Nov 27, 2009, 09:00 PM
Riverside, California, United States
Joined Aug 2004
Back on track! I have just about put everything together and the models are going together easily. Let's start first with the kits available. I have already shared pricing but I want to go over some details and also share the new Legerton inspired gear/ballsat kit available. So let's begin. Here is the standard Hardware kit. When using Ball links they put about a 5mm offset on your linkage. Meaning your link is 5MM outside of your servo arm as opposed to using a clevis on the servo end where the rod is inline with the servo arm. The model has been designed with the offset in mind and all the recesses for the servos and through holes and fairing locations have been set according to this offset. Using clevises on the servo end might not work as the servo case may not end up in the proper location. It could have a tendency to ride up on the balsa core in the wing and wont sit flat. Hope all that makes sense. Basically, use ball links on this model and you wont have any problems fitting your standard sized servos.
