Old Feb 12, 2011, 02:09 AM
scotsoft is offline
Find More Posts by scotsoft
Master Of My Universe
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
I take it you are still crashing to keep breaking your inner shafts
It always seems to be flybars with me
Originally Posted by jimmer109 View Post
Hey, my inner shaft replacements broke again, and now my only local hobby ship, 8 hours away, only sells stylish metal ones for 20$ each, and both are broke. i'm having a hell of a time with this heli.
scotsoft is offline Find More Posts by scotsoft
Old Feb 12, 2011, 03:00 AM
THE_SHRUB is offline
Find More Posts by THE_SHRUB
Joined Dec 2010
well if you keep breaking them then its a no brainer! Get the shiny sturdy ones!!!
THE_SHRUB is offline Find More Posts by THE_SHRUB
Old Feb 12, 2011, 03:26 AM
DoomsDay is offline
Find More Posts by DoomsDay
DoomsDay's Avatar
Charlotte Douglas, NC
Joined Sep 2003
That was the first thing that broke on mine. I got in a weird TB effect and it went down and hit just right and snapped off one half of the front flybar. I was really shocked as it wasn't that bad of a hit, I guess it just hit at the perfect angle to snap it.
DoomsDay is offline Find More Posts by DoomsDay
Old Feb 12, 2011, 03:36 AM
UMASS is offline
Find More Posts by UMASS
Magnolia, MA.
Joined Dec 2010
Jimmer109: You are not serious! Let me get something straight here, you traveling 8 hours (each way) to score a part? You do know that you can buy parts on something called the internet...right?
UMASS is offline Find More Posts by UMASS
Old Feb 12, 2011, 08:55 AM
CCbusa05 is offline
Find More Posts by CCbusa05
CCbusa05's Avatar
USA, NV, Carson City
Joined Sep 2006
Yikes...............with the price of gas nowadays, he could overnight air freight and still be money ahead!
CCbusa05 is offline Find More Posts by CCbusa05
Old Feb 21, 2011, 05:06 AM
Jake8131 is online now
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
I got four of them...3 of them want to yaw to the right.....the 4th on just goes backwards...bad 5n1?
Jake8131 is online now Find More Posts by Jake8131
Old Feb 22, 2011, 11:23 PM
el guapo is offline
Find More Posts by el guapo
three amigos
Joined Dec 2010
mine was crap out of the box. I almost gave up on it.
the biggest issue is that it would jiggle when I would give small aileron input. sometime it would even go the wrong direction until large input was given.
anyway, I fixed mine. the swash pivots were too loose. and the swash could move any direction it wanted with small servo input. very inconsistent.
on a MCX the swash is sported by two ball joints and one guide. but on the tandem, its held by two guides and one ball joint and only should pivot on one axis. my guides where very loose..
so.... I pinched the two guide slots that the swash should pivot on. made a huge difference. it flys much more precise.
el guapo is offline Find More Posts by el guapo
Old Feb 23, 2011, 02:41 AM
scotsoft is offline
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
Those are some excellent tips you posted there, thank you
Old Feb 23, 2011, 04:52 AM
Jake8131's Avatar
Joined Dec 2010
I noticed this, the longer it flies, the more it yaws to the right...3 of mine do that...the 4th one just goes backwards and it is going to the LHS...I checked everything on it, changed the blades and flybars, but still does the same thing....confusing....!
Old Feb 23, 2011, 01:32 PM
el guapo is offline
three amigos
Joined Dec 2010
did someone else figure that trick out too, sorry if its a re-post? but there are a lot of post to got thru in this thread.
It was real easy to pinch the two guides with some needle nose pliers. my tandem flies really really really good now. I still have to use a bunch of rudder trim. but with it all trimmed out, it is rock solid.
Old Feb 24, 2011, 12:46 PM
swlee is offline
Find More Posts by swlee
United States, CO, Louisville
Joined Jan 2011
Newbie here. I'm about to make the move from 3ch helis to 4ch. I've ordered a Blade mCX Tandem RTF (should be here in a day or two), and am also planning to get an mCX2. I'm sure I'll have lots more questions once I start flying, but here's my first:
It appears that both the Tandem and mCX2 (in the RTF versions) come with the same MLP4DSM 4-channel transmitter. Can a single transmitter easily control both helis, or would I need to re-bind every time I switch from one to the other? (If so, that would seem to argue against getting the BNF version of the mCX2).
Thanks!
Steve
swlee is offline Find More Posts by swlee
Old Feb 24, 2011, 01:36 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Thanks!
Steve
Rebinding is just a matter of plugging the RX batery in and turning on the TX with the throttle pushed in.
Should take less than 30 seconds to swap binds and be ready for flight from one to the other.
The difference in trim will probably be a bigger issue. If you need a RTF TX, you can buy a used one for less than $20 shipped.
UNGN is offline Find More Posts by UNGN
Old Feb 24, 2011, 02:01 PM
swlee is offline
Joined Jan 2011
Ahh - I hadn't thought about the trim settings... Thanks!
Old Feb 24, 2011, 04:36 PM
scotsoft is offline
scotsoft's Avatar
Newcastle, UK
Joined Jul 2010
You would still have to bind each model when you changed from one to the other with the DX6i but that only takes seconds to do
The advantage with a DX6i, or similar transmitter, is all your trim settings would be preserved
Thanks!
Steve
Old Feb 24, 2011, 06:20 PM
gaper is offline
Find More Posts by gaper
Joined Jan 2011
You don't have to rebind to fly each helicopter. In fact, you could fly them both at the same time from the same transmitter. I flew an mCX2 and an mSR with a DX5e and just kept the trim set for the mSR.
Thanks!
Steve
gaper is offline Find More Posts by gaper
Article E-flite Blade mCX Ultra-Micro Helicopter RTF & BNF Review Michael Heer Coaxial Helicopters 346 Nov 06, 2010 01:30 PM
Discussion E-Flite Blade CX 2 Coaxial Heli or Falcon 3D CP pcasamento Micro Helis 2 Jan 29, 2008 10:24 PM
For Sale Brand New E-Flite Blade CP Helicopter AirMicro Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2005 09:16 AM
