Old Apr 10, 2012, 03:38 PM
Gohmer is offline
Find More Posts by Gohmer
Owatonna MN 55060
Joined Sep 2005
Originally Posted by RGS2010 View Post
I got all of my wires together and connected last night and then connected battery for first time and NUTHIN happened.
I couldn't get any power to get the RX to bind at all. I would see a little flicker of power when I connected it at the connector but nothing to the RX.
I then went back to each nacelle and tried to bind to just one ESC at a time and nothing there either. I did this with both ESC's individually and same thing nothing. The only thing I can think of is that I have 2 bad ESC's!!!
They are both 50 amp Red Brick Opto ESC's from HK and although both of these are new, I've been using this type for two other planes with no problems.
It wouldn't matter how the motor wires are connected to the ESC except that the motor might turn opposite direction right?
Any other thoughts would be appreciated...
Russ
Most Opto ESC's don't have any BEC. What are you powering your RX with?
Gohmer is offline Find More Posts by Gohmer
Old Apr 10, 2012, 04:05 PM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Russ
Don't get frustrated, work through it step by step.
If you have 11.1v from the main power wires to the ESCs you should at least get beeps from them. Start by sorting that.
What do you mean by a "flicker of power". On some receivers, if you put the power lead in upside down you will get a flash from one of the RX LEDs.
Sub
subsonic is online now Find More Posts by subsonic
Old Apr 10, 2012, 07:15 PM
WestTexasKing is offline
Find More Posts by WestTexasKing
WestTexasKing's Avatar
Monahans TX
Joined Sep 2010
Sounds like the same problem I had with mine when I first got it.
I'd tell you how I fixed it, but I honestly have no idea what I did to fix it LOL
WestTexasKing is offline Find More Posts by WestTexasKing
Old Apr 11, 2012, 08:30 AM
RGS2010 is offline
Find More Posts by RGS2010
Always Fly 2 Mistakes High!
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
Well it was a comedy of errors but I found it. It was one bad esc and one bad attention problem. I had esc wire connected with wrong extension cable. Got that esc with the HK bec on it to work fine. Then hooked up other and still dead. Put another esc on it (with red wire cut) and hooked both motors up and they worked!
RGS2010 is offline Find More Posts by RGS2010
Old Apr 11, 2012, 11:29 AM
jpflyer is online now
Find More Posts by jpflyer
USA, TX, Corpus Christi
Joined Oct 2001
Russ
If they are Opto's don't you need a ubec or separate battery to the receiver?
jpflyer is online now Find More Posts by jpflyer
Old Apr 11, 2012, 12:05 PM
03svtsnakevert is offline
Find More Posts by 03svtsnakevert
03svtsnakevert's Avatar
USA, TX, Copperas Cove
Joined Jul 2010
Yes you do
03svtsnakevert is offline Find More Posts by 03svtsnakevert
Old Apr 11, 2012, 12:42 PM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
I have one
Yes I have an HK 5 amp BEC wired into one of the ESC's and the other one is an ESC with an onboard bec that I disabled by cutting the red wire. When I hooked 'em all together they played nicely and ran those motors smoothly.
Old Apr 12, 2012, 08:37 AM
Kurt is online now
Find More Posts by Kurt
Upstanding Member
Kurt's Avatar
United States, TX, Houston
Joined Sep 2003
Joining the Jpower P-38 club
Put my order in to HK on Friday, oversized box is packed and should be shipping soon.... Can't wait!
Is the general consensus here that a BEC should be added immediately (i.e. before the first flight?). My understanding this is (partially?) to ensure both motors stop at the same time when the battery gets low?
I intend to limit my first flights to ~5minutes with the Turnigy 2200MAH battery , then check the voltage.
What ending V should be the aim for a flight, leaving some margin for go-arounds and not running them too low?
Can you give a link or model number for your BEC?
I've seen this BEC/LVC one mentioned here:
http://www.dimensionengineering.com/products/smartbec
thanks! The P-38 has always been my dream plane, hopefully will have many, many enjoyable flights with her!
Kurt is online now Find More Posts by Kurt
Old Apr 12, 2012, 11:11 AM
Nikolei Zinsli is online now
Find More Posts by Nikolei Zinsli
If it's R/C, I LIKE IT!
United States, NC, Raleigh
Joined Jun 2005
I use the smartbec on my p-38 and think its a wise investment. Luckily, I havent had to "use" it yet, but I did test it with a low battery pack and indeed both engines slowed at the same rate instead of one cutting off before the other.
