Old Sep 27, 2012, 01:26 PM
BrownEyedFool is offline
Find More Posts by BrownEyedFool
You're killin' me Smalls
BrownEyedFool's Avatar
United States, NJ, Hillsborough Township
Joined Sep 2011
Killerplanes lists a bunch of spares for that plane and you can call or PM them as well.
BrownEyedFool is offline Find More Posts by BrownEyedFool
Old Sep 27, 2012, 02:26 PM
TwistedGrin is offline
Find More Posts by TwistedGrin
Yes it was Abby Normal
Joined May 2012
Aye - Will do .....I have been restraining myself from ordering one for a couple of weeks now....has to be a fun plane to fly. But would also like to keep it in the air with repairs and parts if needed....
TwistedGrin
TwistedGrin is offline Find More Posts by TwistedGrin
Old Sep 28, 2012, 06:59 AM
ww2birder is online now
Find More Posts by ww2birder
too many planes
ww2birder's Avatar
United States, MI, South Lyon
Joined Sep 2012
I would pull the trigger and purchase this one. Stock it flies fantastic and retro fitting parts is not a big deal. The stock landing gear is cheap so turn it into a belly lander. I would also lock tight the motors; the threaded nut can come loose. If you get the silver one it can serve as a under paint for a olive drab variant. Like all p-38s the twin booms are the weak point but can easily be fixed with a carbon spar. hope these ideas are helpful .... Matt
ww2birder is online now Find More Posts by ww2birder
Old Sep 28, 2012, 07:43 AM
eggsplurt is offline
Find More Posts by eggsplurt
USA, NJ, Red Bank
Joined Sep 2010
This airplane with Matt's recommended beef-ups ...booms....horizontal stab....get rid of the gear and hand-launch...etc....it's super. I run the stock motors with Du-Bro 2 1/4 inch spinners and early ParkZone 2 bladed 10 X 8's from the FW-190, Spitfire, and P-51.....Those props are a dime a dozen and the plane performs and sounds spectacular with them......Steve....I'm unloading my stash of E-Flite P-38's in favor of the J-Power Bird.........$145.00 each plus S/H......Steve.....732-530-2061
eggsplurt is offline Find More Posts by eggsplurt
Old Sep 29, 2012, 08:37 PM
peterswolf is online now
Find More Posts by peterswolf
peterswolf's Avatar
United States, FL, Riverview
Joined Apr 2012
Was working on mine on the bench this evneing and noticed engine #2 was pulsing a bit, I'm guessing I won't be flying it in the morning and should probably order some new motors. What are the best drop in replacement motors with minimal modding required? I've got a V1, running stock ESC and stock motors (changed to counter rotating) with MAS 9x7x3 puller/pusher props. I'd like to be able to just drop in some new motors and keep the stock spinners and still use the MAS props. Thanks for any help!
p.s. if motors can be ordered from HeadsUpRC that'd be a plus!
peterswolf is online now Find More Posts by peterswolf
Latest blog entry: http://www.peterswolf.com
Old Sep 29, 2012, 08:46 PM
too many planes
ww2birder's Avatar
Joined Sep 2012
Wolf I'd replace the speed controls before the motors. 2 30 amp speedys should do the trick. Hobby king has D 4023 850kv Bell housing type motors.
Old Sep 29, 2012, 08:53 PM
peterswolf's Avatar
Joined Apr 2012
Another issue now started with engine #2, from zero throttle, if I advance slowly engine #2 starts to very slightly stutter and never actually spins up just sits there being jerky, while engine #1 spins up nice a smooth. If I cut the throttle, advance the prop with my finger, then advance the throttle again engine #2 spins up normally about 50% of the time. I notced if I cut throttle and then advance again right away same thing, half the time engine #2 spins up, the rest of the time it stutters. Now that would really suck in the air. So does this sound like esc or motor issue?
Old Sep 29, 2012, 08:57 PM
Nikolei Zinsli is offline
Find More Posts by Nikolei Zinsli
If it's R/C, I LIKE IT!
Nikolei Zinsli's Avatar
United States, NC, Raleigh
Joined Jun 2005
Might be a bad pole on the motor. Try connecting it to a different ESC and see what happens.
On another issue, what are good motors for a step up in power?
Nikolei Zinsli is offline Find More Posts by Nikolei Zinsli
Latest blog entry: 93" AJ Laser 230z
Old Sep 29, 2012, 09:05 PM
too many planes
ww2birder's Avatar
Joined Sep 2012
Ya those motors are not the greatest. Take the motor off and check the threaded rod isn't loose. Sometime you have to lock tight those things. Also, tighten the grub screws on those funky motor mounts. Hope it help dude.
Old Sep 29, 2012, 10:58 PM
jpflyer is offline
Find More Posts by jpflyer
USA, TX, Corpus Christi
Joined Oct 2001
bad connection
Sounds like you have a bad connection between the motor and esc. Motor going out of phase, maybe. Check your connections just to be sure.
jpflyer is offline Find More Posts by jpflyer
Old Oct 01, 2012, 08:59 AM
gadorey is offline
Find More Posts by gadorey
Germany, NDS, Groß Twülpstedt
Joined May 2011
Another few flights with only a rough landing, but no damage. Otherwise all very nice. I'm liking this bird more and more. Started pushing it a bit more and did some rolls and loops. All very easy, but the wings do flex when you push her.
I set the timer down to 9min and both batteries were down to 30% (3S 2200mAh 30C). I think that's where I'll stay with my times, so 10min are out.
here's some pictures of the day thanks to my gracious wife
gadorey is offline Find More Posts by gadorey
Old Oct 01, 2012, 09:14 AM
Kurt is offline
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
nice pics!
Great to see people still enjoying this excellent plane.
I'm itching to build up the V2 kit sitting in it's box, love flying my FMS Mustang, PZ T28 and Stinger jet but greatly miss having a Lightning...
Kurt is offline Find More Posts by Kurt
Old Oct 01, 2012, 09:23 AM
gadorey is offline
Joined May 2011
Thanks Kurt.
You won't regret it. It's one of my easiest and fun planes to fly. And supprisingly trouble free until now. Just read through the thread and watch out for some pointers to avoid trouble from the start. I did and until now no nasty surprises.
Old Oct 01, 2012, 09:55 AM
Kurt is offline
Upstanding Member
Kurt's Avatar
Joined Sep 2003
oh believe me I know!
http://www.rcgroups.com/forums/showp...postcount=5070
I got too cocky on flight 25 or so, and destroyed my modded V1 while doing low, fast rolls
Plan on having my second one around for a lot longer
Old Oct 01, 2012, 10:30 AM
Joined May 2012
Gents, I just ordered this plane...I would like to set up counter rotating prop on motor #2....can anyone point me to the correct 3 Blade pusher prop for this effort??
Thanks in advance,
TwistedGrin
Discussion Banana Hobby P-51 w/2.4 GHz Tx/Rx cypherpix Electric Warbirds 9 Nov 26, 2008 03:32 PM
For Sale (NEW) F-Model P-38 Cowls Orion Pax Aircraft - Electric - Airplanes (FS/W) 13 Oct 30, 2008 07:22 PM
New Product New Phase 3 P-38 = EMI P-38 repackaged? shschon Electric Warbirds 16 Nov 25, 2007 11:57 AM
Discussion New E-flite P-38 pda4you Foamies (Kits) 1 Jan 12, 2007 11:04 PM
New Product New web shop, New product *EMI P-38 Forked Tail Devil * infinityhobby Product Announcements 60 Nov 03, 2006 06:48 PM
