Old Jan 29, 2010, 12:04 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Originally Posted by Shadrack View Post
Some adjustments that I made really helped.
First, I did the DX7 settings that were posted previously, of course mine will be a little bit different than others, but for the most part they worked well.
My issue was when turning left, the tandem would drop. Turning right (little slower but not bad) it would climb.
I created a 3rd mix on the DX7 that mixed rudder > throttle
Lowered throttle a bit when rudder was right....increased it a bit when I turned left.
Pretty much stays in place now when I use rudder.
My MCX does this much worse than my tandem, though its a little better after I replaced both motors with new. It's just the nature of Coax heli's.
UNGN is offline Find More Posts by UNGN
Old Jan 29, 2010, 01:13 PM
Shadrack is offline
Find More Posts by Shadrack
Mini Obsessed
Shadrack's Avatar
Winnipeg
Joined Feb 2002
Thing is that with a computer radio, you can mix a lot of it out. Kind of like coupling when you knife edge a plane. Easy to mix out.
Shadrack is offline Find More Posts by Shadrack
Old Jan 29, 2010, 08:31 PM
dimastep is offline
Find More Posts by dimastep
Joined Jul 2009
Just removed that ball (like from the ball bearing) attached at the nose of the helicopter (under the canopy). My guess is they put it there to balance the helicopter for better FF. But since I use 400mah battery which is heavier I figured removing a little weight is good.
I now can last for 9min 30 sec in the air, land safely and still not hit the LVC.
dimastep is offline Find More Posts by dimastep
Old Jan 29, 2010, 08:38 PM
douglas4 is offline
Find More Posts by douglas4
"If it ain't broke,fly again"
douglas4's Avatar
Canada, ON, Greater Sudbury
Joined Aug 2006
I did it again
Well I did it again. I just bought this:
http://www.rcgroups.com/forums/showthread.php?t=1174573
I bought the first one he sold that was BNF now I have the RTF one he was selling too. "Whohoo". I must be crazy addicted. I don't know what I did with the one I have now but I'm getting better right turns..not great but they are there. All I did was turn both links out 2 turns. I'm still gonna get the esky one too once helidirect has them in stock. I'm really linking this micro-heli idea..as it is way less expensive than tail rotor machines with all their complicated setting up and stuff. 3 years into this hobby and I'm down to this. Oh well micro helis are fun too.
douglas
douglas4 is offline Find More Posts by douglas4
Old Jan 29, 2010, 08:41 PM
douglas4 is offline
douglas4's Avatar
Joined Aug 2006
what..?
I just looked under the hood and I don't see anything there...? I have 2 small brass weights inside the fuselage on either side of the main gear for FF flight.
doug
Old Jan 30, 2010, 06:20 AM
livonia bob is offline
Find More Posts by livonia bob
Heli collector
livonia bob's Avatar
United States, MI, Livonia
Joined Apr 2009
Originally Posted by erdnuckel2 View Post
That might of course be possible, but then it should be a) mentioned and b) still wouldn't compute in my book ... the length of the two walkera rotors together is over 460mm ... and they reach over the fuse front and back ... I just don't get it ...
Sorry
Does this help any..
livonia bob is offline Find More Posts by livonia bob
Old Feb 01, 2010, 09:05 AM
extracrispy is offline
Find More Posts by extracrispy
Joined Sep 2007
Size differences...
Thought these photos might help. First is of the Esky Tandem Rotor and second is of the *new* Walkera YS8001. Haven't seen the Walkera for sale yet anywhere.
Assuming that the TXs are relatively the same in size they look to be very similar.
extracrispy is offline Find More Posts by extracrispy
Old Feb 01, 2010, 11:47 PM
Ronon is offline
Find More Posts by Ronon
Joined Jan 2009
Does anyone know if flying 150ís in the Tandem Rescue shortens battery life due to the rapid battery drain as opposed to flying them in an mSR or mCX? I fly about 2:50 Ė 3:00 on 150ís in the TR to avoid LVC.
Ronon is offline Find More Posts by Ronon
Old Feb 03, 2010, 07:00 PM
CrashAndBurn! is offline
Find More Posts by CrashAndBurn!
Joined Feb 2010
Batteries
Why not just pick up a couple of extra 250mAh batteries? I just did today. Check with Ultimate Hobbies.
- Crash
CrashAndBurn! is offline Find More Posts by CrashAndBurn!
Old Feb 03, 2010, 07:48 PM
Ronon is offline
Joined Jan 2009
- Crash
I just placed an order. Thanks for the tip! Now I can save my 150ís for the MSR and MCX. I noticed the 150ís are really hot after a 3:00 minute flight and that canít be doing them any good.
Old Feb 05, 2010, 06:31 PM
douglas4 is offline
douglas4's Avatar
Joined Aug 2006
dead thread
Did this thread die..? whats new guys with your tandems...?
doug
Old Feb 06, 2010, 03:17 AM
Ronon is offline
Joined Jan 2009
Havenít flown it as much because Iím waiting for some extra 250 batteries to arrive Thursday.
Old Feb 06, 2010, 10:59 AM
douglas4 is offline
douglas4's Avatar
Joined Aug 2006
Well I have another RTF Tandem coming from "patternflyer" (i bought both he was selling), so I'll have 2 birds now and 2 batterys. Greathobbies here will have extra batterys in stock soon.
Old Feb 06, 2010, 12:16 PM
Ronon is offline
Joined Jan 2009
2 Tandems would be nice and if one gets smashed up you have some spare parts handy. I like to fly at least 4 batteries and my current situation of a 250 followed by a couple shorter 150 flights doesn't cut it IMO. When they release a new Helicopter like the Tandem Rescue they should make sure there's plenty of spare batteries available first.
Old Feb 06, 2010, 03:01 PM
douglas4 is offline
douglas4's Avatar
Joined Aug 2006
charging issue
OK I have a charging issue. When I charge my battery...the charger stays in the almost charge mode. Its been charging for an hour now and still not finished. OK any ideas as to what the problem is I'm pissed here...? I'm only running the battery 6 1/2mins what gives...?
douglas
Article E-flite Blade mCX Ultra-Micro Helicopter RTF & BNF Review Michael Heer Coaxial Helicopters 346 Nov 06, 2010 12:30 PM
Discussion E-Flite Blade CX 2 Coaxial Heli or Falcon 3D CP pcasamento Micro Helis 2 Jan 29, 2008 09:24 PM
For Sale Brand New E-Flite Blade CP Helicopter AirMicro Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2005 08:16 AM
