Old Jan 03, 2010, 08:45 PM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
Thanks guys,
I usually don't like doing RTF/kit planes, I'd rather make my own but everyone's making this PZ P-51 look good so I thought I'd try one.
I enjoy doing the research and reading about the folks who flew these birds.
As I said, these micro birds being so light are hard to damage.
Pete
mtflyr is offline Find More Posts by mtflyr
Old Jan 04, 2010, 07:02 AM
cabman1969 is offline
Find More Posts by cabman1969
cabman1969's Avatar
Melbourne, Australia
Joined May 2008
Bald Eaglet
Hey guys just wanted to show a pic of my first version of the bald eagle paint scheme. Yes i know it still needs the invasion stripes. Its still in the -fly a little- crash a little- paint it a little phase. Notice the slightly mangled nose. Ill do a better version after I destroy this airframe, mainly just so Im better with the flight characteristics of the model. Yes it looks rough but like I said its the prototype of whats to come, (experimenting with acrylic paints add ons and weight). I even added the antenna mast. im actually working on scale landing gear struts and rims that are coming out very well. Yes! I know (weight!) but they are very light construction and ill only use them for touch and go's and static display, a P51 should never have gear hangin out of the bottom.
cabman1969 is offline Find More Posts by cabman1969
Old Jan 05, 2010, 01:01 AM
JoeS475 is offline
Find More Posts by JoeS475
Warbird Flyer
North New Jersey
Joined Dec 2009
cabman1969, yours is an awesome work in progress! I'm on my third spinner (I use landing gear, and the pavement is far from perfect), but I want to buy 3 more of these birds just for different paint jobs. Can't wait to see your final result/next plane.
It's nice to see somebody else put on the antenna mast and move the tail wheel!
Personally I prefer not to add landing gear doors/struts, as I feel a Mustang in flight should not have wheels down. As it is they are quite hard to notice, especially at a distance. I like what mtflyr has done, and that he is only using them for display.
~Joe
Edit: Just read your last sentence again... My thoughts exactly!
JoeS475 is offline Find More Posts by JoeS475
Old Jan 05, 2010, 04:53 PM
skunkworks2006 is offline
Find More Posts by skunkworks2006
skunkworks2006's Avatar
Michigan
Joined Nov 2006
Originally Posted by MicroTex View Post
Thanks guys
I made the canopy, but the mold is not quite right yet. It doesn't fit coerrctly at the front, I had to bend it a little while I was gluing. Once I get the mold right I may offer a few for sale if there is enough interest.
A couple more pics, need to get some shots in the sunlight.
Ever get that mold right? I'd be interested if you have 'em.
skunkworks2006 is offline Find More Posts by skunkworks2006
Old Jan 05, 2010, 06:23 PM
JoeS475 is offline
Warbird Flyer
North New Jersey
Joined Dec 2009
I second that... I'd love a clear canopy, but am not equipped (or skilled enough) to make one myself!
~Joe
Old Jan 08, 2010, 12:42 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Not sure if this will work in the test phase now. A friend at my LHS made one for his slightly larger profile P-51 and it worked for him. I'm not sure if it will work with the PZ brick. I used two GWS 4X3 props cut one at the hub. Then CA'ed to the other hub. It will require making a new spinner as well.
Also made some paper prop decals to test looks.
I've done this before on my large 32" WS P-47 and it works great. Eyeballed the pitch etc on the added prop blades.
We'll see.
Pete
Old Jan 08, 2010, 01:50 AM
BigGuyJT is online now
Find More Posts by BigGuyJT
BigGuyJT's Avatar
Fresno, California
Joined Mar 2007
I had thought about doing that with the stock prop but didnt think I could get them straight.
BigGuyJT is online now Find More Posts by BigGuyJT
Old Jan 08, 2010, 06:40 AM
Dennis A is offline
Find More Posts by Dennis A
Wyomissing PA
Joined Aug 2003
..nice 4 blade! Hope it works, but usually I've lost efficiency with 4 blades. Let us know, I've got lots of props.
