Old Dec 31, 2009, 01:14 PM
butters149 is offline
Find More Posts by butters149
Joined Apr 2008
Lol Oh i get ya, anyways, in the pic above, can't you just remove the wing to paitn it in sections? Or is that harder? I don't have the plane yet, it came in today and I will look at it.
butters149 is offline Find More Posts by butters149
Old Dec 31, 2009, 03:28 PM
C140 is offline
Find More Posts by C140
Nose Wheels are for Sissies
C140's Avatar
Madera, CA
Joined Jan 2009
Originally Posted by Doug Sipprell View Post
You can also use Velcro to provide a battery "shelf" for batteries about to be used, or for holding a charging station. I use Velco circles to hold the foam block in the Ember "hangars". Mustang hangar now has the charging station velcro installed.
Elfi Flyer, where did you get that charger that plugs into a flight pack? I've been looking all over for something about it, and I just saw it in the Ember picture you attached to the post I quoted.
Edit: It's Post 81 on page 6.
C140 is offline Find More Posts by C140
Old Dec 31, 2009, 03:59 PM
I R Irv is offline
Find More Posts by I R Irv
I R Irv's Avatar
United States, IL, Washington
Joined Nov 2008
(fourplay)four port charger Lukes rc planes,I would post a link but there site is down,
TODD
I R Irv is offline Find More Posts by I R Irv
Old Dec 31, 2009, 04:03 PM
olmstead25 is offline
Find More Posts by olmstead25
Parkzone connectors here!!
olmstead25's Avatar
Joined Oct 2008
c140,
you can make your own charger plug into a flight pack if your willing to do a little soldering. simply take apart a charger and conect the power leads to your plug with a resistor on one of the sides. the resistor depends on how many cells you want to run and what the charge rate is set at on your charger. example: fully charged 2S = 8.4v, 4 AA= 6 volts if your charger is set at the minimum charge rate of 100Mah it is roughly the same drain on the battery. so you use ohms law to calculate that you will need a 27 Ohm 1/2 Watt resistor to get your supply to 6v then for your LED you will need to bring it down to 1.5 at 20Mah so that would be around a 270 Ohm 1/4 Watt. so for the price of 2 resistors and a battery plug you have one provided you have a PZ charger. any other questions PM me
olmstead25 is offline Find More Posts by olmstead25
Old Dec 31, 2009, 04:40 PM
C140 is offline
C140's Avatar
Madera, CA
Joined Jan 2009
Thanks, that's what I was looking for, but at $70, it's not gonna happen any time soon. I might try opening up a Parkzone one.
Old Dec 31, 2009, 04:48 PM
I R Irv is offline
I R Irv's Avatar
Joined Nov 2008
70$ is a bit much but after using it now I think it's worth every penny.
TODD
Old Dec 31, 2009, 04:59 PM
mtflyr is offline
Find More Posts by mtflyr
Centreville,VA,USA
Joined Apr 2001
The wing can be removed but it's glued on to the lower fuselage section. But since I want to activate this bird I left it on. It would have been a lot easier to do the panel lines with the wing off though.
My friend Jin made some awesome decals for me for the Glennon Moran, Little Ann P-51 scheme. (Thank U Jin)
I got the Blue Nose,rudder and prop done. Next the pilot and minor cockpit details. It's starting to look like it now.
Pete
mtflyr is offline Find More Posts by mtflyr
Old Dec 31, 2009, 05:01 PM
Doug Sipprell is offline
Find More Posts by Doug Sipprell
Elfi Flyer
Doug Sipprell's Avatar
Rock Hill, SC
Joined Oct 2002
Got mine at SEFF 2009. I was willing to pay the $$ for the convenience of having the charger immediately available, also to get the adjustable charge rate feature (adjustable for each of the four ports). Thus far, very satisfied with the charger, also the ability to mount it in or on the "hangar".
As already posted, Luke's Hobby seems to be the place where you can get this charger, possibly direct from ETF, but not sure on that. The 240 mAh Hyperion Lipo's I am now using will tolerate a 2 - 3C charge, so I can crank up one or more ports on the FourPlay to 350 mAh and get a recharged cell in about 20 minutes. Neat charger. I like it, might even get another to work in the Ember "hangars".
Doug Sipprell is offline Find More Posts by Doug Sipprell
Latest blog entry: Big Red Cadillac
Old Jan 02, 2010, 12:30 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Except for some John Morgan style weathering with chalk that I'll do later, I finished my PZ Micro P-51C.
Weight WO wing landing gear 1.1oz. so no real weight added.
Did some minor cockipt details and the decals my friend Jin made worked great.
Pete
Old Jan 02, 2010, 03:15 AM
JoeS475 is offline
Find More Posts by JoeS475
Warbird Flyer
North New Jersey
Joined Dec 2009
Wow!
Looks Great! I guess I'm gonna have to give up the Sharpie and electrical tape and try this for real
~Joe
JoeS475 is offline Find More Posts by JoeS475
Old Jan 02, 2010, 08:17 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Added some weathering and landing gear door covers, though I fly without the landing gear.
Pete
Old Jan 02, 2010, 10:28 PM
verticalspark is offline
Find More Posts by verticalspark
Aut Viam Inveniam Aut Faciam
verticalspark's Avatar
United States, CO, Colorado Springs
Joined Oct 2008
you plane looks awesome! Kinda wish I could do something like that, but I would end up crashing it.
verticalspark is offline Find More Posts by verticalspark
Old Jan 03, 2010, 08:12 AM
mtflyr is offline
Centreville,VA,USA
Joined Apr 2001
Thanks VS,
With these micro birds being so light even when you whack in there's usually very little if any damage. That's what I really like about this weight and size RC bird.
Pete
Old Jan 03, 2010, 08:41 AM
sniper1 is offline
Find More Posts by sniper1
sniper1's Avatar
Crawley Down, sussex, England
Joined Dec 2004
Greeeaatt!!
Pete
I have never been a big fan of the 'B' and 'C' versions of the Mustang, but you have made a truly beautiful model! I can appreciate the massive amount of work you put into it, to make it look historically accurate. The artistry and modelling skills to do that on a big model is one thing, but on this small and fragile plane, it is really tricky, as i have found out. I look forward to seeing some pictures of it flying!!
sniper1 is offline Find More Posts by sniper1
Old Jan 03, 2010, 06:14 PM
bungholio is offline
Find More Posts by bungholio
duct tape and hot glue
bungholio's Avatar
Olympia,WA
Joined Dec 2009
Thats pretty amazing mtflyr! Looks more like a display model than a flyer! Just try not to think about a rough landing
bungholio is offline Find More Posts by bungholio
Discussion Parkzone Micro P-51 rcozstyle Australia 13 Oct 15, 2009 04:51 PM
Gallery ***Show off your Scale Micro's or Mini's!*** Pigs dont fly Micro Helis 81 Oct 07, 2009 06:29 PM
Discussion Parkzone Micro P-51 rcozstyle Australia 32 Aug 24, 2009 06:47 PM
Show off your Micro Helis' "friends". beemer Micro Helis 3 Sep 03, 2005 02:28 PM
Show off your Sub-Micro!!! Minimole Micro Helis 39 Apr 20, 2005 10:20 PM
