Old May 07, 2012, 10:20 PM
Kurt is online now
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
Originally Posted by subsonic View Post
Heh, that's hobbyking's build for you. My servo horns are at 90 when at neutral
LOL I didn't even see the HK watermark :facepalm:
I'd love to see them try to fly that plane
Kurt is online now Find More Posts by Kurt
Old May 08, 2012, 08:30 AM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Landing Gear Doors
Okay I'm down to just the landing gear doors now...THANK GOD!
How are you guys securing the hinges to the foam?
Screws through the foam into wood?
Can't get over how "rubbery" the propeller blades are.
RGS2010 is offline Find More Posts by RGS2010
Old May 08, 2012, 08:51 AM
mike2663 is online now
Find More Posts by mike2663
Hey Guys, Watch This.......
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
This thing needs a "real pilot" any suggestions? My V2 shows "out for delivery" time to start gathering the essentials.
mike2663 is online now Find More Posts by mike2663
Old May 08, 2012, 07:49 PM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
I tried the programming that was posted for the DX8 but it isn't the same options as my DX6i. Has anyone programmed their DX6i with nose steering on Aux channel?
Please share.
Russ
Old May 08, 2012, 08:03 PM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Originally Posted by nigelsheffield View Post
I had the same problem, it's easy(sort of) one mix is all thats needed
plug nose steering servo into aux, mix rudder to flap and use gear to swtich, you probably will need about +70% up and down but that's down to personal preference and set up flap sub trim so that servo does not stall when retracted. good luck.
Obviosy you will have to use y lead for ailerons, and no flaperons are not available but thats no porblem with this plane.
I understand everything except the sub trim for flaps...so what number for flap sub trim?
Russ
Old May 09, 2012, 01:08 AM
nigelsheffield is online now
Find More Posts by nigelsheffield
United Kingdom, Horbury
Joined Oct 2007
you will need to experiement with sub trim to stop the servo chattering when retracted
nigelsheffield is online now Find More Posts by nigelsheffield
Old May 09, 2012, 10:28 AM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
I did this (the whole programming mode, not just sub trim) and it sure enough makes the servo steerable but it also steers when retracted in too!
I had to make a little mod on my rudders since both of them cracked while I was setting throws, etc. They are just SOOOO flimsy at that point. My little toothpick fix was just the trick. I dremeled out a slot and then CA'd with medium CA toothpics in the slot and filled and painted...not too bad if I say so myself.
Russ
Old May 09, 2012, 06:22 PM
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
This whole gear door set up is pretty bizarre. Sometimes one works and sometimes it won't go figure. The nose and left doors work every time. Then there's the finicky right door. Rebound swapped leads and now I'm out of Ideas. The servo works as I checked it independent of the sequencer which I guess could be bad.
Old May 09, 2012, 07:39 PM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Perfect Nose Gear Steering Programming
Thanks to FreeChip...here is perfect nose gear steering and inhibit of steering when retracted...for DX6i
Mix1 RUDD > FLAP
Rate 100% 100%
Sw ON
This is so the nose gear servo moves with the rudder
Mix2 RUDD > FLAP
Rate -100% -100% (notice minus values here)
SW GEAR
This is when the gear switch is toggle up and the gear retracts the rudder nose gear servo from mix 1 is now disable and centered.
My servo monitor show the AUX1/FLAP channel moving with the rudder (steerable nose gear) and when the gear is retracted AUX1/Flap channel is no longer moving..
Old May 09, 2012, 09:13 PM
03svtsnakevert is offline
Find More Posts by 03svtsnakevert
03svtsnakevert's Avatar
USA, TX, Copperas Cove
Joined Jul 2010
got the counter rotating props mounted....looks pretty sweet on spin up...also does not feel like it wants to pull any one direction besides forward...re-maiden coming soon
03svtsnakevert is offline Find More Posts by 03svtsnakevert
Old May 10, 2012, 07:33 AM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Mine is same thing but it's my right retract. It will work 5 times every time and then won't go down and then after cycling, it will work several times, up to 10 times before failing again. I use Spektrum DX6i and increased servo travel to 110% just to see and it made no difference. Guess I'll have to live with it, whatever it is.
But I'm ready to maiden this weekend and can't wait to get this one in the air!
Old May 10, 2012, 08:16 AM
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
I'm using a DX7 and 7100 receiver after taking care of some around the house issues I'll look it over again. There has to be a solution. I hate to take the doors off. There are ways around that also such as rubber bands, string or springs attached to the doors to manually close them. Their wiring harness may be the issue. Way to much going on there IMO. It is what it is and I'll deal with it. That's what makes this interesting, overcoming issues.
Overall I like the looks of the V2.
Mike.
Old May 10, 2012, 12:49 PM
rdeis is offline
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
I didn't see how you've got the gear doors set up, but if there's a sequencer and separate servos, I'd blame the sequencer switch.
Maybe it needs cleaned, or maybe it's mounted in a flexible spot that keeps the switch from beign fully depressed every time?
rdeis is offline Find More Posts by rdeis
Old May 10, 2012, 01:28 PM
mike2663's Avatar
USA, TX, El Paso
Joined Dec 2003
Actually it must be in thier harness. Once I bypassed it and went directly to the sequencer ( using extensions and a Y harness) the problem cleared right up. The rats nest of wires is my next project.
Old May 10, 2012, 03:42 PM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
I have the V1, and after the first gear door fell off in my hand, I just pulled the rest of them off. They get in the way and they're not scale anyway, so. Bye bye.
subsonic is online now Find More Posts by subsonic
Discussion Banana Hobby P-51 w/2.4 GHz Tx/Rx cypherpix Electric Warbirds 9 Nov 26, 2008 03:32 PM
For Sale (NEW) F-Model P-38 Cowls Orion Pax Aircraft - Electric - Airplanes (FS/W) 13 Oct 30, 2008 07:22 PM
New Product New Phase 3 P-38 = EMI P-38 repackaged? shschon Electric Warbirds 16 Nov 25, 2007 11:57 AM
Discussion New E-flite P-38 pda4you Foamies (Kits) 1 Jan 12, 2007 11:04 PM
New Product New web shop, New product *EMI P-38 Forked Tail Devil * infinityhobby Product Announcements 60 Nov 03, 2006 06:48 PM
