Old Dec 18, 2011, 11:04 PM
UltraMicro is offline
Find More Posts by UltraMicro
UltraMicro's Avatar
United States, CA
Joined Jul 2011
Has anyone tried using eflight's 500mah 1s? Haven't seen any posts on it. I tried it with my micro p-51 and it get's 30min+ flight times. Surprisingly, the extra 350mah gives it some extra power. Even with the extra weight, the p-51 flies just about the same as if you ran it one the stock 150mah battery.
UltraMicro is offline Find More Posts by UltraMicro
Old Dec 19, 2011, 09:31 PM
Saxguy1000 is offline
Find More Posts by Saxguy1000
Rockin' & Flyin'
Saxguy1000's Avatar
Virginia Beach
Joined Dec 2009
30+ minutes? I use the Lectron Pro 3.7 volt - 270mAh 12C batteries. They aren't as heavy and give me at least 12 minutes. I don't go to LVC, though, and they probably go longer.
Saxguy1000 is offline Find More Posts by Saxguy1000
Old Dec 25, 2011, 05:08 AM
UltraMicro's Avatar
United States, CA
Joined Jul 2011
Just out of curiosity, when you guys paints yours micro p-51 in the petie the 2nd color scheme, how do you get the perfect symmetrical blue curves on each side of the nose?
Old Dec 27, 2011, 11:08 PM
UltraMicro's Avatar
United States, CA
Joined Jul 2011
When I pulled off the decals on the p-51 they left ruff marks on the body. How can I erase these marks?
Old Jan 01, 2012, 10:48 PM
Yellow Baron is offline
Find More Posts by Yellow Baron
Back in the game.
Yellow Baron's Avatar
3" from insanity, 2' from the computer ,Richford, Tioga county, Southern Tier, New York, U.S., North American Continent, Northern hemisphere, Earth, The Sol System, Milkyway Galaxy, The Universe, The Current Dimension, Your Selected Realm of Reality.
Joined Dec 2006
Does anyone know who makes drop tanks for the P-51? I saw them on the main thread, but don't recall who makes them or what page they are on.
Yellow Baron is offline Find More Posts by Yellow Baron
Old Jan 01, 2012, 11:10 PM
UltraMicro's Avatar
United States, CA
Joined Jul 2011
I know ParkFlyerPlastics make various accessory's for electric aircraft. I know some people have used ParkFlyerPlastics's drop tanks for their micro p-51 but i'm not 100% sure which size. Here's the link to the various droptanks:http://parkflyerplastics.com/cart/in...4636bd4391a29e
Old Jan 02, 2012, 09:15 AM
Back in the game.
Joined Dec 2006
UltraMicro, I thought of that just after making that post, but it was not them, the smallest drop tank is just slightly too big. The tanks I'm thinking of were vacuum formed by someone on here for their own plane and they then decided to offer them to other modelers too.
Old Jan 02, 2012, 01:18 PM
UltraMicro's Avatar
United States, CA
Joined Jul 2011
i'm guessing you could try searching it up in the RCG search bar.
Old Jan 02, 2012, 04:54 PM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Yellow Baron,
I made blue construction foam molds a while back and vac formed .010 styrene takes with micro rare earth magnets for the wings and tank so they would pop on and off they were pretty cool when flying and landing WO LG on a gym floor since they would sometimes pop off on landings. Someone took them while at an indoor fly-in, I have not made another set. I made some for JoesS475 you can see them on pages 19, 21 and flying on his plane on page 31 of this forum.
I also did a paper and foam set of paper tanks for another P-51 mod I did.
Somewhere in this forum I did posts on each build and there are pic's here somewhere on the vac formed tanks on mine while flying.
Pete
mtflyr is offline Find More Posts by mtflyr
Old Jan 02, 2012, 07:12 PM
Back in the game.
Joined Dec 2006
Mtflyr,
Did you ever make a set of the 75 gallon aluminum tanks that were used before they switched to the pressed paper ones later in the war?
Old Jan 02, 2012, 07:27 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Yes, if yoy mean the tear drop aluminum DT's, look back at the pages I noted noted. As I said someone took them while at an indoor fly in.
Pete
Old Jan 02, 2012, 08:56 PM
Back in the game.
Joined Dec 2006
Pete,
Those are the ones I'm thinking of! Sorry to hear about your set getting lost.
Old Jan 06, 2012, 12:33 AM
George de Pinedo is offline
Find More Posts by George de Pinedo
Joined Jan 2012
But still I did not understand how to build the 4 blade prop.......
George de Pinedo is offline Find More Posts by George de Pinedo
Old Jan 06, 2012, 01:45 AM
UltraMicro's Avatar
United States, CA
Joined Jul 2011
I painted my Micro P-51 the color of Moonbeam McSwine (look on my blog or the Details):
Base and Primary Layer:
Details:
Cockpit V1:
Final:
Old Feb 05, 2012, 02:17 PM
Angelo is offline
Find More Posts by Angelo
Angelo's Avatar
Chicago, IL
Joined Nov 1999
Mounting new motor - getting wing off.
I'm trying to put a new motor in my micro Mustang. During customizing it, I glued down the top part of the fuse. I made a hatch from the front of the cockpit to the nose, but I now see the wires for the motor run underneath the receiver brick. What's the best way to remove the scoop and lower fuselage to get to the brick?
Angelo
Angelo is offline Find More Posts by Angelo
Discussion Parkzone Micro P-51 rcozstyle Australia 13 Oct 15, 2009 04:51 PM
Gallery ***Show off your Scale Micro's or Mini's!*** Pigs dont fly Micro Helis 81 Oct 07, 2009 06:29 PM
Discussion Parkzone Micro P-51 rcozstyle Australia 32 Aug 24, 2009 06:47 PM
Show off your Micro Helis' "friends". beemer Micro Helis 3 Sep 03, 2005 02:28 PM
Show off your Sub-Micro!!! Minimole Micro Helis 39 Apr 20, 2005 10:20 PM
