Go Back   RC Groups > Aircraft - Sailplanes > Hand Launch
Old Oct 21, 2009, 07:30 PM   #1
Which batteries and why? How about LiFePO4 for DLG?
I have been scratch my head for a while: which rx batteries for my first DLG?
I have flown RC for 3 years now and all powered: Glow and electric. I use exclusively NiCd and A123. No NiMH, no lipo and no primary batt, at all.
There is a good thread about NiMH, lipo and primary cells:
http://www.rcgroups.com/forums/showthread.php?t=1044988
NiCd is not option: 120mAh per 34g.
I have found some alternatives:
1-RCR123 600 mAh from K2: http://store.peakbattery.com/lfp123a...r-lithium.html
rcg review here: http://www.rcgroups.com/forums/showthread.php?t=868243
Pro:
LiFePO4;
No regulator needed.
cons:
heavy: 34g, at least;
DIY.
Edit:
according to this result: http://www.rcgroups.com/forums/showp...&postcount=118
I've chosen this LiFePO4 for my first dlg:
dlg: Topsky1;
Receiver: Hitec Electron 6;
Servos: Eflite S75 all around;
Batt: 2s K2 Energy 600 mAh rcr123a.
There are other lifepo4, cheaper but I would not consider on my airplane:
http://www.dealextreme.com/details.dx/sku.4419
(what??? 1000mAh!!! You right :-)
2-MAXIRACE HW 25C-330 mAh: http://www.maximus-racing.com/fr/330mah_-_20c.html
rcgroups review here: http://www.rcgroups.com/forums/showthread.php?t=1078049
Pro:
LiFePO4;
light.
Con:
Not available yet;
DIY.
3-Another LiFePO4: Hyperion...http://aircraft-world.com/shopexd.asp?id=6764
Part#HP-FG305-0850
TYPE: 2S 6.6V "flat"
Capacity: 850mAh
Max Current Continuous: 4.25A
Max Charge Rate (4C): 3.4A
L x W x H (mm): 54.5 x 29.5 x 15.4
Weight (g): 48.8
Pro: Available!
LiFePO4
Con:
Heavyyyy
size
Sooooo, Which batteries and why?
tai626 is online now Find More Posts by tai626   Reply With Quote
Old Oct 21, 2009, 08:01 PM   #2
Kevin Caldwell
kcaldwel's Avatar
Pro:
LiFePO4;
cons:
DIY.
Those K2 cells look interesting. I had tried some Tenergy LiFePo4 cells previously, with the intent of using them in a DLG. The capacity was less than half their spec though, so I returned them.
http://www.rcgroups.com/forums/showt...hlight=lifepo4
It looks like the K2 cells actually test to a reasonable mAh. I'm not sure there is any test numbers for the 600mAh cells there?
34g for 600mAh at 6V with no regulator, and no LiPo worries, would be OK with me.
Kevin
kcaldwel is offline Find More Posts by kcaldwel   Reply With Quote
Old Oct 21, 2009, 08:02 PM   #3
Tai,
Glad you started this thread. Should be interesting.
I'm still studying your links. Some look promising. Greater safety with high capacity would be welcome.
I've used primary cells for nearly five years and enjoy the advantages, but always leave the door open for something better.
http://www.rcgroups.com/forums/showthread.php?t=966437
Regards,
John255
John255 is online now Find More Posts by John255   Reply With Quote
Old Oct 21, 2009, 08:11 PM   #4
Kevin
K2 is the second highest peak after Everest... Ops let's me rephrase it:
k2 is the second best after A123 :-) Since A123 can't be found smaller than 18650, I go to the second best. Still trying to search for its retailer. $10 shipping for 4 cells is not cheap...
Old Oct 21, 2009, 08:19 PM   #5
Originally Posted by John255
Tai,
Regards,
John255
I am just looking for something different here. Not sure if it will work or not. That why your experience is valuable.
Old Oct 21, 2009, 08:20 PM   #6
Kevin Caldwell
kcaldwel's Avatar
K2 is the second highest peak after Everest... Ops let's me refrase it:
Well, you could live in Canada, and pay $15 shipping, and then have UPS charge you $65 to bring your 4 cells across the border! If they won't ship USPS, I won't be getting any.
