Oct 24, 2009, 10:32 AM
Azarr's Avatar
Joined Jan 2000
Thanks Seth & RJ, is there different types of spider wire? Mine is stretched out to a ridiculous amount. i.e. on the rudder, it's so loose I can almost reach 3/4 of the way up to the top of the fuselage. It's definitely not slipping, I can't force it to slip. Mine is fixed at both ends, I didn't leave any adjustment, but it's so loose there would be no way to adjust it anyways. We've got a huge fishing supply store in Dayton, I'm going to check it out next week and see what they have to say.
Azarr
Old Oct 24, 2009, 10:55 AM
why wont it fly
south africa
Joined Jan 2006
its a tedious job but i strip the kevlar strands that are about every six inces apart in my carbon fiber cloth and use them, havent had trouble since, doesnt seem to load the hinges as much either
dylan roberts is offline Find More Posts by dylan roberts
Old Oct 24, 2009, 11:01 AM
3D-Seth's Avatar
Champaign, IL
Joined Jan 2007
Azarr
Let me know if you find anything good there Azarr! I might have to run over and pick some up myself!
Seth
Old Oct 24, 2009, 11:02 AM
3D-Seth's Avatar
Champaign, IL
Joined Jan 2007
RJ
And yes, I know...
I don't use spider wire though so...I just figured I'd tell him how you do it.
Old Oct 24, 2009, 11:08 AM
Ruud_NL's Avatar
Joined Apr 2007
Hi,
I'm using wire used for kites. They have improved now to almost no stretching material. It's the smallest size they have and it's something like 0,5 mm thick. Weight is less than a gram on one meter. I use "alu-tubes" that I press with a wire to keep it holding. It doesn't move and doesn't stretch at all. If you want I can post a photo.
Regards
ruud
www.f3p.eu
Ruud_NL is offline Find More Posts by Ruud_NL
Old Oct 24, 2009, 12:08 PM
ededge2002's Avatar
Newmarket,Ontario, Canada
Joined Dec 2002
ive found that if you need to tighten the lines a little on a model you can remove the horn from the servo and carefull twist it and the lines will shorten up with only 7-10 twists. storing models with the surface deflected slightly also seems to stop them from stretching out as much.
ededge2002 is offline Find More Posts by ededge2002
Old Oct 24, 2009, 12:32 PM
Azarr's Avatar
Joined Jan 2000
Originally Posted by Ruud_NL
Hi,
Regards
ruud
www.f3p.eu
ruud, are you using a Spectra material?
Azarr
Old Oct 24, 2009, 02:20 PM
Team Futaba
Devin McGRath's Avatar
Rochester New York
I have been using regular fishing line for years with good results. 17 lb test stretches enough to move with the airframe and is still highly effective. I unfortunately don't have the pleasure of tightening my pull pull lines every day....
Devin McGrath
Devin McGRath is offline Find More Posts by Devin McGRath
Old Oct 24, 2009, 02:39 PM
hpapilot's Avatar
Joined Nov 2006
Aww man Devin, you're missing out on the fun! When you're lucky, you get to tighten them 2 or 3 times a day...
Old Oct 24, 2009, 04:09 PM
Ruud_NL's Avatar
Joined Apr 2007
Azarr
Azarr,
Is Spectra the product or the brand?
The product I use is called Aramide (it's kevlar kind). It has a stretchratio of 3% max. It's a kind of yellow stuff.
Regards
Ruud
www.f3p.eu
Old Oct 25, 2009, 10:24 AM
Azarr's Avatar
Joined Jan 2000
Azarr,
Regards
Ruud
www.f3p.eu
Spectra is the product, I think it's a polymere of some sort, just as aramide is kevlar. I'm going to try kevlar next, I haven't been able to get my hands on any, but have some on the way.
Thanks for your input,
Azarr
Old Oct 25, 2009, 01:19 PM
Joined Nov 2007
Pull-Pull thread
This outfit seems to have almost anything you could ask for in thread...
www.thethreadexchange.com
I got a spool of the #46 Kevlar, but I haven't used it yet
Dave
Acrodave is offline Find More Posts by Acrodave
Help! Quick, Easy, Alternative Pull-Pull Material? CrazyHerb Foamies (Kits) 6 Jul 31, 2005 02:01 PM
Question Pull-Pull Cable Material vonJaerschky Electric Plane Talk 50 Feb 07, 2005 06:02 PM
