Go Back   RC Groups > Regional Forums > Australia
Old Oct 25, 2009, 01:30 AM   #16
Good Better Best quest.
olmod's Avatar
Originally Posted by kevtherev
Hi Les, we need to talk about that motor mount!!
Anytime Kev
olmod is offline Find More Posts by olmod   Reply With Quote
Old Oct 25, 2009, 01:58 AM   #17
kevtherev's Avatar
This is the fox you flew at Casey a while back?
kevtherev is offline Find More Posts by kevtherev   Reply With Quote
Old Oct 25, 2009, 02:19 AM   #18
Speed Junkie
gazza2003au's Avatar
now windrider has the EPP and EPO avaliable for $70 shipped i have picked the motor i will be using it will be a Emax 2215/20 or 2215/25 im yet to decide what model i will use more than likely it'll be the 20 with a 10x5 prop 24.5 amps 1200 grams thrust
gazza2003au is offline Find More Posts by gazza2003au   Reply With Quote
Old Oct 25, 2009, 03:00 AM   #19
I've got one of these but I can't say it's one of my favourites. It seems a bit too small on light days and doesn't have enough energy retention on better days. The spar isn't on the c.g. and so I haven't worked out a ballast setup yet. All up with battery mine weighs 452g. What weight are others using ?
  • Name: Fox.jpg
Description: Standard size elevator servo
HS 65 mg aileron servos top mounted linkages
Lost model alarm
4xAAA Eneloop's Standard size elevator servo HS 65 mg aileron servos top mounted linkages Lost model alarm 4xAAA Eneloop's 38.1 KB · Views: 46
stumblethumbs is offline Find More Posts by stumblethumbs   Reply With Quote
Old Oct 25, 2009, 07:12 AM   #20
olmod's Avatar
Quite a while back and at Alexandria also.
Old Oct 25, 2009, 07:18 AM   #21
olmod's Avatar
Emax are good ,the motor i used was 1000kv with 9x6 graupner cam blades on a H/City hub and because everything was kept light t had no trouble getting up quickly,perhaps you are after hot liner vertical performance.
Old Oct 25, 2009, 07:24 AM   #22
olmod's Avatar
I found i had to keep the CG forward as it was unstable and was lucky to land it on the maiden in one piece. from memory its at around 25mm FLE.
Old Oct 25, 2009, 08:54 AM   #23
Speed Junkie
i picked this plane because it was a bargain i couldnt pass up and it had a nice wing span so it should be really stable also im hopping it will slow right down and help me learn throttle control as all my planes i fly full throttle the whole flight mostly flying wings and this will be my first glider i would love hot liner performance but i doubt i will achieve this with a 28mm motor?
Old Nov 02, 2009, 11:35 AM   #24
Speed Junkie
bugga placed my order 2 weeks ago still no order im using the tracking info and usually it says "parcel has left hong kong for its destination" it usually has this status for around 3-4 days its now been a week ive never had a problem ordering from windrider before....
Old Nov 02, 2009, 01:35 PM   #25
kevtherev's Avatar
Gazz, ordered mine bit over a week ago, got it yesterday, must be a problem with the courier??
Old Nov 03, 2009, 04:02 AM   #26
Speed Junkie
yeah dont know why its taking so long i got an email from ming last night saying give it untill friday and i just done a check with the tracking number it seems its in australia pending customs inspection
kevtherev, did u get two tracking numbers?
Old Nov 04, 2009, 05:46 AM   #27
dingb's Avatar
my fox , maiden at local spot (tank hill)
  • Name: fox (5).jpg
  • Name: fox maiden.jpg
dingb is offline Find More Posts by dingb   Reply With Quote
Old Nov 04, 2009, 05:47 AM   #28
Speed Junkie
dingb when did u order yours?
Old Nov 04, 2009, 06:01 AM   #29
dingb's Avatar
got mine oct 13th one week after order direct from ming
Old Nov 04, 2009, 06:48 AM   #30
Speed Junkie
hmm i need to order more things from windrider to get my mini bee going again but im a little worried now i dont know how it could possibly take 2-3 weeks to arrive
Build Log Windrider Easy Glider EPP Pro w/ V-Tail Mod Phiber Optik Foamies (Kits) 20 Mar 29, 2007 08:21 AM
Windrider Easy Glider Up&Away Slope 23 Feb 23, 2006 10:51 PM
Finally maidened my Windrider Easy Glider Up&Away Slope 0 Jun 09, 2005 06:35 AM
FS: NIB, Mini Fox Glider, Beeline Models ajeepham Aircraft - Sailplanes (FS/W) 9 Mar 28, 2004 11:20 AM
2M Fox Glider F/S fw190a Aircraft - Electric - Airplanes (FS/W) 0 Dec 05, 2001 02:20 AM
Bored? Want to fight?
Join the RCGroups clan!
