Old Apr 27, 2003, 06:04 AM
mikesayer is offline
Find More Posts by mikesayer
mikesayer's Avatar
Coventry UK
Joined Apr 2003
suggetions for pattern plane
Hi,
I am looking for a kit of a pattern plane suitable for electric conversion.
I am thinking of something about 50-60 inch span powered by a flyware outrunner on 12 - 16 cells.
The Great planes Tracer looks like a good choice. Has any one any experience of this model or any other suggestions?
thanks in advance
mikesayer is offline Find More Posts by mikesayer
Old Apr 27, 2003, 08:38 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Welcome to the "Ezone", Mikesayer!
The Tracer flies great with the lessened weight of a glow engine. I personally haven't seen one electrified but these days just about anything is possible. There are a few other planes such as the Lexx that do great in pattern work. Post a few pictures when you get something, OK?
GregG is offline Find More Posts by GregG
Old Apr 27, 2003, 09:12 AM
Sabrejock is offline
Find More Posts by Sabrejock
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
I fly my Tracer at about 500W and 5 lbs. I'd like a bit more, but even as is it's a great flying plane. Pattern style planes are very honest, point and shoot fliers. You'll enjoy it if that's your choice. Tedx.
Sabrejock is offline Find More Posts by Sabrejock
Old Apr 27, 2003, 09:50 AM
jhouvener is offline
Find More Posts by jhouvener
Midland, Mich.
Joined Feb 2003
Try the new Fusion kit. I just got mine. Best kit I have ever seen.Designed especially for sport aerobatics and pattern. 58" low wing, 88 to 96 oz. Great plans. See at www.electroflying.com
jhouvener is offline Find More Posts by jhouvener
Old Apr 27, 2003, 01:29 PM
Ed Lyerly is offline
Find More Posts by Ed Lyerly
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
Hi Mike,
Welcome to the E Zone !
A comment on your question. If you are determined to use the Flyware (or other "outrunner" type motor) your airplane choice will be determined by the size and shape of the nose ..... as a "pattern" plane usually has a slim "pointy" nose and fitting an outrunner in one will likely be a tight fit.
Ed
PS ... please fill out your user profile so your location shows in your avitar on each post.
Ed Lyerly is offline Find More Posts by Ed Lyerly
Old Apr 27, 2003, 03:25 PM
Herky-Bird is offline
Find More Posts by Herky-Bird
Herky-Bird's Avatar
Bracknell, Berkshire, UK
Joined Jul 2001
Hi Mike,
I'm building one of these Alliances at the moment (http://www.probuild-uk.co.uk/product...4b216083e1be1c) and although it's an expensive kit it is extreemly well made and the wood choice is top rate. I'm going to run mine on a geared MaxCim on 20 cells (cp1700) for a higher voltage, lower current setup but I reckon it would go fine on a 16 cell set-up.
cheers
Grant
Herky-Bird is offline Find More Posts by Herky-Bird
Old Apr 27, 2003, 07:30 PM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Change the link to electroflying to ".com" rather than ",com" Tex.
Old Apr 27, 2003, 08:04 PM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Jhouve, Welcome to the "Ezone"!
Thanks for the link, I edited your original post so that it works.
Old Apr 27, 2003, 08:48 PM
twest is offline
Find More Posts by twest
100% electric since 1990
twest's Avatar
United States, MA, Ware
Joined Jul 2001
Check out the thread "calling all lexx owners".
This is an electric pattern arf, (pricy, $500), and in the latest post someone is using an outrunner (one of the new $140 model motors brand).
twest is offline Find More Posts by twest
Old Apr 28, 2003, 06:34 AM
PTLdom is offline
Find More Posts by PTLdom
WC,WS,WC
Joined Dec 1999
The Accord series from Esprit Models would make a good E-pattern plane.
PTLdom is offline Find More Posts by PTLdom
Old Apr 28, 2003, 12:16 PM
mikesayer's Avatar
Coventry UK
Joined Apr 2003
Thanks for all the info.
The Alliance looks favourite at the moment, mainly because it is available in the UK and not too expensive.
I have not managed to find a local source for the Tracer.
Grant have you any idea what your final weight will be??
If the quoted 4 1/2 pounds with an 18oz YS63 is realistic, I would think 5 lbs with 16 cells should be easy.
I am using a Flyware LRK350/25 10.5 turn on 12 CP1700 in my Cougar 2000 and it is superb. It weighs 4 lbs and the static thrust is about 90 oz. The motor is barely warm so I could probably save 2 oz and go for a smaller version of the motor.
cheers
Yippee! Design Basics for Pattern Plane Wingin' Wayne Modeling Science 1 Jan 22, 2005 05:02 AM
Neumotor for Pattern Plane nxtdoor Power Systems 14 Dec 28, 2004 12:14 PM
Motor Advice for Pattern Plane Gwalch Fuel Plane Talk 4 Oct 20, 2004 06:34 PM
Brushless Idea for a Pattern Plane Carnifax Parkflyers 1 Jul 23, 2004 08:39 PM
Airfoil for pattern plane? DeaninMilwaukee Sport Planes 14 Sep 16, 2002 08:58 PM
