Old May 03, 2011, 05:08 PM
Grejen is offline
Find More Posts by Grejen
IAMCANADIAN
Grejen's Avatar
Canada, BC, North Vancouver
Joined Jul 2002
Originally Posted by RHough View Post
I have a bit of a brain teaser for the tuners.
There is some coupling of controls in the tandem. I'm a bit fussy about making any mechanical trim adjustments I can so the TX trims are as close to center as possible.
Here is what the Heli does:
Right gives Right + Back
Left gives Left + Foreward
Right Piros = gain in altitude
Left Piros = loss of altitude
Very slight Left drift
Anyone thought this out? I think I've read every post in the tandem threads and I haven't seen a tuning/troubleshooting guide. Is there any interest?
R
LOL I just figured that's the way tandems fly and adjust when controling it. Left drift can be simply trimmed out. I've noticed as it collects wear and tear the flight trim changes a bit. My rear lower rotor gear (outside shaft) has a nice sticky spot or two.
Grejen is offline Find More Posts by Grejen
Old May 03, 2011, 06:15 PM
RHough is offline
Find More Posts by RHough
Old
Joined Nov 2010
I have to laugh too. The darn thing is so light that it reacts to the dog farting.
For what its worth:
Forward Rotor Swash Adjustments:
Turns out (longer control rod) = Left Roll
Turns in (shorter control rod) = Right Roll
Aft Rotor Swash Adjustments:
Turns out (longer control rod) = Right Roll
Turns in (shorter control rod) = Left Roll
R
RHough is offline Find More Posts by RHough
Old May 03, 2011, 07:36 PM
Jake8131 is offline
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
You dont have adjust the servo rods on the front or aft...just pop the one on the 5n1 and turn it either way.
Jake8131 is offline Find More Posts by Jake8131
Old May 03, 2011, 08:57 PM
RHough is offline
Old
Joined Nov 2010
That works to correct a left/right drift (roll). To correct for a roll induced yaw, you have to adjust the front/rear links.
If you have to put left or right (roll) trim in and no rudder (yaw) trim, adjusting the center link works.
If you have just rudder trim or both rudder and roll trim on the tx, you can trim it out using the front and back links.
The two rotors interact and finding the settings that require the least tx trim makes the heli fly much better. I'm getting very close to no drift and no yaw with equal speed piros both directions with no altitude change.
I haven't figured out how to get the gyro to get happy without a short flight, land, reset and fly routine. Once it is warmed up and happy it is very stable. There is some change in yaw trim required as the voltage changes during a flight this seems to be "normal".
I've gone from having to add both rudder (yaw) and aileron (roll) trim to near center hands off hover. Once that's dialed a click or two of forward or aft trim will make it perfect.
R
Old May 04, 2011, 07:26 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Share you settings, please.
Old May 10, 2011, 03:46 PM
Grejen is offline
IAMCANADIAN
Grejen's Avatar
Joined Jul 2002
Jake - Those settings/adjustments are probably unique to the particular airframe. Something you have to 'play' with. If the body could be removed without pulling rotors and lighting wires I'd probably do a lot more fiddling with it.
R - My CX seems to have a similar yaw gyro issue. Towards the end of the flight (I don't overwork my batteries) it seems to need tons or CW yaw trim then next time I fly it I have to take it all back out.
Old May 10, 2011, 11:06 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
I've got mine pretty good now...just a little forward drift, but right yaw doesn't kick itself in till about 4mins into the flight which I am about done with it.
Old May 14, 2011, 12:41 AM
Glenstr is offline
Find More Posts by Glenstr
Glenstr's Avatar
Canada, AB, Lac La Biche
Joined Aug 2010
Just wondering, how does one change the inner shaft that holds the stabilizer bar? Does the plastic body have to come off? Is it a hard job?
thanks!
Glenstr is offline Find More Posts by Glenstr
Old May 14, 2011, 04:40 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Small fingers. Remove the lower gear and the inner shaft will pull right out.
Old May 15, 2011, 01:33 PM
Glenstr is offline
Glenstr's Avatar
Joined Aug 2010
I see it now, there is NO way my big meat-hooks are getting that out. Going to put some cut's in the back of the fuselage cover so I can just fold it down..
update: that did the trick & lesson learned - keep college aged boys away from my toys, I have two of them and within a day both my Night Vapor and Heli were grounded!
