Go Back   RC Groups > Aircraft - Exotic and Special Interest > VTOLs
Old Oct 29, 2009, 09:53 AM   #16
Site Sponsor
Hi,
Saw that my name was mentioned, so had to show you this:
VTOL Vector 450 Indoors and Out - Gress Aeronautics (0 min 58 sec)
a video of the Vector 450 bi-prop. It's a descendant of the MicroVader prototype that V22 referred to. Yes, it has been almost 10 years
Pitch control is obtained by having the props tilt in a direction 45 deg. from the longitudinal (fore-aft). Single-axis tilting (not gimballed), so it's still fairly simple mechanically. What's difficult and costly is the 3-axis gyro and mixer unit. You can see everything at my website, at
http://www.gressaero.com
Plans are no longer available, but complete kits are.
Gary
PS. mine is only one solution ... and it took a LONG time to develop. VTOL stability is a difficult field, so don't expect good results with new ideas right away.
GaryGress_1 is offline Find More Posts by GaryGress_1   Reply With Quote
Old Oct 29, 2009, 12:49 PM   #17
v22chap's Avatar
Gary
Hey good to see you are still around these sites .... Been to long since we really have talked and to much water over the damn ???
Hope all is going good with your venture and family ... will pm you with what I am doing at present
Larry
v22chap is offline Find More Posts by v22chap   Reply With Quote
Old Oct 31, 2009, 07:50 AM   #18
hey guys.. its me again.. first thing first... HELP!!! look at my video and ull understand why.. is it due to differences in rpm between the two motor? we got our cg done rite, now its yaw-ing like mad.. dats the reason i don't dare to throttle up more..
Vtol unstable (0 min 14 sec)
vtol unstable II (0 min 13 sec)
yuzri1984 is offline Find More Posts by yuzri1984   Reply With Quote
Old Oct 31, 2009, 08:46 AM   #19
Originally Posted by yuzri1984 View Post
...now its yaw-ing like mad..
The second video actually didn't look too bad except for the yaw.
Tilt the motors slightly to compensate for the yaw.
If everything is still held together with tape still, especially the rod that the motors are attached to, then you have to start securing things better. Glue some of these Landing Gear Wheel Stoppers to your fuselage to hold the motors rod. Make sure your plane balances left to right as well.
Originally Posted by GaryGress_1 View Post
...Saw that my name was mentioned...
And purchase one of Garys kits to learn from Something I plan to do as well.
This guy is a genious!
RCvertt is offline Find More Posts by RCvertt   Reply With Quote
Old Oct 31, 2009, 09:15 AM   #20
v22chap's Avatar
O.K. to stop the yaw ,,, one motor has to point forward a little and the other backwards a little (engine vectoring ) .. You could play around with this in a manual position setup until you get it close ,,,but every time the motors advance or a gust of wind hits it ,,things will change .. Therefore ,,,since you aren't going to go with Greg's tri copter setup you need to follow another guys plans , Vtolman used just two motors to control VTOL flight and up close to conversion ,,,, but this will need to have TWO servos ,a vtail mixer and gyro's to control it .
These two servos and a vtail mixer / with gyro's to do pitch and yaw axis through the two motors in a true engine vector setup and balance will be touchy on this as well .
Please read his article as it will help you a lot .
You need to read the whole thing to get it all ...but if you skim just vtolmans posts you will get most of it . .
http://www.rcgroups.com/forums/showthread.php?t=440470
By the way ,, don't let the first pages stop you ... he starts out with vane control under the motors ,,but soon finds that he doesn't need the vanes and takes them off and still flys well
Middle of page 5 Vtolman gives the specs to his bird ... :
http://www.rcgroups.com/forums/showt...=440470&page=5
motor size and esc / props etc.
Good luck ,,, hope this helps some .
Old Oct 31, 2009, 09:50 AM   #21
v22chap's Avatar
Here are a few pix
I am trying to get the videos up ,,but this new layout that they have don't accept the video files any more , and it erased the ones I had loaded yrs ago when he did this ,,will try to get them up on youtube I guess
Old Oct 31, 2009, 10:11 AM   #22
v22chap's Avatar
Here come the videos ;;; first how his controls work .
kingsleyscontrols (0 min 7 sec)
Old Oct 31, 2009, 10:16 AM   #23
v22chap's Avatar
flying in his living room
kingsleycircleslivingroom (0 min 8 sec)
Old Oct 31, 2009, 10:18 AM   #24
v22chap's Avatar
And outside and does a loop
Kingsleysvtoldoesloop (0 min 26 sec)
Old Oct 31, 2009, 10:21 AM   #25
v22chap's Avatar
Hope these help you ,,,, good luck
Old Nov 02, 2009, 07:22 AM   #26
F-111 John's Avatar
Nevermind, I see from post #1 that they are.
Last edited by F-111 John; Nov 02, 2009 at 09:04 AM. Reason: Stupid question about counter-rotating props.
F-111 John is offline Find More Posts by F-111 John   Reply With Quote
Old Nov 02, 2009, 12:24 PM   #27
v22chap's Avatar
F111
That is o.k. as it wouldn't have made any difference as the only controls he has on it right now is motor ESC's ... and not sure ,,but maybe a vtail mix on throttle for roll control ....
It aint going to happen until he gets rudder and pitch controls on there and then it will be minimal at least .
But he is learning and the best way ... try it and find out
Old Nov 07, 2009, 01:40 PM   #28
tungym's Avatar
It still suffers from the tip over problem (pendulum effect) with a bi-prop design. You can see from the Discovery Channel video link. I think it might have solve the problem, but it doesn't.
It is like a seesaw as the lift is close to the C.G. itself , nothing is goona dampen the pendulum.
tungym is offline Find More Posts by tungym   Reply With Quote
Old Nov 08, 2009, 09:29 AM   #29
so is it i have increase the length of the rod where my motor sits on?
Old Nov 08, 2009, 09:55 AM   #30
it doesn't matter how far the motor is from the pivot point, what matters is how far is the pivot point from the CG. the bigger the control arm, the greatest the control authority. But don't think for one second that this will make the plane more stable, it will only make the control inputs more effective. You have to think in terms of vectors of thrust and vector of gravity, remembering to take into account all vector components. The "pendulum effect" is an illusion, a plane can't hang from its prop because the prop tilts with the plane. You need something else there to keep it upright. Quick thumbs or some form of stabilization system, like hiller paddles.
Brandano is offline Find More Posts by Brandano   Reply With Quote
Help! Need expert opinion. Bothersome Engines 8 Jun 29, 2009 05:58 PM
Tiny motor choice. I need your expert opinion. MrFlyer Parkflyers 15 Apr 07, 2003 02:23 PM
Will this fit/work in Graupner Mini-Piper? Need expert help! ViperR Foamies (Kits) 9 Dec 09, 2002 01:56 PM
Wattage Hawk crashed on first flight due to Aileron problem, need expert advice! ericss Foamies (Kits) 7 Oct 02, 2002 08:58 AM
I need your opinion... snowman610620 Foamies (Kits) 0 Apr 27, 2002 04:34 PM
Bored? Want to fight?
Join the RCGroups clan!
