Right now it's a lawnmower tire but I keep some plugs and such on the motorcycle for emergencies. Some if the girlie glue even says extremely flammable. I fell for that one and thought I had the real McCoy. NOT. |
I used to guide bicycle tours and have done hundreds of patch jobs.
The best tube patch kits are made by the French company Velux. The patches have nice feathered edges and the cement is top quality. I added one of those mini Bic lighters to the kit. 1. Find the leak. On the road I would slightly over inflate the tube, lick my lips and slowly move the tube past them. You can feel the jet of air from the leak pretty well. 2. Rough up the area that will be covered by the patch with the scuffer provided in the kit. First in one direction then at 90 degrees to the first. 3. Peel the backing off of the patch and have it at the ready. 4. Apply a nice coat of cement to an area slightly larger than that the patch will cover. 5. Quickly ignite the cement with the lighter. 6. The moment the cement is not burning, apply the patch. Hold it firmly in place until it cools. This is now the strongest part of tube and I have never had a patch applied this way fail even using cheaper kits. Almost forgot the one thing that trips people up most often. WITH GREAT CARE inspect the inside of the tire for the cause of the leak. If possible, turn the tire inside out to do this. No sense fixing a flat and then just getting another one from the same issue. |
Joined Dec 2002
Once the hole is located, i stick a round toothpick in it to keep it located when the tube deflates. Then put 4 dots of Whiteout equidistant from the hole, to mark the area to be scruffed. Helps assure the patch is dead-centered on the hole.
BTW, whatever went with the non-pneumatic 'solid' tubes J.C. Penney used to sell in the late '70s? Those were the cat's meow. |
maine
I appreciate your kindness but I gave that up 45yrs ago! It gave me headaches! I just couldn't see what the big to-do about it was. I'd say it was very over-rated
maine
What company sells the brand or repair kit? |
| Thread Tools | |
| Have you tried it? | genovia | Electric Plane Talk | 5 | Sep 27, 2002 08:46 PM |
| Lithium Ions: CGR 18650HG : Have you tried them? | Daveairway | Parkflyers | 0 | Aug 30, 2002 03:43 PM |
| 3 x 2/3 AA 600 mAh Rayovac for $5.99 - have you tried them? | Christophe | Parkflyers | 3 | Jun 08, 2001 12:33 AM |
