Old Sep 24, 2012, 06:56 PM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Originally Posted by gadorey View Post
and the ailerons slightly raised as well as aileron differential. Right now I'm very happy with it, maybe at a later point I'll reduce the spoileron effect or differential to see if there are any improvements in other areas.
Hey Gadorey, I don't remember reading on here about the aircraft needing any permanent up aileron deflection. Why do you do that?
FWIW, I can literally harrier mine around upright and inverted without a hint of tip stall, so can't see the need for it myself unless I'm missing something. It's a pretty benign handling plane this one.
Sub
subsonic is online now Find More Posts by subsonic
Old Sep 24, 2012, 08:54 PM
gadorey is offline
Find More Posts by gadorey
Germany, NDS, Groß Twülpstedt
Joined May 2011
Originally Posted by Hornetnz View Post
Gadorey, Is yours stock? v1 or v2? I have stock v1 and use 3s 2300mah packs and a 7 minute flight would be pushing it. As is, some of my packs get puffy if I'm WOT too much. Failing to see how you're going to get a 10 min flight!
I don't know, but that's what I'm getting. Started with 5 min on the timer, increased it to 7 min, then to 8min. I charged my bat. after the 8 min flight last night and put in 899mAh on the 2200mAh Lipo. That's still 59% charge left after 8 min.
It is all stock and from the descriptions about V1 and V2 I guess it's a V1, although the under carriage doors are spring loaded to shut, but the retracts are with servos. I must say I fly slow and sedatetly and mostly between 1/4 and 3/4 throttle. Full Throttle is very seldom and only short bursts when needed. No acrobatics either - did a loop once. I guess as my confidence with her grows and start pushing the limits more I might have to readjust the flight times down.
gadorey is offline Find More Posts by gadorey
Old Sep 24, 2012, 08:59 PM
gadorey is offline
Joined May 2011
Sub
You probably don't. Old beginner habit of mine, I always set all my planes with aileron differential and put in some up trim on both ailerons to start with. Added safety for the maiden, I guess. With the P-38 I have about a trailing wedge width up. But as she flys, she probably doesn't need it as you say. Since I'm not big on accrobatics and am not going for sharp rolls or anything like that, I haven't noticed any negative effects either.
Old Sep 25, 2012, 09:10 PM
gadorey is offline
Joined May 2011
so finally here's some pictures. Had a small mishap today. I was practicing touch and goes and veered off the runway landing on the side ditch. Only damage was a snapped boom were the tail is attached. Broke clean off the square block that goes into the tail - a well known weak spot. A toothpick and epoxy and should be flying again tomorrow
Old Sep 26, 2012, 04:24 AM
WestTexasKing is offline
Find More Posts by WestTexasKing
WestTexasKing's Avatar
Monahans TX
Joined Sep 2010
I see the problem, your props are made of rubber LOL
She's looking good, gadorey!
WestTexasKing is offline Find More Posts by WestTexasKing
Old Sep 26, 2012, 08:52 AM
maddawg1 is offline
Find More Posts by maddawg1
maddawg1's Avatar
so-cal
Joined Jun 2010
Well crash my p-38 today (RIP) and i want to order a new one but i see Banana is not sell J-Power anymore dose anyone know where i can order the J-Power V2?
maddawg1 is offline Find More Posts by maddawg1
Old Sep 26, 2012, 08:55 AM
peterswolf is offline
Find More Posts by peterswolf
peterswolf's Avatar
United States, FL, Riverview
Joined Apr 2012
oh no, what happened?
I'm not sure on the V2 being anywhere, I know HK just got a bunch of V1's (I assume V1's) in stock in the USA location. Just replace the retracts with servoless ones and you'd be good to go really...
peterswolf is offline Find More Posts by peterswolf
Latest blog entry: http://www.peterswolf.com
Old Sep 26, 2012, 08:56 AM
Hink64 is online now
Find More Posts by Hink64
Hink64's Avatar
Cape Coral, Fl
Joined Jan 2010
I'm not sure on the V2 being anywhere, I know HK just got a bunch of V1's in stock in the USA location. Just replace the retracts with servoless ones and you'd be good to go really...
