Old Oct 22, 2009, 02:37 PM
xxxvizard is offline
Find More Posts by xxxvizard
Joined Sep 2009
Super cub vs Super cub lp vs super cub lp bnf vs easystar.
Super cub vs Super cub lp vs super cub lp bnf with blade cx2 transmitter vs easystar(for a beginner who doesn't have a coach and has barely ever flown rc planes before).
xxxvizard is offline Find More Posts by xxxvizard
Old Oct 22, 2009, 02:40 PM
Belem is offline
Find More Posts by Belem
Foam flogger
Roseville, CA
Joined Apr 2009
I'd say the BNF wins as it's 2.4 ghz and has a aileron channel built in.
Belem is offline Find More Posts by Belem
Old Oct 22, 2009, 02:55 PM
AD. is offline
AD.
Find More Posts by AD.
AD.
Team Better Than Yours
AD.'s Avatar
London, UK
Joined Jul 2009
AXN clouds fly or if you want one from the list Supercub LP BNF
AD. is offline Find More Posts by AD.
Old Oct 22, 2009, 03:06 PM
John Sargent is offline
Find More Posts by John Sargent
John Sargent's Avatar
United States, IL, Aurora
Joined Sep 2007
Depends what price you are paying and what you want to do with it. There are probably some deals out there on the old faithful models.
John Sargent is offline Find More Posts by John Sargent
Old Oct 22, 2009, 03:29 PM
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
EasyStar is probably a bit faster and heavier than the SuperCub. Of course, it is far less "scale looking." The belly-landing nature of the plane, and its pusher prop offer lots of advantages for a newb. Plus, I hear the RTF version of the EasyStar comes with a decent (72 MHz) radio and uses standard components...
The only hop-up I'd suggest (from a stock RTF EasyStar) would be to use a large 2S lipo in place of the NiCd or NiMH battery pack. It's not like you need a large battery, but you'll need some extra weight up front, to get the CG right.
After you've flown the EZStar a bunch, you might also want to upgrade its motor to brushless. With the stock motor, you're best advised to avoid winds above, say, 5-8 mph.
rafe_b is offline Find More Posts by rafe_b
Old Oct 22, 2009, 05:23 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
Please try to refrain from posting threads that ask basically the same question.
Xpress.. is offline Find More Posts by Xpress..
Old Oct 22, 2009, 06:27 PM
realtimerecon is offline
Find More Posts by realtimerecon
Real Time Recon
realtimerecon's Avatar
smith mt. lake VA.
Joined Jan 2007
I say, buy the parts that make up the body of the S.C. & build it the way U want.The parts that are checked off,for a total of $62.00...RTR
realtimerecon is offline Find More Posts by realtimerecon
Old Oct 22, 2009, 07:57 PM
rafe_b is offline
Joined Jan 2009
^^^ Yes, I agree -- by all accounts, the SuperCub is an excellent airframe, and $62 is about the going price for a foam ARF of that size. Building it from parts makes sense.
Old Oct 23, 2009, 01:27 PM
Smokescreen38 is offline
Find More Posts by Smokescreen38
Checking CG is for NERDS!
Smokescreen38's Avatar
Joined Jun 2005
The Supercub is a honey, no doubt... but I have about 20 planes including fast EDFs, scale warbirds on steroids, etc... and I always come back to my Easystar andf I long ago got bored and parted out my BL/lipo Hobbyzone Supercub.
Compared to the Supercub, the Easystar is an elegant, graceful and efficient flyer...on the stock brushed motor, it flies fine but with the drop-in F27 StrykerC BL motor, it has an incredibly broad flight envelope on 3s- from almost gymnasium fly-able to a high speed cruiser.
This plane will be the one that earns its spot in your transmitter's memory...Mine is my all weather flyer- it takes off brilliantly from powdery snow, thermals extremely well for a trainer-type plane and will fly forever on a 2200 pack. I have documented a 1+ hour flight with no help from thermals.
So- of the two planes, the Easystar wins in my book...
...but it will require you to assemble the kit (very easy...but still) and source your own electronics...which is not an easy task for a first plane.
Hopefully this will help:
ARF kit:
http://www.horizonhobby.com/Products...odID=MPU214192
Multiplex's suggested power system:
http://www.horizonhobby.com/Products...odID=MPU993211
Alternatively:
Stryker motor:
http://www.horizonhobby.com/Products...ProdID=PKZ4216
Turnigy ESC:
http://www.hobbycity.com/hobbycity/s...eed_Controller
Prop:
http://www.horizonhobby.com/Products...odID=APC06055E
A pair of Hobbycity's finest 9g servos:
http://www.hobbycity.com/hobbycity/s...?idProduct=662
battery:
http://www.valuehobby.com/product_de...d=8&item_id=30
would also fly fine on:
http://www.valuehobby.com/product_de...d=8&item_id=88
Any Spektrum rx (if that's what you're using)
http://www.horizonhobby.com/Products...rodID=SPMAR500
Glue:
http://www.horizonhobby.com/Products...ID=MEUM300M1OZ
battery connectors:
http://www.horizonhobby.com/Products...ProdID=WSD1300
Smokescreen38 is offline Find More Posts by Smokescreen38
Old Oct 23, 2009, 01:59 PM
rafe_b is offline
Joined Jan 2009
The Turnigy 2835 inrunner -- usually the 2200 Kv version -- is a perennial favorite for powering the EasyStar. If I were building one again (from an ARF kit) I'd use that from the get-go. Fantastic little motor, with 3S lipo and APC 6x4 prop.
Old Jan 06, 2010, 12:38 PM
MyMonkey is offline
Find More Posts by MyMonkey
Joined Jan 2010
So, for a true beginner most here would recomend the Easy Star over the Super Cub LP?
MyMonkey is offline Find More Posts by MyMonkey
Old Jan 06, 2010, 01:08 PM
donsinger1 is offline
Find More Posts by donsinger1
aka KF7DS
United States, OR, Portland
Joined Nov 2009
No, Super Cub. More responsive than Easystar in my experience and just fun to fly. I have crashed and built quite a few and when I fly and take two planes, one is always the SC.
donsinger1 is offline Find More Posts by donsinger1
Old Jan 06, 2010, 02:02 PM
Silver Streak is offline
Find More Posts by Silver Streak
Joined Feb 2005
I don't have the experience of others in the thread, but when I'm bored and want a change of pace my SC is where I go back to. If I'm at the field alone and the wind is light I get a kick out of doing hammerheads on either end of the runway with touch and goes in between. I do wish it had more power and it may be time for a new motor or BL/lipo conversion.
Silver Streak is offline Find More Posts by Silver Streak
New Product finally a new Super Cub LP BNF. MerlinKing Beginner Training Area (Aircraft-Electric) 73 Jul 31, 2011 12:29 PM
Discussion Easy Star vs Super Cub rel North Coast Electric Flyers 16 May 10, 2008 09:48 AM
Discussion Super Cub vs. Super Decathlon thrashaero Parkflyers 3 Aug 15, 2007 01:06 AM
Discussion HZ Super Cub vs. PZ Slo-V biphfyt Beginner Training Area (Aircraft-Electric) 9 Nov 03, 2006 12:48 AM
Super Decathlon vs the J-3 Cub Travy Beginner Training Area (Aircraft-Electric) 7 Mar 01, 2005 06:41 AM
