Omaha, NE
Joined Oct 2009
Hey guys, I just received my BH P-38 and began doing the necessary dry fitting and wiring etc.
During a power test everything appeared to work fine but after a few tries of lowering and raising the gear, the nose gear steering servo began to jitter by itself then got worse to the point it was sounding crunchy. I powered down then looked around and didnt see anything I thought was out of ordinary and powered it up again - the nose steering servo began to spin inside. I take it the gear is stripped? Anyways its not a big deal just wondering if this plane is steerable with out that servo? I have a replacement coming in the meantime but I would like to fly it if I can. Also how do you guys tune the servos to quit jittering? Thanks in advance. Julian |
Omaha, NE
Joined Oct 2009
Goodyear, AZ.
Joined Dec 2005
Same with mine... after 5 flights.. need to put CA in places (retracts) I also used hot glue on the nose retract area.. (screws came off, I dont know if in-flight or during landing) but 2 of them are gone, only 2 left holding it. Hot glue Fixed that area for now. I dont know for how long it will hold. I have a T28 foamy (PZ) it seems it can take a lot of beating (mine is still pristine condition) I dont know with this P38 how long the foam will last. (maybe more damage just getting to and from the field) Also with the other jet foamys at BH... dont know how durable, how long they last. I came across one person in youtube that his BH planes lasted about 10 flights then things fall apart. I would like for mine to live forever (no crashes)...
I finally got the "replacement" airframe built & it was no bargain. I was sent some sort of prototype with crappy original parts.
The landing gear had additional support wires attached and they were loose so they rotated on their own, had to fix (tried to anyway) with CA, the gear doors had hinges setup so they were hinged closed!!! I had to peel off the hinges, take them apart and put the hinges in backwards, then re-glue everything back together. Somewhere during the process it crossed my mind to chuck them and see what OP was doing for doors and follow his lead.. Then I discovered they didn't include the little fishing line jigs for closing the doors. Had to recover those from the crashed one.... After much screwing around to mount them, the new problem is the doors wont close all way because the hinges appear to be too stiff!!!!! What a croc... Just cant win. Any suggestions for gear doors would be welcome at this point I feel like ripping them off and flying naked!!!!!!!!!!!!! Anyway, took it out this morning for the maiden, besides some clicks of left aileron all went well, flew like a dream & I forgot how quickly it took off. It leaps off the ground in 30 feet. Not much top end but lots of grunt with the stock motors. The Tower pros I used from hobbyking in the last one appear to have more pull and gave me a slightly higher top end... With all the messing around and other projects on the go, I don't have the time or inclination to change them out.... |
| Thread Tools | |
| Discussion Banana Hobby P-51 w/2.4 GHz Tx/Rx | cypherpix | Electric Warbirds | 9 | Nov 26, 2008 03:32 PM |
| For Sale (NEW) F-Model P-38 Cowls | Orion Pax | Aircraft - Electric - Airplanes (FS/W) | 13 | Oct 30, 2008 07:22 PM |
| New Product New Phase 3 P-38 = EMI P-38 repackaged? | shschon | Electric Warbirds | 16 | Nov 25, 2007 11:57 AM |
| Discussion New E-flite P-38 | pda4you | Foamies (Kits) | 1 | Jan 12, 2007 11:04 PM |
| New Product New web shop, New product *EMI P-38 Forked Tail Devil * | infinityhobby | Product Announcements | 60 | Nov 03, 2006 06:48 PM |
