Old Oct 20, 2009, 11:21 AM
Rengine is offline
Find More Posts by Rengine
'Cobra Fan - P-39 & P-63
Rengine's Avatar
Fort Collins, CO
Joined Aug 2004
Build Log
H E L L - B E A R -- warbird/3D tribute 60" span, 3.5 lbs AUW -
The HELL-BEAR - a tribute to warbirds and 3D too
FFF - Packing Tape - Hot Glue
-- 60 inch span - 48 inch fuse - est AUW at 3.5 lbs - 56 ounces
Started on a new one this last Sunday - kind of like a P-47 Jug & Hellcat F4F combo. After my "Corbra" success (and subsequent crashes and trashing) I wanted to use a similar type of fuselage buildup for this one. It's easy to do, just takes some time as I have to cut each part as I build and test fit.
I spent about 15 hours building on it Sunday and made great progress. Going to be using Hacker A30 12XL motor, 4s1p 2200 mah batt pack, 40 amp esc and 4 full size servos. This combo worked great on the "Corbra" - pulled hard and fast with a 14x7 prop. These wings are damn near flat (the 'airfoil' must be put in quotes as it's the thickness of a single aluminum arrow shaft ). Should be plenty fast and without all the annoying lift.....
time for the photos to do the talking
Enjoy!
Mark
Rengine is offline Find More Posts by Rengine
Old Oct 20, 2009, 02:01 PM
Spamman127 is offline
Find More Posts by Spamman127
United States, OH, Troy
Looks a little like a F-8 bearcat.
Spamman127 is offline Find More Posts by Spamman127
Old Oct 20, 2009, 02:08 PM
may-day is offline
Find More Posts by may-day
A&P Mechanic
may-day's Avatar
San Antonio
Joined Mar 2005
cool
may-day is offline Find More Posts by may-day
Old Oct 20, 2009, 02:10 PM
cmelton11 is offline
Find More Posts by cmelton11
CMelton
cmelton11's Avatar
USA, NC, Burlington
Joined Jul 2009
what size are your formers that is a cool looking build
cmelton11 is offline Find More Posts by cmelton11
Old Oct 20, 2009, 03:29 PM
may-day is offline
A&P Mechanic
may-day's Avatar
San Antonio
Joined Mar 2005
great size. Not way too big and difficult to transport, not to small and wind bound.
Dave
Old Oct 21, 2009, 10:28 AM
Rengine is offline
Rengine's Avatar
Fort Collins, CO
Joined Aug 2004
Save $200 To $700 On Each Plane- Build With Fff!
Thanks for the nice comments guys!
Got some more done last night on the - uh...Warbird! maybe think up a name today...Helljug...HELLJUG extended fuse....racing HellJug ? Pattern Warbird...
Anyway - got the formers done and wings built - gotta mount the servos and such...now the design phase is done and the location of batt & servos comes into play as I maintain the Center of Gravity at about 25 - 30% of wing chord. I do the batt placement last to finalize the proper CG.
So I build the fuse without concern for placement of servos, recvr, batt, etc - and just cut a hole in the foam later for those. Makes building without a plan much easier.
The full fuse with wings on and the Hacker A30 mounted is only 1.5 lbs. Excellent...should hit 3.5 lbs AUW easily enough.
Making formers is easy!
First glue on the long horizontal former (each side has one that follows the thrust line), as they are used as a guide for the rounded vertical formers.
Once those are in place, just cut a 90 degree angle into any scrap foam piece big enough to work. An acrylic drawing triangle is what I use a lot for a scratch build like this.
Wherever you want a former. hold the scrap piece with the 90 degree cut up against the vertical beam/spine and the long horizontal former and use a pen to mark where the former should be cut to fit. Then lay the circular device (in this case stovetop burner cover) on the piece of foam and cut it. very hard to describe - but so easy to do....
enjoy!
Mark
Old Oct 21, 2009, 10:57 AM
zultone is offline
Find More Posts by zultone
Master Crasher
zultone's Avatar
Fletcher, NC
Joined Oct 2008
Looking very sharp. I like it.
I have not figured out how to make good formers... All of my builds have been boxes because of it.
zultone is offline Find More Posts by zultone
Old Oct 22, 2009, 02:32 AM
TJC is offline
TJC
Find More Posts by TJC
TJC
Crossweave king
TJC's Avatar
Cambridgshire in England!
Joined Jan 2007
Nice build. I'm a big fan of just letting a plane design itself as you build. Capturing the spirit without following any specific design.
TJC is offline Find More Posts by TJC
Old Oct 22, 2009, 08:44 AM
Rengine is offline
Rengine's Avatar
Fort Collins, CO
Joined Aug 2004
MAKING FORMERS using random kitchen objects
Got some more done on the build - working on the landing gear mounting now - it has to be very tough and durable, yet yield in the right way if and when a hard landing comes along and tries to rip the gear off...
this required extra formers, I decided, so a great time to illustrate how I discovered making formers on this build. I have not used this technique before (and for all I know many people are already doing this) but it is working out wonderfully. An easy way to give your profile plane some depth
Enjoy!
--Mark
Old Oct 22, 2009, 10:17 AM
JimW is offline
Find More Posts by JimW
North Kent, England UK
Joined Jan 2005
Now I know what to do with that bag of depron offcuts I've been saving.