The Tenergy LiFePo4 cells are very cheap, and if they had even 500mAh capacity I would have been happy. They told me they had never had anyone complain before, but I had 6 cells I think, and they were all the same, about 300mAh. I'm not sure if I just got bad ones, but I never tried again.
http://www.batteryjunction.com/rc375reliba.html
Kevin
Old Oct 21, 2009, 08:27 PM   #7
How about I sent you via Usps? We can split the shipping...
Old Oct 21, 2009, 08:28 PM   #8
34g for 600mAh at 6V with no regulator, and no LiPo worries, would be OK with me. Kevin
Kevin,
How about 34g. 1500mA, 6V. no fire hazard, no regulator, no balancing, no expensive individual cell charger, and no charging?
http://www.kodak.com/eknec/documents...7ec/K123LA.pdf
Regards,
John255
Old Oct 21, 2009, 08:51 PM   #9
Kevin Caldwell
kcaldwel's Avatar
John,
I've seen your thread. I'm not really keen on primary batteries. I like rechargeables.
I haven't had any issues with my LiPos. They hold a charge very well and are ready even if I haven't charged them recently. I can fly for hours with no concerns on the 450mAh packs I have now. I charge them at low rates, in the plane. Despite that, there is always the lingering thoughts of potential problems from a short or something, and the added complexity and failure points with a regulator.
The LiFePo4 cells look very good, if they had their rated capacity.
Tai,
I've mailed K2 to see if they will ship USPS. If not, I may take you up on your offer of forwarding some. Thanks!
Kevin
Old Oct 22, 2009, 03:11 AM   #10
robert14's Avatar
Send a message via MSN to robert14
in the netherlands allmost everybody's uses the GP ni-mh cells. for a 350mah pack you come about 28 grams. enough to fly a twister with allmost no lead in the nose for the cog
robert14 is offline Find More Posts by robert14   Reply With Quote
Old Oct 22, 2009, 03:32 AM   #11
I haven't used NiMH as receiver pack. Do you peak charge at field? At what rate?
Is the loaded voltage good indication of the batt gauge?
Here is the comparison of NiMH and k2 LiFePO4:
http://www.rcgroups.com/forums/showthread.php?t=914941
  • Name: Rec-pack-at-1A.jpg
Description: Comparing NiMH and K2 dischargig at 1C Comparing NiMH and K2 dischargig at 1C 41.0 KB · Views: 60
Old Oct 22, 2009, 03:57 AM   #12
Kevin:
You may try this one also. $6.00 per cell and $4.50 shipping, from Hong Kong.
http://www.cpfmarketplace.com/mp/sho...d.php?t=125353
Nominal Voltage : 3.2V
Capacity : 500mAH
Lowest Discharge Voltage : 2.0V
Standard Charge : CC 250mA CV 3.6V
Cycle Life : > 500 cycles
Weight : 16.5g
  • Name: PICT0013-1.jpg
  • Name: LiFePO4R123-1.jpg
Old Oct 22, 2009, 07:27 AM   #13
Is the charging rate important for DLG?
If it is, this lipo is a good candidate:
http://www.allerc.com/product_info.p...oducts_id=4503
2s 7.4v 450mAh 29g and it can be charged at 5c or over 2 amperes!!!
Old Oct 22, 2009, 07:32 AM   #14
Regarding charging rate:
LiFePO4: 0.5C
NiMH: 1C
Lipo: 5C!!!
I really miss A123 here...
Old Oct 22, 2009, 07:51 AM   #15
Chuck 'Em and Chase 'Em
Fly2High's Avatar
I had batteries Plus make myself and others a few and the popular consensus of the GP 1/2AAA is that they are great.
Unfortunately for me, they closed the local Batteries plus. They are a chain but the nearest one is in N. Jersey!
Fly2High is offline Find More Posts by Fly2High   Reply With Quote
which batteries for 25 oz plane/hacker b-20 d12bn Sport Planes 5 May 09, 2002 10:33 AM
Which batteries fit? T-Bo Electric Plane Talk 4 Apr 12, 2002 02:22 PM
If heat is bad for batteries, then why.... green66 Sport Planes 1 Feb 15, 2002 07:29 PM
Which batteries? (and where to get them) CruzThs Electric Heli Talk 5 Jul 16, 2001 09:10 AM
Which batteries for Something Extra blfinche Sport Planes 4 Jun 26, 2001 05:19 PM
Bored? Want to fight?
Join the RCGroups clan!