Old May 15, 2011, 08:46 PM
Jake8131 is offline
Jake8131's Avatar
Joined Dec 2010
Try swapping out the 5n1!!!! Real fun!
Old May 16, 2011, 04:51 PM
RHough is offline
Old
Joined Nov 2010
Well ... after spending some time waiting for a new swash plate to replace the one I broke making adjustments ...
Yep ... some of it is just the way it flies.
I took the body off and made sure the frame was straight and the rotor shafts are parallel.
Then I made sure that with the Tx trims centered that both swash plates were level (90 deg to the rotor shafts).
There is just a bit of fore - aft movement when left/right cyclic is applied but no continuous fore - aft after sideways flight is established ... so much for all my "tuning" ...
I'm left with a tiny drift that should be adjustable at the servo link (as Jake suggested) and a slightly faster left piro than right.
Next up is a mount for a 500 mAh battery ... the 120SR uses a single cell 500 mAh battery and comes with a harness that plugs into the board ...
12 min+ flight time!
The 500 mAh battery weighs only 50% more than the 250 mAh that is stock ... so double the capacity for a small weight gain.
I wish there was enough demand for this heli for Blade to use some of the upgraded programming and bits from the mCX2 ... the throttle and gyro on the mCX2 are so much better ... if the mCX2 upper swash was a separate part you could have the "high rate" option on the tandem ...
Does anyone know a cure for the gyro? Fly for 30 - 40 seconds, while fighting the yaw. Land, reset the gyro, and it is just fine for the rest of the flight. I'm concluding that it is just the nature of the beast.
R
Old May 24, 2011, 01:16 AM
rocco987 is offline
Find More Posts by rocco987
R0CC0336
rocco987's Avatar
USA, AZ, Tucson
Joined Dec 2009
I bought one of these and love it aside from all the obvious previous listed issues. My dad got one and noticed the rear motor controlling the lower blades was bad. It would not turn. If you gave it a spin it would work but did not have enough power to fly. When you cut throttle it would not spin again.
I took a used motor from a Blade mCX and extended the wires and tried that. The motor worked visibly as you think it should but the heli would spin hard left and crash backwards. I am thinking there may be some importance in the uniformity of front and rear motor capacity/performance, correct? If the rear motor is used and not creating as much lift as the front...crash!!! He called HH who is sending a new motor but has yet to install it. What do you think, bad motor causing issues or possibly something bigger?
rocco987 is offline Find More Posts by rocco987
Old Jul 22, 2011, 02:36 PM
Klippie is offline
Find More Posts by Klippie
Klippie's Avatar
Scotland
Joined Oct 2010
Tandem Rescue Good Price For UK members
I recently bought a new RTF Tandem Rescue and thought I'd pass on the great price to our UK members - http://www.danielstores.co.uk/p/7666...cro-helicopter - the store was great to deal with and I'd happily buy from them again.
When I bought the Tandem I also bought a DX6i (also a good price) and they threw in a spare battery for the Tandem for free...
Klippie is offline Find More Posts by Klippie
Old Jul 28, 2011, 09:28 AM
jrtubb is offline
Find More Posts by jrtubb
I Fly!
jrtubb's Avatar
United States, AL, Huntsville
Joined Jan 2011
Just wanted to say thinks for this great thread. I bought one of these as my first RC Helicopter a few weeks ago on an impulse buy as the sale price was great at my LHS. I've been flying RC planes for a number of years and have stayed away from helicopters.
After a pretty frustrating initial flights (little control, turned left, impossible to hover, etc) I read through this entire thread and tried the twist solution (didn't work), then I found the recommendation to re-center the trims and rebind to the helicopter. It is now a pretty decent flier, hover still requires significant right stick back input, and right turns are not bad, left turns are fast. I've noticed that abrupt control inputs causes extremely quick lose of attitude.
So like planes, smooth combined controlled inputs are key.
jrtubb is offline Find More Posts by jrtubb
Article E-flite Blade mCX Ultra-Micro Helicopter RTF & BNF Review Michael Heer Coaxial Helicopters 346 Nov 06, 2010 12:30 PM
Discussion E-Flite Blade CX 2 Coaxial Heli or Falcon 3D CP pcasamento Micro Helis 2 Jan 29, 2008 09:24 PM
For Sale Brand New E-Flite Blade CP Helicopter AirMicro Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2005 08:16 AM
