Old May 11, 2011, 01:37 PM
Trusted Verified User
griffin 27's Avatar
United States, CA, San Diego
Joined May 2009
Originally Posted by Lardog View Post
Trust me, you'll want to switch. Those flimsy stock props aren't able to deliver the power your motors are capable of. I switched motors and kept the stock props, but was fairly disappointed at the results. Put on some MAS 10x7x3s and it made all the difference.
Dont the MAS 10x7x3s almost hit the ground ?? I put on some 9x7.5 APC two blade props and they are only a half inch from the payment I think ? BTW, two blade 9x7.5 props with upgraded park 480 motors dont really make the plane fast enough for me, I cant even imagine the plane getting off the ground with an all stock setup.
griffin 27 is offline Find More Posts by griffin 27
Old May 11, 2011, 02:44 PM
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Yes, they hit, but then, so did the stock props. With the 3-blade and no ESC brake, they just rotate out of the way when landing. Again, probably a 9x7x3 would work better.
I used BP 2810-11 (1200Kv) motors.This is no speed demon, but is considerably faster than stock. It does have thrust for days, however.
Lardog is offline Find More Posts by Lardog
Old May 12, 2011, 08:39 AM
Owatonna MN 55060
Joined Sep 2005
Originally Posted by rickfe101 View Post
The wings on mine really flex in flight. Has anyone done anything to reinforce them?
Did you join the two spars in the center with anything? I used a piece of tempered wire to join mine and a CF tube in the wire channel.
Gohmer is offline Find More Posts by Gohmer
Old May 12, 2011, 09:17 AM
United States, CA, Sunnyvale
Joined Mar 2011
Is your's a ver1 or ver2? Have you compared any amp/watt numbers?
Vincent
vhuang168 is offline Find More Posts by vhuang168
Old May 12, 2011, 11:03 AM
Joined Mar 2011
Fired the motors up for the 1st time yesterday. Ran some batteries through to check out the watt/amp readings and here is what I got.
All on stock Ver2 motors 1100kv and stock props
3s 2200mah 35c @ 12.26V 482.2Wp 45.24Ap
3s 2200mah 45c @ 12.57V 573.4Wp 50.30Ap
4s 2200mah 35c @ 16.45v 979.7Wp 69.19Ap
I only ran the 4s at WOT for a few secs just to get the reading but I'm pretty sure I'd fry the ESCs if I kept it up. Aren't they rated for 30Amps?
The 1st 3s pack was about a 3/4 charge so it should be more representive of acutal use, the 2nd pack was at full charge and was a 45C pack.
Have my MAS 10X7X3 CR props on order, should be here tomorrow. Already bought the tractor MAS props.
In the stock setup, the motors have some right/down thrust angles built in already. It looks like the foam is acutally angled because the plexi is flat and the motor mounts to the plexi with no spacer.
If I go CR, do I have to straighten the thrust angles out?
Old May 12, 2011, 11:20 AM
ex-noob
Lardog's Avatar
Sammamish, WA, USA
Joined Jan 2010
Mine is a v1. I've had it for about a year now. The two BP motors combined with the MAS 10x7x3s pull about 53A and 600W. These motors with the stock props pull about 48A and 530W.
IIRC, with the stock motors and stock props, it was closer to around 300W. I think the new v2 motors are likely a bit stronger.
Old May 12, 2011, 11:49 AM
United States, TN, Jackson
Joined Mar 2007
Originally Posted by Rob Knox View Post
Have to agree, The Stock props are fine, although I do have a lovely grass park on which to slide her in on .
Hey, just as a matter of interest, Has anyone else tried to spin this thing. It ends up being more of a cork screw. Very funny.
When spinning try some opposite aileron---Flattens the spin a bit so that it doesn't look so weird..
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old May 12, 2011, 09:04 PM
Shameful Warbirdaholic.
Aros's Avatar
Maple Valley, WA
Joined Apr 2006
Well I'm in the hunt for the V1 battery tray/lid. Beautiful evening so I took her to the top of this hill by my house with beautiful views. Suddenly during mid flight the winds kicked up. And boy do I mean kick up! Suddenly I was negotiating through 35-40mph winds! Holy cow!!
Our area is in the Cascade foothills, known for winds but this really took me by complete surprise. So as I am bringing her in for a very hairy final, I saw the lid go flying off (the force of the gusts flipped it right off the magnetized base!)...I tried my best to triangulate to search after landing...Brought her in and dropped throttle right as my wings found level and made an uneventful touchdown. Whew!
I searched for the lid but to no avail. It's flat olive blended with the tall grassy hillside to perfection. Anyone have a spare they want to sell?
Aros is offline Find More Posts by Aros
WestTexasKing's Avatar
Monahans TX
Joined Sep 2010
Try doing a spin with differential thrust, the wings turn into rotor blades and you gain altitude from spinning so fast.
OK, well maybe there's some creative licensing involved there, but I swear it descends like a parachute in a thermal.
No possible way to keep track of orientation, and I can pretty much keep track of my PZ Sukhoi XP with max throws on the ailerons....crazy stuff
WestTexasKing is offline Find More Posts by WestTexasKing
Old May 13, 2011, 02:32 PM
Field of Dreams Flyer
Mikemynameis's Avatar
San Pedro,Ca
Joined Sep 2004
So what is the difference between V1 and V2
Mikemynameis is offline Find More Posts by Mikemynameis
Old May 13, 2011, 03:46 PM
Grand Rapids, MI
Joined Jun 2005
Different motors, servoless retracts, different methods of wing joining and boom attachment...
Hornetnz is online now Find More Posts by Hornetnz
Old May 13, 2011, 04:44 PM
San Pedro,Ca
Joined Sep 2004
So what version is the one from HobbyKing
Old May 13, 2011, 04:52 PM
San Pedro,Ca
Joined Sep 2004
nevermind i see the pics its ver 1 thats why the price is so cheap
Old May 13, 2011, 05:12 PM
Owatonna MN 55060
Joined Sep 2005
BH has the airframe version for $89.00 None of the versions have good motors or retracts.
Old May 13, 2011, 05:37 PM
Monahans TX
Joined Sep 2010
Hobbyking is supposed to have the V2, they just haven't updated the page.
Only problems I've heard about the V2 retracts is that they don't like being subjected to water (dew on grass).
Discussion Banana Hobby P-51 w/2.4 GHz Tx/Rx cypherpix Electric Warbirds 9 Nov 26, 2008 03:32 PM
For Sale (NEW) F-Model P-38 Cowls Orion Pax Aircraft - Electric - Airplanes (FS/W) 13 Oct 30, 2008 07:22 PM
New Product New Phase 3 P-38 = EMI P-38 repackaged? shschon Electric Warbirds 16 Nov 25, 2007 11:57 AM
Discussion New E-flite P-38 pda4you Foamies (Kits) 1 Jan 12, 2007 11:04 PM
New Product New web shop, New product *EMI P-38 Forked Tail Devil * infinityhobby Product Announcements 60 Nov 03, 2006 06:48 PM