Excellent job.
JimW is offline Find More Posts by JimW
Old Oct 23, 2009, 08:51 AM
Rengine is offline
Rengine's Avatar
Fort Collins, CO
Joined Aug 2004
A bit more done...
H E L L J U G - update
...Got the servos installed for rudder & elevator, almost finished the landing gear mounting...I'm trying to create something that will break nicely if a harsh landing ever occurs...not like that happens - but I've got an idea to try using bamboo skewers...did initial balance testing - looks good mounting the battery just above the leading edge of the wing right behind that former...
...that's about it for today
Old Oct 26, 2009, 09:31 AM
Rengine is offline
Rengine's Avatar
Fort Collins, CO
Joined Aug 2004
H E L L B E A R - (new name-sounds cooler than "helljug")
H E L L - B E A R
Got lots done over the weekend, all control surfaces rigged and running and covering/outer shell installation about 80% done. Still figuring out the wing securing method - not sure on that yet - but I know I can still maiden it with something temporary while I decide.
Weight is going up since I'm gluing the outer skins on (my last build like this, the "Corbra" - i used packing tape on the outer skins). So maybe 3.8 lbs for this build, perhaps even 4lbs - but that's just a guess at this point.
Also decided to program flaperons in the mix since after I powered up everything the aileron servos were not quite centered properly. As a result the ailerons are both in a slight UP position right now (good for adding lift to this very flat wing, eh?
Even at 4lbs it's still going to be quick as a wink Maiden next weekend for sure - if not before - but the weather here in Fort Collins, Colorado is supposed to be cold, windy, snowy for the next few days...
Have a good day!
Mark
Old Nov 01, 2009, 12:16 PM
Rengine is offline
Rengine's Avatar
Fort Collins, CO
Joined Aug 2004
MAIDEN FLIGHT Video
MAIDEN FLIGHT Video
Everything went well - I think my flaperons were a tad bit in the up position (if you look close on the take off you can see what i mean) so it was flying in a tail low attitude...I was wondering why until I saw my hat-cam video in slo-motion. i think that is why...but will determine a lot more as I get more flights on her and play with the flaperons.
The great news is the super thin wings worked great - the do flex a bit, and that's just fine. see the landing slo-mo to watch 'em bend. The power-off glide is awesome - floats in nicely and doesn't drop a wing at stall.
So the wings are definately strong enough for the approx 68 oz weight. The hacker 30 and 14x7 prop pull plenty hard on 4s1p 2200 mah pack - and I've no doubt it will carry a 2nd lipo pack giving me 4400 mah of fun foam flying time.
I ended up adding two additional carbon fiber arrow shafts to the wings - and completely packing taped the top & bottom of the wings. I think without this additional support I'd proabably snap off one of the wings...
Gotta figure out how to finish the canopy (maybe built up a F4F type - or perhaps a more Edge 540 type...) and do some kind of painting or decorating. It looks a lot like a submarine from the side now...and with no paint orientation can be tough when far away.
will post a few more pics too when I get a minute.
Enjoy!
Mark
http://www.youtube.com/watch?v=KLzAWg-cm9A
Old Nov 01, 2009, 04:24 PM
SKYPILEIT is offline
Find More Posts by SKYPILEIT
Deplorable but likeable
SKYPILEIT's Avatar
Novi, Michigan
Joined Nov 2002
the Hell Bear.!
Very interesting project Mark & I'm amazed at your building skills...& you did it in only 10-11 days.?That's real good...(it would have taken me a couple months)
Please..share the next few flight vids with us,I'd like to see it with the larger packs & Cg forward a bit.Can't wait to see it all painted up with military insigs.
I can see alot of snow in Ft.Collins already..I guess that means we'll be getting it in another few weeks.Lookin' at the next 6 months of Mich. winter.
Oh well..
SKYPILEIT is offline Find More Posts by SKYPILEIT
Old Nov 02, 2009, 12:24 PM
Rengine is offline
Rengine's Avatar
Fort Collins, CO
Joined Aug 2004
Highlights video footage from 11/2 - Touch N Go
Here's some more footage - this thing flys GREAT !!!!
I'm very pleased with the outcome...still haven't flown with 2 - lipo packs yet. The flaperons are cool - but it sure doesn't need them to slow down...most of these landings - in fact all but one - were done with out any flaps down....
P L E N T Y of power (not enough to hover for more than 2-3 seconds though) and I had a couple of hard landings with no damage - whew! the wings will take a hit and flex - and come back for more.
SKYPILEIT - thanks for the nice comments, it was a quick build - and I had to focus to get it done. I normally take 2 months or more... But that's what Michigan winters are for, right? Building time!
thanks,
Mark
HELLBEAR RC foamie airplane warbird 3d type (5 min 23 sec)
Sold Laser cut kit F-15 eagle for 3.5" / 90mm fans. 35" wing span (PARTIALLY BUILT!) demetrius Aircraft - Electric - Airplanes (FS/W) 6 Sep 16, 2005 11:58 AM
3.5" span Sky Bug model for HFX900 system Ralph B Scratchbuilt Indoor and Micro Models 65 Jul 17, 2005 12:06 AM
Suggestions for EPP/Tuff plane, 3-4ch Ail/Elev/Rud aprox 48 to 60” span Dampy Slope 40 Mar 13, 2003 06:04 PM
