Go Back   RC Groups > Regional Forums > Argentina
Old Oct 21, 2009, 09:03 PM   #1
on a vacation
The introduction of WFLY 2.4GHz SET A
WFLY SET A(2.4GHz module with 9 channel 2.4GHz dual MCU, dual antenna receiver)
Model: WFTRFS
Application: Airplane, helicopter, glider, car, boat
Band: 2.400GHz-2.4830GHz( varies with different country and region)
Output power: ≤100Mw
Current drain: ≤150mA
Radio frequency working statue checking function
Fail Safe
Modulation: PPM/PCMS 1024 /PCMS 4096
Power: 9.6-12V
Dimension: 59×37×34mm
Weight: 40.9g
Model: WFR09S
Use in:airplane, helicopter, glider, car, boat
Band:2.400GHz-2.4830GHz ( varies with different country and region)
Receive sensitivity:-97dBm
Fail safe
Modulation:PPM/PCMS 1024/PCMS 4096
Power:4.8-6V
Dimension:44.8×27.9×16.39mm
Weight:14.8g
Dual MCU, dual antenna receiver:
Contains two receivers working independently
Features
Choose the optimum signal for antenna
More reliable
Quicker response
Better anti-interference
Longer range
Notes
For better preformance, place two antennas in 90 degree
Pls refere to the following specification of WFLY 2.4G
A.Hopping frequency is high Speed.
WFLY 2.4G adopted hopping frequency to DSSS technology and the hopping speed is 4 MS one time.
B. 2.4G receiver outputs high reliable PWM signal to digital servo. Oscilloscope can observe the details with nano second. But other brand receiver PWM signal is not so reliable compared with WFLY 2.4G.
C. High 4096 resolution, high response( with WFT09S and WFT08S transmitter).
D. Recognize PPM, PCMS, 4096 PCMS modulation automatically.
E. With hopping DSSS, WFLY 2.4G is high reliable working with 50 transmitter together.
WE STILL HAVE SET-B AND SET-C
  • Name: SET-A.jpg
WFLY is offline Find More Posts by WFLY   Reply With Quote
Discussion The introduction of WFLY 2.4GHz SET A WFLY India 0 Oct 19, 2009 11:09 PM
Discussion The introduction of WFLY 2.4GHz SET A WFLY Brazil 0 Oct 19, 2009 11:08 PM
Discussion The introduction of WFLY 2.4GHz SET A WFLY Chile 0 Oct 19, 2009 11:06 PM
Bored? Want to fight?
Join the RCGroups clan!
