Old Nov 25, 2009, 06:46 PM
Action Jack is offline
Find More Posts by Action Jack
Action Jack's Avatar
Edmonton, Canada
Joined Apr 2003
Now that is a thing of beauty! Be sure to post when all those "details" are done. What a stunner!
Jack
Action Jack is offline Find More Posts by Action Jack
Old Nov 25, 2009, 07:55 PM
fairplane is online now
Find More Posts by fairplane
fairplane's Avatar
Canada, SK, Prince Albert
Joined Aug 2006
Nothing much different except added removeable flaps for indoor flying Have since narrowed them by 1/4 in to same width as ailerons
fairplane is online now Find More Posts by fairplane
Old Nov 26, 2009, 01:14 AM
Hepdog is offline
Find More Posts by Hepdog
Registered Plan-a-holic
Hepdog's Avatar
Stonewall, MB, Can
Joined Jul 2004
Almost done....almost.
Weight is now 5 grams over stock....whoops I'm sure it has power to spare - especially with the E-flite 150mah pack.....gulp Who knew all those tiny details would add up Guess I have to fly at WOT....
Looks good anyway......
Hepdog is offline Find More Posts by Hepdog
Old Nov 26, 2009, 10:14 AM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Outstanding! Did you use some type of "filler" on the foam, prior to painting it? Also, what did you use for paint? The plane is too pretty to fly, so keep it on display and go make another one to fly!!
RD
Doug Sipprell is offline Find More Posts by Doug Sipprell
Last edited by Doug Sipprell; Nov 27, 2009 at 04:57 PM. Reason: grammar correction
Old Nov 26, 2009, 01:31 PM
Hepdog is offline
Hepdog's Avatar
Stonewall, MB, Can
Joined Jul 2004
Thanks for the kind words.
I did fill the foam quite a bit with normal household "spackling". I tried model lite filler but it's density is actually harder than foam - that equals really bad sanding. You end up sanding off more foam than filler which makes a mess of everything. Spackling on the other hand, sands super easy leaving the foam in place - just don't put on too much - only enough to fill the bigger voids.
For paint I intitially tried Testors new model master Latex - sucks. Pigment coverage is waaay too thin - it would take many coats to get a consitent colour overtop the other colours. If the base was pure white - it might be fine.
Instead I use Creative airbrush paint from Micheals. Thin with a touch of water and use multiple light coats - fully drying inbetween - coverage is excellent.
Flew her today - super tail heavy - but lots of power to spare. I'll make a new recessed battery holder in the nose and she should balance out fine. Pics to follow...
Old Nov 27, 2009, 05:00 PM
Elfi Flyer
Rock Hill, SC
Joined Oct 2002
Stock motor, or brushless conversion?
RD
Latest blog entry: Big Red Cadillac
Old Nov 27, 2009, 07:48 PM
Hepdog is offline
Hepdog's Avatar
Stonewall, MB, Can
Joined Jul 2004
RD
All stock except for the paint and wing fillets...which might add some speed...or not.
I'm going to hold off moving the batt till I'm sure it's a CofG issue. The stock elevator setup, even a full trim down, was still showing some up elevator. PLUS there is no downthrust built in the to the motor mount...which is a little odd. We have indoor flying tonight so I can trim it out without the wind interfering. If need be I'll add nose weight and see what happens.
BTW new batteries in my scale - 40grams with the battery!!!! Still flys fine....
Old Nov 27, 2009, 08:29 PM
pyrobus is offline
Find More Posts by pyrobus
outstanding in the left field!
pyrobus's Avatar
USA, IL, Marengo
Joined Feb 2007
very cool
Do you have the weight of the stock model for comparison?
Great job!
Pyro
Edit 5 grams ...
pyrobus is offline Find More Posts by pyrobus
Old Nov 27, 2009, 08:48 PM
Hepdog is offline
Hepdog's Avatar
Stonewall, MB, Can
Joined Jul 2004
Great job!
Pyro
Edit 5 grams ...
Stock set up is 30 grams without battery - stock battery weighs 4 grams
Old Nov 27, 2009, 09:28 PM
UNGN is offline
Find More Posts by UNGN
Power Wheels Guru
UNGN's Avatar
Southlake, TX
My Un-flown, unmodified P-51 is 32.2g without battery.
The factory 120 mAh battery is 3.7g
So its 35.9g RTF
UNGN is offline Find More Posts by UNGN
Old Nov 29, 2009, 06:27 PM
Hepdog is offline
Hepdog's Avatar
Stonewall, MB, Can
Joined Jul 2004
Got a whopping 4 flights before the motor burnt out...
Oh well - easy fix. New motor and gear box is under $20. Since I had to cut up the nose I decided to mount the battery internally - needed to be forward for CofG anyway. Cowl is held on with magnets - battery is removable once the cowl is off.
Old Nov 30, 2009, 03:09 PM
kelloggair is online now
Find More Posts by kelloggair
kelloggair's Avatar
centennial/aurora colorado
Joined Mar 2008
thats amazing i cant believe what a little filler,paint,and elbow grease can do keep up the great work ill be getting mine soon but i will probably keep it stock for a little while till i learn her fully
kelloggair is online now Find More Posts by kelloggair
Old Dec 04, 2009, 12:21 AM
llbr22 is offline
Find More Posts by llbr22
llbr22's Avatar
USA, CA, Oakland
Joined Nov 2009
Subscribed.
Love red and white!
llbr22 is offline Find More Posts by llbr22
Old Dec 08, 2009, 10:16 AM
P-51C is offline
Find More Posts by P-51C
Reserved Parking
P-51C's Avatar
Joined Jun 2004
Lookin good Hepdog!
P-51C is offline Find More Posts by P-51C
Old Dec 09, 2009, 11:54 AM
llbr22 is offline
llbr22's Avatar
USA, CA, Oakland
Joined Nov 2009
Hepdog,
Did you remove the original paint? or when you mention 'coverage' are you speaking of covering over the original colors.
Also. anyone know if Krylon Short Cuts will cover darks like on the P-51?
thanks all!
L
Discussion Parkzone Micro P-51 rcozstyle Australia 13 Oct 15, 2009 05:51 PM
Gallery ***Show off your Scale Micro's or Mini's!*** Pigs dont fly Micro Helis 81 Oct 07, 2009 07:29 PM
Discussion Parkzone Micro P-51 rcozstyle Australia 32 Aug 24, 2009 07:47 PM
Show off your Micro Helis' "friends". beemer Micro Helis 3 Sep 03, 2005 03:28 PM
Show off your Sub-Micro!!! Minimole Micro Helis 39 Apr 20, 2005 11:20 PM
