Old Jan 24, 2010, 01:23 PM
douglas4 is offline
Find More Posts by douglas4
"If it ain't broke,fly again"
douglas4's Avatar
Canada, ON, Greater Sudbury
Joined Aug 2006
linear servo
Originally Posted by Bowerz View Post
Just crank them up to 125, i just remembered that the Tandem doesn't use servo's for yaw so go ahead with the full throws.
Hoping of course I don't strip my linear servo. That would be disastrous...$72.99 CAD for a new E-board. I might add though working on this heli to try and adjust the linkages is a daunting task due to the micro size of the parts. Oh well, all part and parcel eh boys of helis, regardless of the size. he he
douglas4 is offline Find More Posts by douglas4
Old Jan 24, 2010, 02:57 PM
Ronon is offline
Find More Posts by Ronon
Joined Jan 2009
Does the Tandem Rescue handle outside flying very well? It looks like it could do some reasonable FFF but if itís anything like my mCX it wonít handle slight breezes very well.
Ronon is offline Find More Posts by Ronon
Old Jan 24, 2010, 03:19 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
Stripped servos can be repaired for $3, unless the servo controller on board itself is bad.
UNGN is offline Find More Posts by UNGN
Old Jan 24, 2010, 03:23 PM
Bowerz is offline
Find More Posts by Bowerz
No, I dont work for HH ;)
Bowerz's Avatar
Southampton, Hampshire, UK
Joined Sep 2009
I forgot that the yaw isn't controlled by the servo's, i may be wrong but i am pretty sure i'm correct (well there is no servo for yaw on my standard mCX) so just double check this to be sure. If i am, you're fine to crank it up as there is no servo to strip!
Bowerz is offline Find More Posts by Bowerz
Old Jan 24, 2010, 03:49 PM
douglas4 is offline
douglas4's Avatar
Joined Aug 2006
outside flight and servo strip
1) I don't think the tandem is capable of flying outside. Its way to light for that IMO.
2) I have battery on charge now started 4:06pm its now 4:39pm should be done soon and then I'll go downstairs and try it with the travel adjusts @ 120% first then try them @ 125% and we'll see.
douglas
Old Jan 24, 2010, 04:09 PM
douglas4 is offline
douglas4's Avatar
Joined Aug 2006
Hm..?
Well flight #7 and still slow right turns but not as slow as it was before so I guess I'll have to play with the rear linkage some more. All values @ 125% now and seems better and more maneuverable. OK back to the bench whilst I charger another battery.
douglas
Old Jan 24, 2010, 04:15 PM
dimastep is offline
Find More Posts by dimastep
Joined Jul 2009
douglas
Just want to clarify. Are you talking right turn ( as in Yaw, in other words turning the nose to the right) or right banking, as in sideway movement?
Reason I ask is that with my new replacement board from horizon my Tandem does slow banking to the right. But rotation is still fine either direction.
Sideway banking is controlled by servo. Yaw is only controlled by electronics and also motors (spinning differently)
dimastep is offline Find More Posts by dimastep
Old Jan 24, 2010, 04:16 PM
Bowerz is offline
Bowerz's Avatar
Joined Sep 2009
Don't put all values at 100%, what ever the servo's control (the roll i think) needs to stay at 100 otherwise you will damage the servo.
Old Jan 24, 2010, 04:43 PM
douglas4 is offline
douglas4's Avatar
Joined Aug 2006
roll
So you mean "aileron" (roll)....right...? Which value should be @ 100%...? What I mean is I can do long banking turns to the left...but the right banking turns as it were, is painfully slow. I can pirouette on axis both ways fine..its just the right banking turns are slow.
doug
OK as I was posting and reading the above I put the "aileron" (roll) back to 100% both ways. I also gave the rear linkage another turn out to lengthen it when I came back upstairs earlier. So have the battery on charge now and will go and give her another test flight.
You know if this thing is finicky like this I may just sell her and wait for the Blade SR to come out next month as I have the money in my Paypal account just waiting for the release.
Old Jan 24, 2010, 05:51 PM
DoomsDay is offline
Find More Posts by DoomsDay
DoomsDay's Avatar
Charlotte Douglas, NC
Joined Sep 2003
doug
And why would you do that? I mean the tandem is just for easy relaxed fun. The SR is a completely different type of flying. Mine has always had the slow right turn and slow right pirouettes and it doesn't really bother me much at all. I enjoy it for what it is, and thats just slow easy relaxing fun.
DoomsDay is offline Find More Posts by DoomsDay
Old Jan 24, 2010, 06:43 PM
douglas4 is offline
douglas4's Avatar
Joined Aug 2006
better
Originally Posted by DoomsDay View Post
And why would you do that? I mean the tandem is just for easy relaxed fun. The SR is a completely different type of flying. Mine has always had the slow right turn and slow right pirouettes and it doesn't really bother me much at all. I enjoy it for what it is, and that's just slow easy relaxing fun.
Well It does go more right now since I put the roll up to 110% and earlier adjusted the rear swash linkage. And you right for what it is I'm not going to bother trying to get it perfect. It is what it is and its just a "sh..."s and giggles" indoor flier. I guess I fell into the tweak it tills its perfect mindset. This web site can do that to you. lol.
Old Jan 24, 2010, 11:22 PM
Goanna is offline
Find More Posts by Goanna
United States, NY, New York
Joined Oct 2006
Blade MCX Tandem Rescue Right Turn Issues
Hello All, I just posted a video on youtube showing how I fixed the right turn problems with the Tandem Rescue.
E-Flite Blade MCX Tandem Rescue - Right Turn Issues Solved (1 min 20 sec)
Goanna is offline Find More Posts by Goanna
Site Sponsor
Old Jan 25, 2010, 01:34 AM
Ronon is offline
Joined Jan 2009
douglas
Iíve flown the MCX outside quite a bit and while it is vulnerable to light breezes I would think that having twin rotors might help the Tandem handle them a little better than an MCX. Maybe itís just too light.
Old Jan 25, 2010, 07:19 AM
UNGN is offline
Power Wheels Guru
UNGN's Avatar
Southlake, TX
I have both, and the Tandem can handle breezes and turbulent air much better than the MCX.
Flying both around the room, the tandem can easily blow the MCX to the ground, but the MCX barely effects the tandem. Also, the tandem is faster than the MCX.
Old Jan 25, 2010, 07:42 AM
Goanna is offline
Joined Oct 2006
I was flying mine outside the other day. I was flying it of of my 2nd story deck and took it pretty high into the air, well above my house. Seemed to handle pretty well outside. If it's nose into the wind it doesn't get affected too bad, and as long as it's not a really fast gust of wind, holding it sideways to the wind it still remains pretty stable, it just moves with the wind until you turn it nose first.
Site Sponsor
Article E-flite Blade mCX Ultra-Micro Helicopter RTF & BNF Review Michael Heer Coaxial Helicopters 346 Nov 06, 2010 12:30 PM
Discussion E-Flite Blade CX 2 Coaxial Heli or Falcon 3D CP pcasamento Micro Helis 2 Jan 29, 2008 09:24 PM
For Sale Brand New E-Flite Blade CP Helicopter AirMicro Aircraft - Electric - Helis (FS/W) 3 Jun 26, 2005 08:16 AM
