Espritmodel.com Heli Air
Old Oct 20, 2009, 11:43 PM
Go Faster!!
Jason Lilly's Avatar
San Diego, CA
Joined Apr 2004
Joe,
Those parts look sweet. I can't wait to get my paws on one for myself!
Good job!
Jason Lilly is offline Find More Posts by Jason Lilly
Old Oct 21, 2009, 12:00 AM
C'mon more Energy
Swoopdown's Avatar
Melbourne, Australia
Joined Mar 2005
Joes has finally meet his goal.
http://www.rcgroups.com/forums/showp...&postcount=497
I still often look back to this thread for insperation.
http://www.rcgroups.com/forums/showthread.php?t=303670
Just goes to show that this model hasnt come about overnight.
It was back in Nov 2004 when Joe first started his first Dynamic 80". Apart from the 80" span the entire model has changed in every way.
Well done Joe. Champion job!
Swoopdown is offline Find More Posts by Swoopdown
Old Oct 21, 2009, 02:52 AM
Mach 0.261 ... Hiccup of Wiggy
Geo420's Avatar
Wiggy Poo, England!
Joined Mar 2006
Very Nice!
Very nice indeed.
George
Geo420 is offline Find More Posts by Geo420
Old Oct 21, 2009, 04:51 AM
In you face flying
timbuck's Avatar
gold coast australia
Joined Aug 2008
Well done joe!! when i grown up out of the D40 i think i will have to get one!!!
Tim.
timbuck is offline Find More Posts by timbuck
Old Oct 21, 2009, 06:28 AM
Can you DS it??
spotterone's Avatar
Australia, NSW, Berowra
Joined Aug 2008
That looks awesome! Can't wait for one to land on my doorstep!
I'll take the kit too. Nothing like making life easy for yourself
Leo
spotterone is offline Find More Posts by spotterone
Old Oct 21, 2009, 06:31 AM
Windburner Factory Pilot
swoop119's Avatar
Joined May 2008
Leo
Sounds like there are a few D80's coming to Oz
swoop119 is offline Find More Posts by swoop119
Old Oct 21, 2009, 08:34 AM
Just chillin @ 403 MPH
Jantar2A's Avatar
Boulder Colorado
Joined Nov 2005
Congrats Joe things look great.
I must ask if you have made a part to clean up the lower part of the vertical fin or does it just get left open like in the pics.
Nick
Jantar2A is offline Find More Posts by Jantar2A
Old Oct 21, 2009, 10:37 AM
CRASH NOW,CRY LATER!!
Joined Aug 2007
kit me to! cant wait....
rojomatt is offline Find More Posts by rojomatt
Old Oct 21, 2009, 11:52 AM
andreis's Avatar
Monza, Italy
Joined Dec 2006
Very nice job !!!
Watching the pictures, the tail opening is clearly visible, but thinking about the space fullfilled by the pitch servo a curiosity is growing : from where it's passing the allen key to tighten the 3 tail&fin fixing screws ??
Antonio.
Originally Posted by joe manor
The fuse is 99% kevlar. I used some UHM carbon tow to stiffen the tailboom and it is very stiff. Other than that the only other carbon is wrapped around the rib inside the subfin. The carbon tow stops at the LE of the wing. These fuses are very thick up front and should hold up to rock landings no problem. The entire nose of the model has zero carbon and I will be testing a 2.4ghz system in this model.
andreis is offline Find More Posts by andreis
Old Oct 21, 2009, 12:37 PM
Stay in it!!!!
Riverside, California, United States
Joined Aug 2004
Nick
There is a tailcone just like the D160. The mold is being made now.
joe manor is offline Find More Posts by joe manor
Old Oct 21, 2009, 12:40 PM
Stay in it!!!!
Joined Aug 2004
Originally Posted by andreis
Very nice job !!!
Antonio.
The tail is removeable. The front bolt is accessed by a small hole at the bottom of the fuse. The second bolt is accessed through the servo opening. It is positioned so that you can get to it while the servo is in place. Once you disconnect the control rod from the servo arm you can move the rod off to one side and get to the rear bolt through the opening at the rear of the fuse by removing the tailcone. All this will be detailed later in the build. Stay tuned.
Old Oct 21, 2009, 05:49 PM
andreis's Avatar
Monza, Italy
Joined Dec 2006
Thanks.
Old Oct 21, 2009, 06:33 PM
Jantar2A's Avatar
Boulder Colorado
Joined Nov 2005
Totally cool Joe.
I'll be sending you $$$ soon
Nick
Old Oct 22, 2009, 10:39 AM
Stay in it!!!!
Joined Aug 2004
Didnt get much finished yesterday. I spent the whole day drawing and machining the proper sized horns for the production run. Finally I got the correct size. I will use them in this model but until the actual production models arrive and I can check for clearance under the fairings I wont know for sure if these are the final sizes or not.
Old Oct 22, 2009, 10:44 AM
Stay in it!!!!
Joined Aug 2004
The wing control rods are exactly like the elevator but shorter. These are hardened steel rods much stiffer than a typical 4-40 threaded rod. The accessory kit will include all the links pre soldered to the correct length. You will just have to screw on the plastic ball link on the other end and hook it up. The kit will have aluminum arms to fit the Hitec servos reccommended for the model as well as the ball portion to screw into the servo arms.
Discussion 40" Dynamic Build Thread joe manor Dynamic Soaring 413 Apr 15, 2013 09:08 PM
Discussion 100" Hollow Molded Dynamic Build Thread joe manor Slope 74 Dec 07, 2007 04:47 PM
80" Dynamic Build Thread joe manor Slope 497 Jun 05, 2006 09:25 PM
P/F-80 Build Thread....the beginning... Kirkgh Slope 53 Nov 19, 2004 12:37 PM
CSD F-80 semi-sled build thread.... Brandon Slope 20 Nov 19, 2004 10:11 AM