Dennis A is offline Find More Posts by Dennis A
Old Jan 08, 2010, 10:11 AM
Orion Pax is offline
Find More Posts by Orion Pax
Wisdom can not be granted.
Orion Pax's Avatar
Shreveport Louisiana
Joined Dec 2006
Well if it doesn't work you can always decrease the diameter. When you add a blade you increase pitch by 1 and diameter by 1. Of course you guys probably knew that but if the thrust isn't there jut trim the blade. Less weight to sling around and you should get more performance. I hope it works because I want to do the same thing.
Orion Pax is offline Find More Posts by Orion Pax
Old Jan 09, 2010, 12:48 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Thanks Orion, my friend did infact reduce his diameter by cutting the prop.
I just got a GWS 4X3 instead of the 5X3.
I think it will work powers up ok the extra blades will I'm sure pop off the first time one hits the ground so I may try and cut a slot in the hub later for each blade.
Pete
Old Jan 09, 2010, 08:28 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Made some .010 styrene light weight drop tanks. They are held on with micro magnets not the best but they look okay and I should be able to fly with them or I can pop them off. Run up tests on the 4 blade prop are okay too. Also made a quick spinner but I'll need to make a better one if the 4 blade prop works.
Weight gain 1.1 oz to 1.3 oz not too bad.
Now mine can do long range missions
Pete
Old Jan 09, 2010, 09:46 AM
Orion Pax's Avatar
Joined Dec 2006
Man that looks good!
Old Jan 09, 2010, 12:33 PM
jingjingjing is offline
Find More Posts by jingjingjing
I love my ID.
Fairfax VA
Joined Aug 2004
Pete,
you can fit extra batteries in side that drop tank. Looks great as usual.
Jin
jingjingjing is offline Find More Posts by jingjingjing
Old Jan 10, 2010, 08:40 PM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Well today I was able to test fly the P-51 with the 4 blade prop indoors at the National Building Museum in down town DC. It's a great place to fly and I had a ton of fun.
The 4 blade prop really slowed the plane down and worked well until I landed and as I had thought both the CA held on blades poped off. The cool thing is with the now two blade GWS 4.5X3 prop the P-51 flew great indoors. It slowed it down enough to have fun flying it and the wing drop tanks worked great too and pop off when landing.
I may try cutting a notch in the prop hub to help keep the added blades on the prop. But again for tight areas of indoor flying just using the GWS 4.5X3 prop is a pretty good way to go.
Thanks to the folks who set up the indoor flying at the National Building Museum
Pete
Old Jan 10, 2010, 10:41 PM
fairplane is online now
Find More Posts by fairplane
fairplane's Avatar
Canada, SK, Prince Albert
Joined Aug 2006
Pete
Hey mtflyr- your bird looks incredible! So if you had to guess at how much the speed was decreased by using the gws prop-what do you think it would be? 10%-20%-30%???? I put fixed flaps on my P51 to slow it down enough for indoor flight, but maybe I'll change the prop too to make it a little more relaxing as mine flies well indoors but really have to keep on the sticks at all times-had an indoor fly today and now my bird has a crease in the wing, but doesnt effect the flight at all Once again your plane looks AWESOME!
fairplane is online now Find More Posts by fairplane
Discussion Parkzone Micro P-51 rcozstyle Australia 13 Oct 15, 2009 04:51 PM
Gallery ***Show off your Scale Micro's or Mini's!*** Pigs dont fly Micro Helis 81 Oct 07, 2009 06:29 PM
Discussion Parkzone Micro P-51 rcozstyle Australia 32 Aug 24, 2009 06:47 PM
Show off your Micro Helis' "friends". beemer Micro Helis 3 Sep 03, 2005 02:28 PM
Show off your Sub-Micro!!! Minimole Micro Helis 39 Apr 20, 2005 10:20 PM
