Old Nov 08, 2012, 11:55 PM
gordonzo is offline
Find More Posts by gordonzo
Different fly 4 different guy
gordonzo's Avatar
Joined Jan 2011
Originally Posted by Aphro View Post
. . . every time I fly it I have to spool it and land it again and then remove and reinstall battery. If I do not do this it tends to rotate on the rudder axis to the right. . .
Originally Posted by RoboHeli View Post
Hi. I have the same problem. Easy to apply the fix though... My drift isn't bad though. It is just too much drift to fix with trim.
OK I just tried my Tandem and it does the same thing! I never noticed that before. That's very strange.
regards . . . g
ps: Anybody seen this pic before? I still have 3 of the 4. Anyone need a part that is hard to find (except for pcb, as I have only 1 spare) - let me know.
gordonzo is offline Find More Posts by gordonzo
Old Nov 09, 2012, 12:31 AM
Aphro is offline
Find More Posts by Aphro
ChuckTseeker Super Fan
Aphro's Avatar
Joined Jan 2012
It's the strangest thing... every once in a great while it will work without having to reinstall batt... but it's probably only like one out of 5-8 flights... it makes absolutely no sense
Aphro is offline Find More Posts by Aphro
Old Nov 09, 2012, 09:00 AM
RoboHeli is online now
Find More Posts by RoboHeli
Safety : practice & promote!
RoboHeli's Avatar
Joined Dec 2011
I'm guessing it's a bug in the firmware or else a quirk in the gyro hardware.
RoboHeli is online now Find More Posts by RoboHeli
Old Nov 13, 2012, 10:09 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
Hey! Still flying mine..anyone using a DX6i and want to share there settings?
Jake8131 is offline Find More Posts by Jake8131
Old Nov 13, 2012, 10:12 PM
stuball56 is offline
Find More Posts by stuball56
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
Right here, I like these, although I did tweak very slightly a couple of the settings.
stuball56 is offline Find More Posts by stuball56
Aphro is offline
Aphro's Avatar
Joined Jan 2012
I fly mine with no expo and no D/R... I just have to install the battery twice to get the gyros to function properly.... must be a fail safe feature just in case you may have accidentally installed the battery the 1st time
Old Nov 13, 2012, 10:14 PM
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
Weird. I don't seem to ever have to do this. Either that or I am so inexperienced that I don't know any better, lol. But I can fly it pretty well, so must be working.
Old Nov 13, 2012, 10:15 PM
RoboHeli's Avatar
Joined Dec 2011
Yup. As has been discussed before, mine does the same. I have a slight rudder bias that goes away if I "reboot" the heli after flying it for a few seconds. Weird. Must be a systematic firmware bug or something.
Old Nov 13, 2012, 10:34 PM
Aphro is offline
Aphro's Avatar
Joined Jan 2012
If she doesn't "rudder" around on her own you are a lucky guy... wanna trade???
Old Nov 13, 2012, 11:37 PM
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
How fast are you meaning for the "ruddering around"? Mine does do that, but slowly, so I thought it just out of trim?
Old Nov 13, 2012, 11:42 PM
RoboHeli's Avatar
Joined Dec 2011
When I first plug the battery in and take off, mine yaws slowly in one direction. I can't trim it out on my TX. To fix it, all i have to do is land, pull the battery out for a few seconds, plug it back in, and then from that point on the heli stays perfectly still at center stick.
Old Nov 13, 2012, 11:57 PM
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
Well, I guess I do have that. But not every time. Is it every time with you? I just flew it and it did not seem to have it this time. But I did have it before a few times and tried to trim it but it didnt help.
Old Nov 14, 2012, 12:01 AM
Aphro is offline
Aphro's Avatar
Joined Jan 2012
Mine slowly rotates to the right, but it takes almost full left rudder to make it hover stationary. Doesn't matter if I use the rudder stick or the trim adjustment. If I unplug the batt and plug it back in after adjusting the trim to compensate for right turn, it will then rotate to the left. Just plug battery in, take off and land... re-insert batt and she flies perfectly... it is quite odd...
Better than never flying perfectly... I guess
Old Nov 14, 2012, 12:02 AM
Aphro is offline
Aphro's Avatar
Joined Jan 2012
Just saw that part... no it's about 5 out of 8 flights. Sometimes it will work straight away... but more often than not it doesn't.
Old Nov 14, 2012, 12:03 AM
Which way is up?
stuball56's Avatar
Michigan, USA
Joined Mar 2008
Do these have the same controller boards as the regular MCX or MCX2?
Article E-flite Blade mCX Ultra-Micro Helicopter RTF & BNF Review Michael Heer Coaxial Helicopters 346 Nov 06, 2010 12:30 PM
Discussion E-Flite Blade CX 2 Coaxial Heli or Falcon 3D CP pcasamento Micro Helis 2 Jan 29, 2008 09:24 PM
For Sale Brand New E-Flite Blade CP Helicopter AirMicro Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2005 08:16 AM
