Espritmodel.com Heli Air
Old Oct 09, 2012, 10:15 AM
Yes it was Abby Normal
Joined May 2012
Originally Posted by dude_109 View Post
TwistedGrin,
I was just browsing YouTube over the weekend looking at JPower P-38 and saw a vid where a guy had 1 motor also come off but it was right when he landed and taxi in...extremely lucky. I've got the V2 kit so will be sure to give the motor some test yanks.
Ya man check 'em twice er thrice....I yanked on mine and felt OK. Note, you have to take off the motor bulkhead mount off of the fuselage. These are the two screws that hold the motor/bulkhead mount to the fuselage. Then there are Four screws that hold the motor to that bulkhead mount. On mine...which I now know is the V2 version...this bulkhead mount is a clear plexi-plastic. I have an idea these screws came loose and allowed the motor to tork away.
The plexi-plastic bulkhead motor mount did not come off the fuselage...the motor actually ripp/torked out of the bulkhead motor mount.....CRAZY!!!!
I did notice some popping of this plane when I bench tested it at WOT...but everything flexes so much I could not tell what was popping....still don't know if it was that motor mount or not....anyway....do put this on your assembly check list. Take it off...tork it down...re-assemble...check it check it check it.
TwistedGrin
TwistedGrin is online now Find More Posts by TwistedGrin
Old Oct 09, 2012, 07:42 PM
WestTexasKing's Avatar
Monahans TX
Joined Sep 2010
Twisted, from the looks of the foam directly behind the motor mount, it appears that it was overheated.
That bubbly texture in the center of the nacelle is what foam looks like when exposed to way too much heat.
On top of that, it also looks like the motor mount screws seemed to have melted the plexi.
Are you sure that the screws broke out of the plexi or did they melt?
Good job taking it in without damage, I've had to do it a few times myself...more fun than a monkey full of barrels LOL
WestTexasKing is offline Find More Posts by WestTexasKing
Old Oct 09, 2012, 10:43 PM
Joined May 2012
WTK, I also thought about heat issue, but remember noting this from brand new and the other side is identicle. I am begnining to think one of the motor mounts just backed completely out, the other gots loose....enough to rub against the nacelle. Proably did generate enough heat to soften the plexi-plastic mount and tork its way out of its other three holes.....the nacelle foam is the same on the other side, so I don't think it melted the foam.
The motor smells fine, and spins freely but I won't bother powering it up since the wires are all twisted and mangled. Now the motor wires did get melted together....I could heat shrink them but I would never trust them again. So yes..it did get hot but not sure when it got hot..for sure after the wires touched each other as they twisted together the moment the motor broke loose...and even until I was able to unplug the battery.
It is such a cool plane and not seen that often...I must have one ready to fly anytime....and it was really fun to land...was infinately bummed when that bbbbrrlrlrlrlaaap sound was heard. I am looking forward to flying it again ASAP. This is another great TurkeyBuzzard chaser too.
TwistedGrin
Old Oct 10, 2012, 08:50 AM
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Rather than buying or resoldering to reverse elevator servos,
Resoldering will NOT reverse the elevator servo!
You should be able to mix it easily, or find an inline reverser for just a few bucks.
rdeis is offline Find More Posts by rdeis
Old Oct 10, 2012, 08:58 AM
03svtsnakevert's Avatar
USA, TX, Copperas Cove
Joined Jul 2010
I beg to differ you can resolder to reverse the servo...I've done it
03svtsnakevert is offline Find More Posts by 03svtsnakevert
Old Oct 10, 2012, 10:39 AM
AMA 353531
rdeis's Avatar
Joined Aug 2003
Sorry, then I misunderstood.
Most people that attempt to rewire a servo reverse the wrong thing and smoke the servo. (I've done that myself and seen many others do or propose the same) Can you show me your successful technique?
Old Oct 10, 2012, 10:45 AM
Joined Jul 2010
Sure...here's the link
How to REVERSE a Servo. (4 min 32 sec)
Old Oct 10, 2012, 03:42 PM
dude_109's Avatar
Houston, TX
I've watched those vids but my soldering skills is not nearly good enough to do such things for these tiny 9 gram servos.
The inline reverser is an option but programming mix would probably be better if I still have spare channel on the RX. I've tried doing mixes before on other planes with success on some and terrible failures (crashes) on others so was hoping someone has good solid procedure for me to just follow.
dude_109 is offline Find More Posts by dude_109
Old Oct 11, 2012, 08:19 AM
AMA 353531
rdeis's Avatar
Joined Aug 2003
I'm sure it can be done, but you need to talk to someone with a DX7 to get the particulars. You need to slave the reveresed channel to the elevator, set the slope to -100%, and probably set an offset so they both find neutral in the same place.
You might try the radio forum for a DX7 programming expert?
Old Oct 11, 2012, 08:26 AM
Kurt's Avatar
Beer City
Joined Sep 2003
I know it's probably been given somewhere in this thread, but couldn't find through searching the largest battery someone's running in a V2.
With the removable canopy it looks like a pack longer than 120mm will fit no problem, but without trimming the width is the same 35mm and height 30mm as the V1.
Is anyone running larger than 2200mAh 4s in their V2, and could you please give the brand and C rating?
I'd like to run a 2600-3000 but the likely candidates on HK all seem to be either too wide or too tall, like these:
Nano-Tech, 44mm height:
http://www.hobbyking.com/hobbyking/s...dProduct=20437
Zippy, 45mm height
http://www.hobbyking.com/hobbyking/s...dProduct=21787
thanks!
Kurt is offline Find More Posts by Kurt
Old Oct 11, 2012, 08:32 AM
Joined Jul 2010
We are either running a 3300-4000
Old Oct 11, 2012, 08:50 AM
Kurt's Avatar
Beer City
Joined Sep 2003
Thanks, which brand and C rating?
When you get a chance, could you pls take a photo of it in place?
thanks much!
Old Oct 11, 2012, 09:22 AM
Owatonna MN 55060
Joined Sep 2005
Servo City will reverse a new one for you. I got a matched pair from them for the elevator on one of my P-38's.
http://www.servocity.com/index.html
Gohmer is online now Find More Posts by Gohmer
Old Oct 11, 2012, 11:22 AM
Joined May 2012
Zippy, 45mm height
thanks!
I have not flown with this battery yet:
http://www.hobbyking.com/hobbyking/s...dProduct=21350
It will fit, albeit very tight fit. I will need to remove just a tad bid of foam for it..but it is nearly the same size as my Genesis 2800mAh 3S 55C
Best Regards,
TwistedGrin
Old Oct 11, 2012, 11:58 AM
dude_109's Avatar
Houston, TX
I've ordered from them in the past. Good to know about that service.
Discussion Banana Hobby P-51 w/2.4 GHz Tx/Rx cypherpix Electric Warbirds 9 Nov 26, 2008 03:32 PM
For Sale (NEW) F-Model P-38 Cowls Orion Pax Aircraft - Electric - Airplanes (FS/W) 13 Oct 30, 2008 07:22 PM
New Product New Phase 3 P-38 = EMI P-38 repackaged? shschon Electric Warbirds 16 Nov 25, 2007 11:57 AM
Discussion New E-flite P-38 pda4you Foamies (Kits) 1 Jan 12, 2007 11:04 PM
New Product New web shop, New product *EMI P-38 Forked Tail Devil * infinityhobby Product Announcements 60 Nov 03, 2006 06:48 PM