You're ending voltage should be 11.1 minimum for a 3s. Figure your time based on how long it takes you to get down to that at full throttle. I've timed my flights for a 3s 2200mah to around 6.5 minutes.
Nikolei Zinsli is online now Find More Posts by Nikolei Zinsli
Latest blog entry: 93" AJ Laser 230z
Old Apr 12, 2012, 11:27 AM
huntingfield is offline
Find More Posts by huntingfield
Clean up! The missus is home
huntingfield's Avatar
United States, MD, Salisbury
Joined Dec 2007
I just ordered the airframe only P-38 from BH. It comes with the motors. I was wondering would 25 amp ecs' work ok. I needed a new P-38 as I crashed my Phase 3 veteran by doing a roll and having the battery fall out! A real shame!
huntingfield is offline Find More Posts by huntingfield
Old Apr 12, 2012, 12:13 PM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
I would use 30 amp or above.
Old Apr 12, 2012, 12:16 PM
RGS2010 is offline
RGS2010's Avatar
Houston, Texas
Joined Mar 2010
[QUOTE=Kurt;21308136]Can you give a link or model number for your BEC?
http://hobbyking.com/hobbyking/store...dproduct=16663
Here ya go. Just remember to cut the red wire on ESCs with the BEC built in after you add the separate BEC.
Russ
Old Apr 12, 2012, 12:25 PM
rdeis is online now
Find More Posts by rdeis
AMA 353531
rdeis's Avatar
United States, CO, Colorado Springs
Joined Aug 2003
Minor clarification:
A separate BEC is used to power the rx and servos. This is a Good Idea becasue 1> this airplane has a lot of servos, and 2> running two built-in BECs in parallel sometimes causes problems. (depends on the brand) There are other ways to deal with the problem, but a stand-alone BEC is one of the simplest and safest.
A separate LVC is used to ensure that both motors cut off together when the battery is low. Also a Good Idea. Again, there are other ways to deal with the problem, but the stand-alone LVC is one of the safest.
The SmartBEC linked above serves both purposes. I use one on my 38 and also on my 262 and another EDF twin.
rdeis is online now Find More Posts by rdeis
Old Apr 12, 2012, 12:57 PM
Kurt is online now
Upstanding Member
Kurt's Avatar
Joined Sep 2003
Thanks much for the replies Hornetnz, RGS, and rdeis, very helpful!
Why don't both motors cut out together on the stock P-38, does each ESC have it's own LVC?
Think I'll go ahead and order a SmartBEC now, would hate to chinz out on $25 and then kick myself later...
BTW - I've already ordered pusher/puller props from Tower to do the counter-rotation mod recommended by http://z8rc.blogspot.com/2011/11/p-3...-rotation.html
Couldn't find much in this thread about this, is it not the general consensus that it serves any useful purpose?
Old Apr 12, 2012, 06:17 PM
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
A conventional BEC is not going to prevent one ESC hitting a Low Voltage Cutoff point before the other. You could use a separate BEC and disable the two in the ESCs, but most don't bother. The voltage outputs of the two (identical) BECs in the ESCs are so close that they do not fight each other. In my experience they are fine to use and provide ample current for the entire system.
Best practice for determining how long you should fly is to observe how many mAh go back into each pack after a short initial flight, and calculate how long you can fly based on that. Stay under 80% of the battery capacity and you'll always have enough reserve for a go around or two, or a particularly "sporty" flight.
I link my timer to my throttle so it counts down when throttle >20%. I think I time for 7 minute flights on a 3S 2200. I never put more than 1760mAh back in.
HTH
Discussion Banana Hobby P-51 w/2.4 GHz Tx/Rx cypherpix Electric Warbirds 9 Nov 26, 2008 03:32 PM
For Sale (NEW) F-Model P-38 Cowls Orion Pax Aircraft - Electric - Airplanes (FS/W) 13 Oct 30, 2008 07:22 PM
New Product New Phase 3 P-38 = EMI P-38 repackaged? shschon Electric Warbirds 16 Nov 25, 2007 11:57 AM
Discussion New E-flite P-38 pda4you Foamies (Kits) 1 Jan 12, 2007 11:04 PM
New Product New web shop, New product *EMI P-38 Forked Tail Devil * infinityhobby Product Announcements 60 Nov 03, 2006 06:48 PM