Try this - X-UAV makes the J-power
http://www.generalhobby.com/xuav-lig...cts-p-335.html
Hink64 is online now Find More Posts by Hink64
Old Sep 26, 2012, 09:03 AM
maddawg1 is offline
maddawg1's Avatar
so-cal
Joined Jun 2010
Thanks guys The Pilot got to cocky flying to close to the ground and clip the tip of the wing on the ground in a turn. you know how after you have a lot of time on a plane (over 100 flights) you want more excitement well some time it bite you that what happen to me.
Old Sep 26, 2012, 09:12 AM
gadorey is offline
Joined May 2011
Yes, but it's Chinese rubber
For those of you trying to find this model, you could always try here.
http://item.taobao.com/item.htm?spm=...d=10149035869&
That's where I bought mine. Of-course having a wonderful asistent like I do helps, but if you manage to talk to them I'm sure they will find a way to send you the box. recognise the pictures? You've got to love China.
Old Sep 26, 2012, 09:40 AM
jpflyer is offline
Find More Posts by jpflyer
USA, TX, Corpus Christi
Joined Oct 2001
V2
I think you can get a V2 here in the US from these guys,
http://www.killerplanes.com/product/...fighter-wservo
jpflyer is offline Find More Posts by jpflyer
Old Sep 26, 2012, 09:47 AM
BrownEyedFool is online now
Find More Posts by BrownEyedFool
You're killin' me Smalls
BrownEyedFool's Avatar
United States, NJ, Hillsborough Township
Joined Sep 2011
Try Toysonics:
http://www.toysonics.com/p-38-lightn...-retracts.html
or killerplanes
The killerplanes description says that is the v2 plane, they also have the crashproofing available for the plane to reinforce weak spots or where the plane tends to break. Steve is active here at RCG and answers PMs, his username is killerplanes (shocker I know).
Hope this is a help.
BrownEyedFool is online now Find More Posts by BrownEyedFool
Old Sep 26, 2012, 12:36 PM
tracknoob is offline
Find More Posts by tracknoob
Diverted by planks
tracknoob's Avatar
South Florida
Joined Dec 2010
Love the photos, great stuff! Flew mine today, but did not get any footage.
tracknoob is offline Find More Posts by tracknoob
Old Sep 27, 2012, 06:54 AM
ww2birder is offline
Find More Posts by ww2birder
too many planes
ww2birder's Avatar
United States, MI, South Lyon
Joined Sep 2012
I replaced my motors with 3542 1100s and 2 30 amp speedys. Shes very fast and very heavy but flies like its on rails. I guess I got lucky with the correct down thrust.I also painted it olive drab and used aluminum pop cans as gear doors. The stock gear was scrap so I used E flite tricycles they work great and gave me a little more ground clearance with the props.
ww2birder is offline Find More Posts by ww2birder
Old Sep 27, 2012, 11:31 AM
TwistedGrin is offline
Find More Posts by TwistedGrin
Yes it was Abby Normal
Joined May 2012
JP P-38's....where are you finding spare parts....props and spinners to be specific....looking into putting one of these planes in my squadron....but hesitant about finding parts....looks like the Aircraft is being discontinued. Killer Planes may have some in stock...but not sure about spare parts a few months from now
Best Regards,
TwistedGrin
TwistedGrin is offline Find More Posts by TwistedGrin
Discussion Banana Hobby P-51 w/2.4 GHz Tx/Rx cypherpix Electric Warbirds 9 Nov 26, 2008 03:32 PM
For Sale (NEW) F-Model P-38 Cowls Orion Pax Aircraft - Electric - Airplanes (FS/W) 13 Oct 30, 2008 07:22 PM
New Product New Phase 3 P-38 = EMI P-38 repackaged? shschon Electric Warbirds 16 Nov 25, 2007 11:57 AM
Discussion New E-flite P-38 pda4you Foamies (Kits) 1 Jan 12, 2007 11:04 PM
New Product New web shop, New product *EMI P-38 Forked Tail Devil * infinityhobby Product Announcements 60 Nov 03, 2006 06:48 PM
