Old Feb 03, 2010, 03:22 PM
Aros.MotionRC is online now
Find More Posts by Aros.MotionRC
Shameful Warbirdaholic.
Aros.MotionRC's Avatar
Maple Valley, WA
Joined Apr 2006
My understanding is that there needs to be a sufficient amount of resistance so it can snap in place when closed. Fishing line doesn't have elasticity for that. Thin rubber band would seem to work effectively if it could be rigged correctly.
Aros.MotionRC is online now Find More Posts by Aros.MotionRC
Site Sponsor
Old Feb 03, 2010, 03:42 PM
Dwhart24 is offline
Find More Posts by Dwhart24
Warbird junkie
Dwhart24's Avatar
Oviedo, FL.
Joined Feb 2009
Hmmm... If you look at post 109 of the pic of the gear it looks like when the gear goes up it just pulls a string up with it that is attached to the door. It looks like if you cut the string to the right length it would work. What is the door hinged with?
Dwhart24 is offline Find More Posts by Dwhart24
Old Feb 03, 2010, 03:47 PM
Maple Valley, WA
Joined Apr 2006
Yeah mine didn't come with any and I don't see how they work or how it's rigged.
Site Sponsor
Old Feb 03, 2010, 03:49 PM
Dwhart24 is offline
Warbird junkie
Dwhart24's Avatar
Oviedo, FL.
Joined Feb 2009
It looks like your pic in post 692, that the doors are hinged with small springs. Which would answer how the doors are kept open without the string. In the post 109 pic, it looks like there is a small screw that holds the mono on one side, and is strung across the top of the gear strut when the gear is in the up position.
Old Feb 03, 2010, 04:04 PM
Maple Valley, WA
Joined Apr 2006
Right. The hinges I guess offer the elasticity and there is added linkage on the gear itself that has the sole purpose of keeping the gear doors open when the gear is down. So the monofillament line must clamp down tightly when the doors close?
I don't know...I'm a "need photos or video to get it" kind of guy.
Site Sponsor
Old Feb 03, 2010, 04:10 PM
bighead93 is online now
Find More Posts by bighead93
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
Mine didn't have anything attached to the doors either.
bighead93 is online now Find More Posts by bighead93
Old Feb 03, 2010, 04:14 PM
guapoman2000 is offline
Find More Posts by guapoman2000
Account closed
Joined Oct 2002
David,
It seems like you are leaning towards this model after all.
I just wish you the best dealing with BH and after carefully watching this thread and all the posts, I would need to change out the struts, or retracts or both for my tastes.
As far as the Doors, I would hinge them and provide a light weight plastic mechanizim to close the doors and made from a CNC machine
For those that do not have access to CNC then, I would at least hinge and use the light weight fishing line.
For me, it is just too much moding.
guapoman2000 is offline Find More Posts by guapoman2000
Old Feb 03, 2010, 04:51 PM
Maple Valley, WA
Joined Apr 2006
For any of you with the mono line, would you mind taking close up shots of how it is attached to the inside of the gear area as well as the doors? That will help those of us out that need to rig our own setup...Thanks!
Site Sponsor
Old Feb 03, 2010, 04:57 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
It looks to me that once the wheels retract that the doors would close behind because of the springs...I will have to test it!
Old Feb 03, 2010, 05:04 PM
moonpock is offline
Find More Posts by moonpock
I don't need no stink'n nitro!
Thompsons Stn, TN
Joined Nov 2008
That's backwards... The springs open the doors, the line pull them shut. I know, because I've got one door stuck open (clue got in the hinge and caused the mono to pull off the door) and two doors that won't open until I drop the gear (I'm hoping that's all it is).
That's what you guys get for buying the green ones! My silver has monofilament...
moonpock is offline Find More Posts by moonpock
Old Feb 03, 2010, 05:10 PM
moonpock is offline
Thompsons Stn, TN
Joined Nov 2008
I'll post some pics as soon as I get the "test" wiring done... Going to plug it all up to see what works and what doesn't, before I go any further.
Old Feb 03, 2010, 05:13 PM
Dwhart24 is offline
Warbird junkie
Dwhart24's Avatar
Oviedo, FL.
Joined Feb 2009
Originally Posted by guapoman2000 View Post
David,
No, I am not leaning torwards this model. Just adding my observations.
Old Feb 03, 2010, 05:18 PM
Sunbather is offline
Find More Posts by Sunbather
Santa Rosa, CA
Joined Nov 2008
Here is where the wires labeled:
#1 Ailerons
#2 Rudder/Elevator (Can't see which is which)
#3 ESC
#4 Rudder/Elevator (see#2)
#5 Gear
Hope this helps,
John
Sunbather is offline Find More Posts by Sunbather
Old Feb 03, 2010, 05:40 PM
Live to fly
bighead93's Avatar
Sacramento
Joined Apr 2005
#1 Ailerons
#3 ESC
#5 Gear
Hope this helps,
John
PERFECT!! Thanks a bunch John! Easy to swap 2 and 4! Did you start building yours?
Old Feb 03, 2010, 05:48 PM
Account closed
Joined Oct 2002
David,
Oh....I see....
Discussion Banana Hobby P-51 w/2.4 GHz Tx/Rx cypherpix Electric Warbirds 9 Nov 26, 2008 03:32 PM
For Sale (NEW) F-Model P-38 Cowls Orion Pax Aircraft - Electric - Airplanes (FS/W) 13 Oct 30, 2008 07:22 PM
New Product New Phase 3 P-38 = EMI P-38 repackaged? shschon Electric Warbirds 16 Nov 25, 2007 11:57 AM
Discussion New E-flite P-38 pda4you Foamies (Kits) 1 Jan 12, 2007 11:04 PM
New Product New web shop, New product *EMI P-38 Forked Tail Devil * infinityhobby Product Announcements 60 Nov 03, 2006 06:48 PM
