United States, FL, Fort Lauderdale
Joined Jan 2011
Latest blog entry: My Build Review of the FMS V3 1400MM...
The only thing I've been able to come up with is to add a mix for the nosewheel to an unused channel slaved to the rudder, then down at the bottom of the mix menu set the three position switch to disable the mix when the switch is is up, down, or in the middle...your preference. Once in the air, the switch can be disabled and the gear retracted. For landing, gear down and then flip the switch back. I know for a fact it works, it's not difficult to set up, but it's not as simple as just flipping a single switch as you need to remember about both switches together. I'm starting to think that's what I did to begin with now that I've tried to reproduce it. Another thing I've tinkered with is to have the gear come down with the three position switch so both functions could be combined, but no luck there. According to the display screen, I could only get the gear to retract and go back to center ![]() I can change it up to where the movement is centered, so it's going up and down equally, but it wouldn't be enough input to signal the gear actuator as they work best with >100% end point travel. The stick is great! I went with the longer CF fuselage as you suggested and mounted some gigantic tundra tires (FMS P-51 tires, LOL). I can land it on the rocky strip I use for my ag planes and it looks really impressive bouncing all over the place. I went with the recommended brushless setup but I'm thinking about mounting a ridiculously huge motor just for giggles ![]() Also noticed you've got HK's minimoa, got mine a few weeks ago. Did the cooling mods and mounted one of my old V1 P-38 motors on it. Thought the slightly larger motor would run cooler, which it did. They're nearly identical in all aspects aside from the bell being a few mm's longer. So far, it's got a hole drilled in the center of the spinner, 6 holes through the back plate, and one large hole between the wheel and the skid underneath the cockpit. It's hard to spot, but when you do it looks like it was supposed to be there does a great job of evacuating heat from the fuselage. Much better than the grommet holes I've seen on others. Anyway, back to the P-38... Sorry for being off-topic
Joined Nov 2010
Kudos to J-Power for listening
Judging from all the complaints about V1 that were addressed in V2, I want to say "Good Job" to the folks at J-Power and Banana Hobby who obviously follow this thread.
Upgraded battery: 2600 mAh, "servoless" retracts, 1200 kV motor mounted to a plexi plate, not the embedded soft plastic. Good solder joints and good connectors on the 30A ESC. Better paint job that is staying on! Pilot bust is still glued on! CF from wing root to wingtip; solid 6MM CF rod to help hold the wings on. Construction is screwed together, not glued; technically, it can still come apart for maintenance, if not transport (no way).Dear J-Power, If you are listening, please tell the worker who shoves the gear door hinges into the styrofoam to try harder - I had to use Zippo fluid to melt the glue enough to shove them home. To the design engineer: back to the drawing board and redesign the nose gear. The door interferes with the closing gear and the steering servo is still binding when gear is up To the packaging engineer: Please tape the wings and horizontal stab/elevator assembly to a piece of styrofoam to prevent warping during shipment. I wonder if you just "sandwiched" the two wings (bottoms facing eachother) with the elevator in the middle (a la Oreo) the whole thing should arrive straight. I'd be happy to accept a new pair of wings for this awesome idea
Los Angeles
Joined Sep 2010
Galand, are those the stock spinners and backplates? My spinner backplate holes have stripped and they just spin on the V1 threaded motor shaft, which causes the props not to be driven. I need to find another option than the standard spinners for 3 blade props and havin't found anything yet. Please let me know where you found yours. Thanks |
Pilot...no need for the molded in hex, it'll only make the situation worse anyway.
What you need to do is tighten two nuts together with a small washer between them right behind the back plate. That allows the back plate to be nearly identical in original spacing and not deform under torque. It'll take some adjustment but you should be able to get the spinner near flush with the cowling. After you've got the spacing set up, reinstall the prop and tighten it down with a nylon insert lock nut. Don't get it too tight, it'll warp the back plate, but you do want it snug. Shouldn't have a single loose prop related issue after that... |
| Thread Tools | |
| Discussion Banana Hobby P-51 w/2.4 GHz Tx/Rx | cypherpix | Electric Warbirds | 9 | Nov 26, 2008 03:32 PM |
| For Sale (NEW) F-Model P-38 Cowls | Orion Pax | Aircraft - Electric - Airplanes (FS/W) | 13 | Oct 30, 2008 07:22 PM |
| New Product New Phase 3 P-38 = EMI P-38 repackaged? | shschon | Electric Warbirds | 16 | Nov 25, 2007 11:57 AM |
| Discussion New E-flite P-38 | pda4you | Foamies (Kits) | 1 | Jan 12, 2007 11:04 PM |
| New Product New web shop, New product *EMI P-38 Forked Tail Devil * | infinityhobby | Product Announcements | 60 | Nov 03, 2006 06:48 PM |
