Old Nov 12, 2011, 12:43 AM
TX Flyboy is offline
Find More Posts by TX Flyboy
Dallas, TX
Joined Oct 2010
Originally Posted by 6Sally5 View Post
Hey TXFlyboy...I read in this thread somewhere that a guy was replacing the stock motors with Exceed RC Optima motors, MAS 3-blade props, and DuBro spinners. Was that you? I am planning on the same thing, but can't figure out how to attach the spinners with backplate to the motor shafts. The shafts are too short to extend through the nacelles. Is there a longer prop adapter somewhere? Thanks, Alan
nope, sorry, it wasn't me... wish it was since I put mine in nose first a couple of months ago and am still rebuilding/repainting/etc. I have been looking for new motors to no avail - either they won't work or always out of stock! I will probably buy a kit for $89 and steal the motors/spinner/props (and possibly upgrade to etracts (mine is a V1)) out of it and keep the rest for spare parts for the next crash!
good luck on your quest and if you do find a solution be sure to post it!
TX
TX Flyboy is offline Find More Posts by TX Flyboy
Old Nov 12, 2011, 09:56 AM
Galand is offline
Find More Posts by Galand
Galand's Avatar
Long Island, NY
Joined May 2010
This will give you an idea on how to upgrade motors:
http://www.rcgroups.com/forums/showp...postcount=1419
I used these motors:
http://www.hobbyking.com/hobbycity/s...idProduct=3883
They are not in stock but you can find equivalents.
The pic's below show how I mounted them. I also put a 1550mAh batt in each nacelle and made the wing tips removable.
The stock prop and spinner looked terrible!
So I put on Dubro 3 blade spinners with GWS 9x5 3b props.
When you use a can-mounted prop adapter it is simple to fit the spinners and props.
It flies very well and up to 15 mins!
Galand is offline Find More Posts by Galand
Old Nov 14, 2011, 09:50 PM
6Sally5 is offline
Find More Posts by 6Sally5
6Sally5's Avatar
United States, CA, Lincoln
Joined Jan 2011
TX
Thanks to you and TXFlyboy. I can't wait to get this back in the air...especially since I only go to take off, then handed it over to somebody else who, no fault of his, had an unplanned sudden landing! Haha!
6Sally5 is offline Find More Posts by 6Sally5
Old Nov 14, 2011, 09:54 PM
6Sally5 is offline
6Sally5's Avatar
Joined Jan 2011
Wow Galand!!! That looks fantastic! Congratulations...any flying vids?
Old Nov 15, 2011, 07:39 PM
Galand is offline
Galand's Avatar
Long Island, NY
Joined May 2010
Thanks.
This is it's maiden flown by my son Harold:
http://www.youtube.com/user/b6s4shel.../5/Qqrymlx4TWQ
Not very good quality video.
I was quite sceptical about the landing gear on that "first cut" type rough grass, but it actually did quite well.
No more loosing hatches. I now use rubber bands around the gondola and the nacelles. Have to find a better fixation method for those.
Doubled up on the magnets for the compressor covers, that now holds them.
The Dubro spinners and GWS props, even if not scale, came out quite well, I think.
And it is an excellent prop/motor/battery flying combination.
Old Nov 15, 2011, 11:25 PM
WestTexasKing is offline
Find More Posts by WestTexasKing
WestTexasKing's Avatar
Monahans TX
Joined Sep 2010
Reinforce the hatch and nose with a bit of balsa or basswood and install one (or two) of these:
http://www.hobbyking.com/hobbyking/s...idProduct=9218
Only reason for the wood is because foam has a tendency to wear out quickly and then you're back at square one.
Building a frame for the assembly, along with the area that the latch will hold against right in front of the windshield, will provide a solid and secure way to lock the hatch down without being too noticeable.
Looks way better than rubber bands even though it's hard to beat rubber bands for reliability
Before mine was destroyed I had one for the battery hatch and two for another access hatch that I cut out from underneath the cockpit...they worked perfectly.
The bottom latches held up even when belly landing on rather rough dirt/dead grass.
Highly recommended!
WestTexasKing is offline Find More Posts by WestTexasKing
Old Nov 16, 2011, 06:23 AM
jeeper1977 is offline
Find More Posts by jeeper1977
jeeper1977's Avatar
Lake Havasu City AZ
Joined Feb 2009
My CG is tail heavy with the largest battery that will fit. Do you guys have to add weight to the nose to correct. Is 70mm from the lead edge of the wing correct?
jeeper1977 is offline Find More Posts by jeeper1977
Old Nov 16, 2011, 11:32 AM
Monahans TX
Joined Sep 2010
That's really odd, a 3S 2200mah battery is more than enough to balance.
An even bigger battery is on the verge of being too nose heavy.
What version do you have?
Old Nov 16, 2011, 01:42 PM
6Sally5 is offline
6Sally5's Avatar
Joined Jan 2011
Well done, Galand and nice flying by Harold. Do you have any pics of the modification of the nacelles for the 1500ma batteries? I'd like to see how you did that.
Old Nov 16, 2011, 05:04 PM
Galand is offline
Galand's Avatar
Long Island, NY
Joined May 2010
Highly recommended!
I agree, the rubber bands look terrible but its quick and you cannot see them in the air.
Might try the latches during the dark days of winter building.
Old Nov 16, 2011, 06:02 PM
Galand is offline
Galand's Avatar
Long Island, NY
Joined May 2010
I stole the idea from someone. I think Gohmer but not sure.
I do not have a pic of the batts in place.
I slide them into the nacelle, contact wires first. They sit snug, sticking out approx 1/2". I attached a velcro strip to each battery to help with pulling them back out.
The starboard side also has the power connector (balance plug) for powering the Smart Bec.
Old Nov 17, 2011, 06:13 AM
jeeper1977's Avatar
Lake Havasu City AZ
Joined Feb 2009
It's a V1. Using a 3s 2200mah 30c battery that weighs 185g. Balances right at the spar.
Old Nov 21, 2011, 04:39 PM
pulver is offline
Find More Posts by pulver
Norge, Troms, Bardu
Joined May 2011
Where the heck are your`s wings???
But if you airborne your`s plane like that..I love to se a video
pulver is offline Find More Posts by pulver
Old Nov 21, 2011, 06:30 PM
Galand is offline
Galand's Avatar
Long Island, NY
Joined May 2010
No need to be confused, Pulver. Removable wing tips.
See posts #3639 et #3675 on how to do it.
Old Nov 23, 2011, 12:58 PM
38Driver is offline
Find More Posts by 38Driver
Joined Nov 2011
$49.00 p-38
Banana Item 2028, $49.00. They can't seem to tell you which version you'll get.
38Driver is offline Find More Posts by 38Driver
Discussion Banana Hobby P-51 w/2.4 GHz Tx/Rx cypherpix Electric Warbirds 9 Nov 26, 2008 03:32 PM
For Sale (NEW) F-Model P-38 Cowls Orion Pax Aircraft - Electric - Airplanes (FS/W) 13 Oct 30, 2008 07:22 PM
New Product New Phase 3 P-38 = EMI P-38 repackaged? shschon Electric Warbirds 16 Nov 25, 2007 11:57 AM
Discussion New E-flite P-38 pda4you Foamies (Kits) 1 Jan 12, 2007 11:04 PM
New Product New web shop, New product *EMI P-38 Forked Tail Devil * infinityhobby Product Announcements 60 Nov 03, 2006 06:48 PM
