Old Oct 22, 2009, 12:15 PM
lichy's Avatar
Joined May 2009
might a bandpass filter help with 2.4 V-Tx locking out FASST Rx?
Hey Guys,
So everybody nows, using a 2.4GHz Video Transmitter will make FASST lock out.
I have made a test on a cheap 80$ Spektrum Analyzer, and it looked like this:
Well I'm not an expert, but to me this looks like these two won't interfere with each other, but in fact, they do. So hf-noob me would say, Fasst locks out, because the VTx that is like 40cm away from the Fasst antennas shouts so loud, that the receiver can't hear the transmitter on the ground anymore. I learned the basics of electronics in school, and I know that there is an electronic component that's called a Bandpass-Filter. As far as I understood, using a bandpass, you could filter the frequencys from 2460 to 2500Mhz, so the Fasst receiver wouldn't hear it anymore, meaning it would be able to operate like without the VTx.
So as I said, I know that there is a bandpass component, but I don't know if there is one in the right size, that in fact filters frequencies above 2460 MHz, and I also don't know if this would solve the problem at all.
Is there anybody that is familiar with the matter and would be so kind to exlain it to me? That would be awesome
regards,
Wolfgang
lichy is offline Find More Posts by lichy
Old Oct 22, 2009, 12:30 PM
Netherlands, NH, Edam
Joined Jul 2004
No, won't work, as a bandpass filter hasn't got steep enough filter slopes, nor the small bandwidth required to do it. Just pick another frequency for RC control or video and stop trying to get 2.4 + 2.4 to work, as you will never get the range or flexibility the other solutions offer.
Cheers,
Sander.
ssassen is offline Find More Posts by ssassen
Reply With Quote  (Disabled)
Old Oct 22, 2009, 01:22 PM
JettPilot's Avatar
Miami
Joined Apr 2005
A bandpass filter will NOT work, because the video and the FASST system are on the SAME band, the filter will pass 2.4 GHZ video, not block it....
JettPilot is offline Find More Posts by JettPilot
Site Sponsor
Old Oct 22, 2009, 05:33 PM
Flying FPV from the lab.
aaron_gx's Avatar
Canada, AB, Lethbridge
Joined Jun 2008
I think trappy said he had great luck with 2.4G vtx on channel 8, avoiding video interference from other's radios, and vice-versa. I know there are a few vtx's that only support 4 channels.
But, sander is right, dont try and force enemies to get along.
aaron_gx is offline Find More Posts by aaron_gx
Old Oct 22, 2009, 05:51 PM
trappy's Avatar
Austria
Joined Feb 2007
In all cases you need a R/C link that outperforms video in every situation (distance, LOS, object penetration). This means R/C on a lower frequency with better antennas then the video. Having twice the same frequency will get you into trouble even if you get it working.
aaron_gx: Yup, no interference from 2.4ghz buddies. Futaba FASST I had the guy talking to me sitting right next to my patch antenna. Only realized he was on 2.4ghz after we both landed. Spektrum I did get the odd white line ... once every 2 or 3 seconds.
trappy is offline Find More Posts by trappy
Old Oct 22, 2009, 06:30 PM
mmormota's Avatar
Budapest
Joined Jul 2003
While in theory such a filter is possible, Sander is correct, in real world a filter with acceptable size and price can't be steep enough.
The best separation you can get is setting the switch in the Fasst Tx to "France", this skips the highest channels from the hopping. And set the video Tx to the highest channel. Unfortunately it's not enough, the range is low and there is interference in the picture as well.
Just choose different frequencies for the video and control, no better solution this time.
Maybe later someone develops a time multiplex solution, a wi-fi or similar system for our hobby.
mmormota is offline Find More Posts by mmormota
Old Oct 23, 2009, 01:26 PM
lichy's Avatar
Joined May 2009
Thanks a lot for these great replies guys! I think I'm pretty clear about the situation now.
cheers!
Wolfgang
Old Oct 23, 2009, 11:31 PM
videocruzer's Avatar
Victoria BC Canada
Joined May 2008
I took one of the 2.4 systems and asked one of the guys at the radio shop to put it on the scope. the first thing he said was even if we had the equipment that was fast enough to see the hopeing. even if we new where to look you would not even see it.
anyway its what he said
videocruzer is offline Find More Posts by videocruzer
Old Oct 24, 2009, 03:26 AM
Joined Jul 2004
A FHSS transmitter is almost impossible to trigger on with a simple scope, that doesn't mean there's not signal being transmitted (otherwise your RC control wouldn't work). Ask the guy to try again with a high bandwidth spectrum analyzer and you'll see the FHSS hopping merrily along the band.
Cheers,
Sander.
Old Oct 24, 2009, 08:02 AM
jab
Unregistered User
Joined Aug 2007
I can confirm what aaron_gx mentioned. If you have a 8ch 2.4ghz video tx there is no radio interference from FASST on the 8th channel since it is just outside the FASST frequency range. But as many has mentioned, far from ideal with regard to signal reception and safety.
jab is offline Find More Posts by jab
Discussion Help with Fireworks 4.2 Ja9 Hand Launch 7 Sep 28, 2009 09:41 AM
Discussion wingdragon with 2.4 transmitter help dazzzer1 Parkflyers 2 Feb 07, 2009 05:03 PM
Help with 3-4 bladed props and MPJET 25/25 Jason Novak Power Systems 4 Sep 10, 2004 03:57 PM
Katana with 2.4 will seperate DERF-54 Aircraft - Fuel - Airplanes (FS/W) 8 Jan 01, 2004 11:54 AM
need help with 2 bl fan setup billyboy Electric Ducted Fan Jet Talk 19 May 01, 2003 02:04 PM
